Old 04-06-2012, 09:46 AM   #51
JRANGER
JRANGER's Avatar
Re: Project 78 High Sierra
A look from the driver seat
JRANGER is offline   Reply With Quote
Old 04-06-2012, 07:11 PM   #52
JRANGER
JRANGER's Avatar
Good Friday rocks!!! I got out of work 2 hours early and got my kick panels in...So who wants to rock???? ME!!!!
Old 04-07-2012, 05:32 PM   #53
JRANGER
JRANGER's Avatar
Well i wanted to do four patches today...Both fenders and the cab corners....I failed......My flange and punch tool died and i only completed the one fender which was paint cuz i couldnt fully flange or punch it...So i used pliers and made do......Spot welding didnt happen much but with some grinding and finding bondo i got it done....So now it just needs some bondo to smooth it out and fix a few lil holes/gaps
SAFETY FIRST!! LOL
Old 04-07-2012, 09:50 PM   #54
JRANGER
JRANGER's Avatar
Got half the hood sanded
Old 04-08-2012, 08:25 AM   #55
UPNADM
UPNADM's Avatar
Now you are committed... Good start my man.
UPNADM is offline   Reply With Quote
Old 04-08-2012, 11:04 AM   #56
survivingalone
are the speakers in your kick panels hooked up? how do they sound?
survivingalone is offline   Reply With Quote
Old 04-08-2012, 11:31 AM   #57
JRANGER
JRANGER's Avatar
They are hooked up and sound amazing! Only prob is it does get in the way of the e brake.....But that also could be because mine are bowed out ever so slightly on the bottom due to some welds
Old 04-08-2012, 03:44 PM   #58
JRANGER
JRANGER's Avatar
O yeah!!! Bare metal after I hit it with 150 grit sand paper and lathered her up with soap and washed her off
Old 04-08-2012, 04:38 PM   #59
JRANGER
JRANGER's Avatar
After soap and water, drying, and hitting it will alcohol I hit it with 4 coats of Eastwood Self Etching black primer......Has a few spots Ill need to hit with a small bit of bondo and then i can get a lil sanding in before I hit it will some more sandable primer....
Notice all the paint dust on my house? This thing had 2 - 3 different coats of paint on it...sheesh.....The under side will just be rust repair and nothing special
Old 04-10-2012, 09:02 AM   #60
JRANGER
JRANGER's Avatar
Took a wire wheel to the rusty part of the underside....It created some holes that im probably going to gill with bondo just to keep it smooth and strong as the area is way to thin to just patch weld..... Either way I hit it with some Krylon Rust Tough afterwards.....
Old 04-10-2012, 09:04 AM   #61
UPNADM
UPNADM's Avatar
Looks great! Keep on going...
Old 04-10-2012, 09:17 AM   #62
JRANGER
JRANGER's Avatar
Read my pm!!!
Ive ordered a bunch of sanding discs for the right angle grinder for so i can work on the fender and rest of the truck.... Ordered some more primer, and some bondo..So should have that soon so hopefully ill get the next set of primer this weekend
Old 04-10-2012, 08:28 PM   #63
y5mgisi
Second Chance Program
y5mgisi's Avatar
I really appreciate your ambition!
y5mgisi is offline   Reply With Quote
Old 04-10-2012, 08:40 PM   #64
JRANGER
JRANGER's Avatar
LOL!!!! THANKS! i like to stay busy....Currently this is what keeps me busy and out of trouble...Could be my adhd though
And todays work.....Wire wheeled the back of the passenger side pull a part fender, cleaned it, and sprayed it with rust tough
Old 04-10-2012, 10:36 PM   #65
UPNADM
UPNADM's Avatar
Good days work. Good stuff.
Old 04-11-2012, 04:33 PM   #66
JRANGER
JRANGER's Avatar
Decided I need to do the right thing before i mess myself up...
Ordered:
Respirator (yes ive been sanding without one.....yes im still sneezing up paint)
Paint Gun
More Primer
Paint removal discs
a new flange/punch tool
some bondo
some files to get the real small cracks and spaces
and some other crap lol
Old 04-14-2012, 02:28 PM   #67
JRANGER
JRANGER's Avatar
Ok used my new Paint removal disc (http://www.roarksupply.com/product-p/4.5cleanstrip.htm) i stripped down the fender...found a few small holes that where bondo over and got it to bare metal....
Pounded out a bit of a dent and then cleaned it up. Hit it with 2 coats of self etching primer before I ran out. Then I hit it with 2 coats of sandable primer...
Now that its flat black I can see all the divits and low spots so ill do a lil bondo to smooth it out and prime it some more
CAN SOMEONE TELL ME IF THE EMBLEM TAKE 1 or 2 HOLES??? There are 2 normal holes but one was bondo over and im not sure if i need it for the emblem
Old 04-14-2012, 03:01 PM   #68
grayharville
^^who I am^^ what I say>
grayharville's Avatar
Yes you need both holes. Should be about eight inches apart or so.
70 chevy LWB 350/TH350 Barn find (AKA the 70)
http://www.67-72chevytrucks.com/vboa...d.php?t=406364
East Tx Squares
grayharville is offline   Reply With Quote
Old 04-14-2012, 05:11 PM   #69
JRANGER
JRANGER's Avatar
ok great! I popped the bondo out of the other hole with a screw driver...
Old 04-18-2012, 10:38 AM   #70
JRANGER
JRANGER's Avatar
Well driving to work a saw a square that is setup the way I plan mine to look in the end...The only difference is the white will be black on mine...
Not a bad looking truck except once up close you can tell how bad of a paint job dude did...Its was a bit cloudy so you can tell he did a bad rattle can job...Either way...
Old 04-18-2012, 11:06 AM   #71
glimmertwin01
glimmertwin01's Avatar
good work man.... I guess you saw the obstacles im up against for a GA truck that spent 15 yrs in Upstate NY
67/68 K/20 "The BEAST"
68 K15 V6 LWB.
73 K20 GMC Burb "The Bomber"
74 K/5
74 K20 Custom Deluxe
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Life is what you make it Live each day like it was your last
Old GM Trucks never go out of style
glimmertwin01 is offline   Reply With Quote
Old 04-18-2012, 11:08 AM   #72
JRANGER
JRANGER's Avatar
yeah man...I remember looking at that thing a while back and just saw your updates...Your right...that is a lot worse then mine...Good luck and good job so far though...
Old 04-18-2012, 11:32 AM   #73
KSWes
KSWes's Avatar
Had to check out your build! I haven't looked at too many of the square builds on the site yet. Been looking for ideas on my 70, but I am now subscibed! Some great work on your part! Nice job on the body work! and the interior looks great. Subscribed!
70 Chevy C10 LWB
My Build:http://67-72chevytrucks.com/vboard/s...d.php?t=513002
KSWes is offline   Reply With Quote
Old 04-18-2012, 11:39 AM   #74
JRANGER
JRANGER's Avatar
Thanks man!!! I feel pretty good about it since Ive never done any work like this and for that matter im a computer geek so its not like im even a mechanic or body guy.... Learning is the best part of this process and this board has been more then helpful in this process
Old 04-18-2012, 11:51 AM   #75
grayharville
I have alot of respect for you northern guys that are repairing the rust yall have to deal with, I swapped my cab 3 times until I got one that only needs cab corners, and im still complaining
That paint job should look pretty interesting, I've never seen that before.
East Tx Squares
