Old 08-08-2013, 12:34 AM   #51
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: Introduction and 2wd Blazer in progress
Subscribed!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 08-08-2013, 05:44 PM   #52
DrppdBlazr
DrppdBlazr's Avatar
Nice looks killer man. I wanna see more
Bodied Blazer Build
http://67-72chevytrucks.com/vboard/s...d.php?t=611842
DrppdBlazr is offline   Reply With Quote
Old 08-13-2013, 08:36 PM   #53
gclark1
gclark1's Avatar
Thanks for all of the nice comments. It is really cool to have you guys get excited about the next steps. Well, since some of you have made updates to your builds today, I guess I should too. Got the jambs all painted and cleared the last couple of weeks. You would think that adding a little two-tone effect in the jambs would just take a few minutes, right? Not the case as it took a lot of time! Next weekend, off comes the body.
gclark1 is offline   Reply With Quote
Old 08-14-2013, 06:36 AM   #54
tvblazer78
Low & Fast!
tvblazer78's Avatar
Nice bro!
tvblazer78 is offline   Reply With Quote
Old 08-18-2013, 11:58 PM   #55
gclark1
gclark1's Avatar
Thanks TV!
Getting closer...
Old 08-19-2013, 01:28 AM   #56
mattcrp1
mattcrp1's Avatar
That color combo looks great.
mattcrp1 is offline   Reply With Quote
Old 08-26-2013, 07:11 PM   #57
gclark1
gclark1's Avatar
Thanks Matt.
Even though I thought the frame would make it back from powder, it did not. I spent the weekend cleaning stuff and getting it ready for re-assembly next weekend. I did have my brothers shop in the Phoenix area www.speedsportsaz.com do the ubndercoating on the body, so that part is now ready.
Old 09-10-2013, 01:17 AM   #58
gclark1
gclark1's Avatar
Got the chassis back from powdercoat and made it a roller over the weekend. Lots of new parts...body back on next weekend.
Old 09-10-2013, 04:48 AM   #59
Low Elco
Everything just looks fantastic. Can't wait to see more.
Low Elco is offline   Reply With Quote
Old 09-10-2013, 10:52 AM   #60
tvblazer78
Low & Fast!
tvblazer78's Avatar
Nice man!
Old 09-10-2013, 10:57 AM   #61
motornut
78K & 79C Jimmys
motornut's Avatar
looks real good,solid
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 09-10-2013, 03:47 PM   #62
68Timber
I know the pieces fit
68Timber's Avatar
Awesome dude!
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 09-10-2013, 10:52 PM   #63
gclark1
gclark1's Avatar
Thanks guys! It has been a ton of work to get it to this point, but I have been having a lot of fun. It really is coming out nice. I will update again next week when the body gets back on. I took off the "upper" overloads and gave the rear leafs about 3" of additional free arch, but did a flip kit at the same time, so I think that means it will be 2" lower than it used to be. I am afraid that it is going to be too low as the rear end is going to be close to the bottom of the body as well as the axle to the frame. Idon't mind doiing a notch, but have no interest modifying the floor - both of which will hit at about the same time so I likely will not do either. We'll see how close it is once the body gets back on and I start to weight it down. I can make the final adjustment with a re-arch of the leaf springs. More to come...
Old 09-11-2013, 10:00 AM   #64
blazer2007
why would you paint it and then remove the body,I,d be scared
blazer2007 is offline   Reply With Quote
Old 09-11-2013, 07:26 PM   #65
gclark1
gclark1's Avatar
No reason to be scared. I did not even have to touch the body. Used a lift to take it up, then bolted it right to the rotisserie. Done deal - no issues. Gotta have confidence, and it helps if you have someone that knows what they are doing. That is where my brother's hot rod shop comes in...
Old 09-11-2013, 07:34 PM   #66
lolife99
67-72 parts collector,…
lolife99's Avatar
Would you do the chassis and body paint work different next time?
(different order)
Keith
Convert to disc brakes.
Old 09-11-2013, 07:41 PM   #67
gclark1
gclark1's Avatar
As I was doing the bodywork myself over the last 12 months, I kind of thought it would be better if I did the chassis first. However, when I talked to folks, especially the shop that squirted it, they told me it is better to just do the chassis once it is painted. It was a bit more work as I had to line up the doors and all panels again (first time to bodywork them perfect, second time to ensure the 2-tone lines will line up behind the trim, now again to finish the project. The nice part about the way I did it is that I did not have to worry about stepping on, dragging my air hose, overspray, or any of the other thousand things that might mess up the chassis while I was finishing the paint. Provided you have a safe place to keep the body while doing the chassis for a few weeks, I would not change the order.
Old 09-17-2013, 12:10 AM   #68
BLOWN73
that thing is freaking awsome!!!!
BLOWN73 is offline   Reply With Quote
Old 09-17-2013, 10:54 PM   #69
gclark1
gclark1's Avatar
I hope you all understand that when someone says it is freakin awesome, I have a smile from ear to ear. Thanks a lot!!
All of you guys that have said how cool it looks makes me just keep pressing on toward getting it done and road worthy. More progress, but minor. More than anything, I got the body back on the chassis.
The money is getting out of control. I thought I could build one for 10-12 when I bought it since I would be doing most of the work myself. My brother laughed and said it would be 15-18. I thought there is no way I would ever spend that much on an old square body Blazer. Well, fast forward and I blew past his estimate too. As a result, I am going to concentrate on putting parts back on that I have accumulated/cleaned/rebuilt over the last 18 months.
Old 09-17-2013, 11:51 PM   #70
BLOWN73
just wait to you get to the part of the build that takes tons of time but doesnt look like you got a lot done, then when your friends come by they look at you and say it took you how long to do what?? LOL but its all worth it when your crusing down the road and the young and old throw a thumbs up.
Old 09-18-2013, 08:02 AM   #71
67cheby
67cheby
67cheby's Avatar
Looking beautiful, love the color !
67cheby is offline   Reply With Quote
Old 09-30-2013, 12:54 AM   #72
jbristo67
resident oilfield trash
jbristo67's Avatar
In
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 10-09-2013, 01:23 AM   #73
Valhalla
Valhalla's Avatar
Nice Love the color scheme I may need your bro shop to do the underneath of my cab and bed.
Can he color match paint ?
My build thread for Project TiC TaC/Jazzmin Oh Yeahhh
Cheap work is never good and good work is never cheap. Lesson = learn to do it all the right way on your own.
SqueegeeMan
Valhalla is offline   Reply With Quote
Old 10-09-2013, 02:34 AM   #74
Devillusion
Devillusion's Avatar
Inspiring progress.....just brought mine home the other day. Can't wait.
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s
1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater
1963 C10 reg cab long box
1970 Chevelle
1968 Biscayne 2dr post
"...there is no excuse for what I am about to do, but dangit....it's gonna be fun!"
Devillusion is offline   Reply With Quote
Old 10-15-2013, 12:29 AM   #75
gclark1
gclark1's Avatar
Valhalla - Space Age auto paint has a product that allows you to tint the material whatever color you want. From there, it is just a matter of spraying it.
I really appreciate the comments guys. My progress is still coming along - considering I am a one man band in my garage at home. I have been putting on some misc parts and doing some sand and buff and it is coming out really nice. I got the doors installed and then just had to take them off and cut the inside jambs (even where the hinges mount) with 2000 paper and then hit them with the wheel too. This is getting out of control, but it is coming out better than I had hoped.
