Old 01-25-2013, 02:28 PM   #51
nate_g_2003
nate_g_2003's Avatar
Re: She is back.
Search Edelbrock carb issues.
Lots of "out of the box" problems.
Float too high.
Won't take any more that 5.5psi.
So a stock fuel pump that puts out 6-7 psi will need to be regulated down.
Just a thought.
I assume you have the correct gas cap?
Yes, if you have an Edelbrock, a fuel pressure regulator is a great investment, even with a stock-style fuel pump.
-Nathan-
1972 GMC K2500 Suburban "The Project"
2013 GMC Sierra 1500 SLT Z71 "The Daily Driver"
2005 Ford F150 Lariat SCrew 2WD "The Daily Driver" SOLD
1995 GMC Sierra C1500 SLE "The Daily Driver"SOLD
2003 Ford Ranger Edge 2DSC 2WD Flareside "The Daily Driver/Project"SOLD
nate_g_2003 is offline   Reply With Quote
Old 01-25-2013, 04:13 PM   #52
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: She is back.
http://www.summitracing.com/parts/EDL-1727
Keith
Convert to disc brakes.
Old 01-26-2013, 11:02 AM   #53
lolife99
lolife99's Avatar
Re: She is back.
Any updates?
Keith
Old 01-26-2013, 11:16 AM   #54
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: She is back.
No updates from the shop yet.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 01-26-2013, 08:55 PM   #55
AzDon
AzDon's Avatar
Re: She is back.
The metal fuel line has a jumper hose in the frame inboard of your third door and is an excellent place to plumb in a marine spin-on fuel filter ( available from West Marine or other online marine sources). This hose is bent in a "U" just like the jumper hose coming into the fuel pump, so check both of these to make sure they arent flattening out and sucking shut and that neither are leaking air. Any filtering should be done BEFORE the fuel pump! If you have a filter after the pump get clogged, it will shut down the flow from the pump...The 62 pickup I built for my son exhibited the same symptoms and what had happened there was....the truck had been inactive for several years and the fuel flow worked fine until our highly-solvent modern fuels loosened up the leftover crap in the lines turning it into a clogging goo, which I had to blow out with compressed air. Fuel hoses can also form annuerisms (a blister or flap inside) as they age....
As for ignition, I'll assume that you are using a points distributor, OR if you've switched to HEI, that you have replaced the resistance wire from the ignition switch with one that has no resistance. (HEI won't work without the full twelve volts) A common intermittant ignition problem with a points setup is the coil often fails intermittantly (usually when it warms up and you're a good distance from home) Don't ask me why, but if you remove the coil and shake it next to your ear and hear the oil sloshing inside, it's usually shot! There are other things to look for inside a distributor after these basics are covered!
Good Luck to you!
AzDon is offline   Reply With Quote
Old 01-27-2013, 02:24 AM   #56
thelonerife
thelonerife's Avatar
Re: She is back.
Good Luck to you!
Very good advice...
thelonerife is offline   Reply With Quote
Old 01-28-2013, 04:17 PM   #57
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: She is back.
The shop called and said they put 5 gallons of gas in it and it is running fine. They did not do a thing 3!@&^&^%%@! I just ordered an Eldebrock fuel pump and will go from there since they pump at 6 psi max. If my head was not already shaved I would be pulling my hair out for sure.
Old 01-28-2013, 04:25 PM   #58
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: She is back.
did you tell them to drive it and put some miles on it to make sure it runs ok
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 01-28-2013, 04:32 PM   #59
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: She is back.
I am going to pick it up this afternoon and put the new fuel pump on when it gets here in a couple of days. I am not sure how much they drove it. It does run fine at times. I have not been too pleased with the shop. It took them a week to get this far.
Old 01-28-2013, 04:41 PM   #60
Ol Blue K20
Re: She is back.
Well I hope all goes well, Keep us posted
Dale
Old 01-28-2013, 07:07 PM   #61
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: She is back.
I went to pick it up and determined they did not drive it very far. I am beginning to wonder if there isn't a problem with the tank. The owner of the shop is supposed to drive it more tomorrow.
Old 01-28-2013, 08:16 PM   #62
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: She is back.
Hopefully he can get it to fail while he's driving it.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-28-2013, 08:54 PM   #63
Ol Blue K20
Re: She is back.
I hate intermittent problems, can't diagnois unless it acts up. Keep us posted, I for one am curious.
Dale
Old 01-28-2013, 08:58 PM   #64
lolife99
lolife99's Avatar
Re: She is back.
Run it off of a gas can.
That will tell you if it's the tank of not.
Keith
Old 01-28-2013, 09:04 PM   #65
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: She is back.
It has always ran fine off the gas can. It is a FUELCELLGUY tank but I don't know muh about it really.
Old 01-28-2013, 09:10 PM   #66
lolife99
lolife99's Avatar
Re: She is back.
Did you talk to fuel cell guy?
Keith
Old 01-28-2013, 10:51 PM   #67
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: She is back.
I am thinking of giving him a call tomorrow.
Old 01-29-2013, 12:06 PM   #68
Ol Blue K20
Re: She is back.
Is it foam filled, like the racing ones?
Dale
Old 01-29-2013, 01:54 PM   #69
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: She is back.
Just got a call from the shop that the alternator is bad. It is a rebuilt with no miles from Autozone so anything is possible. I am going to exchange it and swap it out my self tonight and hopefully they can find the problem tomorrow.
Old 01-29-2013, 07:34 PM   #70
Mayo
Cool Truck
Mayo's Avatar
Re: She is back.
I accidentally clicked on the burb section but that is one sweet ride!
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline   Reply With Quote
Old 01-29-2013, 09:55 PM   #71
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: She is back.
Thanks Mayo.
I rushed over to the shop after they closed and took the alternator off and took it back to Auto Zone and lucked out. I got a cool young kid who knew what he was doing. He tested the alternator and it tested fine but they can not check volts and according to the shop it was not right so he swapped it out with no questions. I upgraded from a 63 amp to a 96 amp for $30 with my warranty. I took it back to the shop and put it on then we tested it and bam 14 volts. The shop thinks this may be why it was dying and back firing. I left it with them and asked him to drive it some more tomorrow. He said he would but he didn't want to because it is going to make him want it more. It was cool to hear that from a guy who has some very nice expensive rides in his shop.
Old 01-29-2013, 09:59 PM   #72
Dieselwrencher
Re: She is back.
That is pretty cool!
Ryan
Old 01-29-2013, 10:10 PM   #73
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: She is back.
I forgot to mention the youngster even took the sepentine pulley off with an impact and put the v-belt pulley from the old one on for me.
Old 01-30-2013, 07:36 PM   #74
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: She is back.
I picked it up today and drove here home and it ran fine. The shop adjust the timing a little and adjusted the carb a little as well. I am going to take it to the tranny shop because the tranny is slipping. I also need to change to a 3.73 rear end to go with the overdrive. The only other known problem at this time is the tire rubbing issue so I am going to order a set of spacers for the rear.
Old 01-30-2013, 08:00 PM   #75
Ol Blue K20
Re: She is back.
I hope it's fixed, Keeping my fingers crossed
Dale
