Old 07-12-2012, 07:21 PM   #51
6lcummins
Re: 1988 Suburban "V Rig" Gets Cummins Power
24V is smooth with the head:
12V have "ears" that stick up above the runner and are easier to drill and tap than a 24V
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK"
ASSEMBLY THREAD
6lcummins is offline   Reply With Quote
Old 07-12-2012, 08:28 PM   #52
Mattman2010
Mattman2010's Avatar
That does look like a pain. Have fun with that Ryan!
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 07-19-2012, 06:15 PM   #53
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I've been working away on this thing. I have the front cross member done, welded in the steering box support plates, got the engine painted, and the injection pump now has a 3k gov spring in it. Now the engine is getting new injectors, and a Denny T stage II fuel pin. This thing should run pretty good. I'll try to get more pics later. Hopefully before the weekend I can have the engine sitting back in the frame.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 07-25-2012, 05:33 PM   #54
Dieselwrencher
Time for updates! I've been sweating my butt off working away on this thing! I got the front cross member and engine cross member finished and bolted back in. I also installed some heat/sound deadener insulation on the fire wall.
Got the engine painted and the injection pump installed. Also installed the SFI rated flex plate.
Yesterday I sat the engine back in it and hung the transfer case on it to see what mods are next. I'm going to have to cut the cross member and clearance it for the drive shaft. The drive shaft also needs lengthened. I installed the starter, hooked up the fuel feed line, installed the OE oil pressure sensor, and have to get a bushing for the OE water temp sender.
Ryan
Old 07-25-2012, 06:06 PM   #55
Dieselwrencher
Some pics underneath.
Ryan
Old 07-25-2012, 10:12 PM   #56
Mattman2010
Looking good bud!
Build Thread
Build Thread
Thread
Old 08-30-2012, 02:27 AM   #57
Dieselwrencher
I finally got the D70 in the rear of this and got the turbo and exhaust manifold back on. I have the down pipe built, now to finish the exhaust and build the trans mount. Been cleaning parts and pieces and painting them, installed the new water pump, and removed the dodge truck harness and PCM. I'm going to use it to run the alt, grid heaters, and over drive on the trans.
Ryan
Old 09-26-2012, 06:11 PM   #58
Dieselwrencher
Been plugging away at this thing. Anyone that says these don't take much time, must not know. The exhaust tip is just tacked on there to see if I like the angle the pipe is coming out at. It does have 4" going over the tcase too.
Intercooler and support mods.
Ryan
Old 09-26-2012, 06:13 PM   #59
Dieselwrencher
I've got to figure out where the trans cooler is going to go now, and get the trans linkage figured out. Still waiting on the radiator and drive shafts, then I need to finish up the wiring. Yee haw!
Ryan
Old 09-26-2012, 09:32 PM   #60
86454k30
86454k30's Avatar
Cool build! Where did you find the GMC grille without the emblem base molded into it?
86454k30 is offline   Reply With Quote
Old 09-26-2012, 11:03 PM   #61
Dieselwrencher
I'm not sure where that came from. I saw that and was like sweet! You can see where an emblem would have bolted in there. Could that be an 88 only deal maybe?
Ryan
Old 09-27-2012, 12:12 AM   #62
Mattman2010
Looking good bud, you sure have been busy on it!
Build Thread
Build Thread
Thread
Old 09-27-2012, 04:34 PM   #63
Dieselwrencher
Today I spent 4 hours installing this. Wow, I'm glad I don't have to do anymore of these for a while.
Ryan
Old 10-19-2012, 07:22 PM   #64
Dieselwrencher
Here is some more progress pics. The radiator support is done, I just have to paint it. Been working on replacing the tie rod ends, installing the DIY4X spring plates on the D60, got the fan hub and belt on the engine. Fuel lines are installed and hooked up, and new injectors are installed.
Ryan
Old 10-27-2012, 02:42 PM   #65
kwin
kwin's Avatar
Any progress?
Keith Winsor
www.ramsaywinsor.com
kwin is offline   Reply With Quote
Old 10-29-2012, 10:34 AM   #66
Dieselwrencher
Originally Posted by kwin View Post
Any progress?
Yes, but not a lot of picture proof. The new trans is in, transfer case is back on, and now I have to redo the trans mount. I swapped out the fan hub so I can get an aftermarket pulley for the a/c bracket I'm running on it. Finally got the radiator back, and need to test fit it now. I had to remove the lh fender because the inner structure of it is all cracked and broken causing the fender to sag and at times you can't open the driver's door. I'll post pics this afternoon.
Ryan
Old 10-29-2012, 10:52 AM   #67
kwin
kwin's Avatar
I'm watching closely, I have a 12 valve, dana 60 / 70 combination and I picked up a 3/4 ton burb.
Just waiting for spring!
Keith Winsor
Old 10-31-2012, 04:22 PM   #68
Dieselwrencher
Time for pics! I got the tcase on, trans mount done, modified the shock mounts on the D60. I had to remove the driver's fender as it was nearly destroyed. This is the worst nice fender I've ever seen! I'll post what I have uploaded and then do more later.
Ryan
Old 10-31-2012, 04:52 PM   #69
Dieselwrencher
More done. Inner fender repainted.
New pulley for A/C set up.
A/C bracket.
Throttle cable set up installed, transmission pressure cable brackets hooked up and I got the cable adjusted properly.
Here was the first shot at making the trans mount. I ended up removing 1 1/2" of height from it to get the transfer case to clear the floor board. This utilizes the stock NP205 tcase rubbers. This truck had poly ones, so it worked out really well.
I have to remove the trans cross member and add gussets to the area where I raised it to clear the drive shaft. Tomorrow I will finish the front axle shock mounts. We had to put the mounting bolts in the mini lathe and turn them down from 3/4" to 1/2" so the chevy shocks can be used.
Ryan
Old 10-31-2012, 06:57 PM   #70
Dieselwrencher
When I was repairing the LH fender, I realized the radiator support had another broken piece. It was still bolted on the fender. I fixed it and then repainted the entire support.
Ryan
Old 10-31-2012, 07:49 PM   #71
kwin
kwin's Avatar
Did you make the AC bracket? I want one!
Is the frame stock or reinforced?
Great work by the way, I can't wait to get started on mine.
Keith
Keith Winsor
Old 10-31-2012, 08:53 PM   #72
Mattman2010
Looks like you have been busy man! Looking good!
Build Thread
Build Thread
Thread
Old 10-31-2012, 10:45 PM   #73
Dieselwrencher
Keith
Keith, no I didn't make the A/C bracket. I got the bracket and pulley from Auto World. They make top notch stuff. Check them out. If you call them ask for Donna. Tell her the crazy guy with the Cummins Corvette sent you.
Ryan
Old 10-31-2012, 10:45 PM   #74
Dieselwrencher
Thanks and yes I have been. I want to hear this thing run! And drive it. Haha
Ryan
Old 10-31-2012, 11:19 PM   #75
Mattman2010
Haha, With as many projects as your trying to get finished in like no time im sure it would be nice to get one done and driving. Even if it isnt yours
Build Thread
Build Thread
Thread
