Old 07-17-2013, 12:42 PM   #51
brimc
brimc's Avatar
Re: 86 Silverado K20 12V CUMMINS Build
Originally Posted by mknittle View Post
Pretty cool build I am a big fan of the Cummins swaps.
Reading through yours makes me want to get restarted on mine.
Ya I agree. Reading all the great threads helps get motivated.
Originally Posted by legendman View Post
Engine crossmember looks good, didn't happen to make an extra one? I need to fab up one myself.
haha, no I didn't make an extra one. But really it was fairly simple.
BRIAN
1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater.
My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509
brimc is offline   Reply With Quote
Old 07-17-2013, 04:21 PM   #52
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work on your engine cross member! That's how I decided to do the one in my 76. We'll be getting our loaner engine back in a few weeks and then it's going in the 76. Keep up the great work!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 07-18-2013, 10:44 AM   #53
brimc
brimc's Avatar
Thanks for the feedback on the xmember.
I hope you are able to start working on your 76 again. I really enjoyed following your thread on that one.
Hopefully this heat wave crap will let up and I can get more work done in the garage. I really can't wait to get this truck into a roller and get the engine fired up!
BRIAN
Old 07-18-2013, 05:21 PM   #54
legendman
legendman's Avatar
x2 Too hot to do much, so I have been hunting down parts
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 07-20-2013, 09:11 AM   #55
brimc
brimc's Avatar
Looks like the weather has cooled down some for this weekend. Hopefully means more work down on all our trucks!
I picked up some Grade 8 hardware at bolts plus for my engine cross member.
Question for you all, I have allot of new hardware to buy for this project obviously. Is this a reasonable price I paid or is there some better place to pick up large orders?
BRIAN
Old 07-20-2013, 01:52 PM   #56
6BT 56
6BT 56's Avatar
Have you tried Brafasco ? Im not sure how the prices campare
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 07-20-2013, 07:59 PM   #57
mknittle
mknittle's Avatar
I get them at tractor supply for about $3.00 a pound. Grade 5 for $2.30 a pound.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 07-21-2013, 12:36 AM   #58
meatwagon83
meatwagon83's Avatar
thats a good lookin helper youve got there!!
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 07-22-2013, 07:23 PM   #59
Dieselwrencher
Usually I go into a local tractor supply store and buy about $40-$50 worth and when it gets low, I go back. Hardware isn't cheap when you're going grade 8 and get 10lbs or more at a time.
Ryan
Old 07-22-2013, 08:21 PM   #60
brimc
brimc's Avatar
Thanks everyone for the reply's on the bolts. I have bought some hardware at TSC stores and they didn't sell grade 8 by the pound. Only in special individual bags. That was how I bought the new 9/16 bolts for my new springs. Very expensive. They do sell grade 5 by the pound though. I'll keep looking around here, but for now the Bolts plus+ place was alright.
BRIAN
Old 07-22-2013, 08:28 PM   #61
brimc
brimc's Avatar
So now that I got my pictures up-loaded, time for an update from the past several days! I got a good 2 coats of POR15 on my new engine cross member after sanding it all down with a 60 grit flap disk.
I think it turned out alright. Next time I would rather use a good saw and angle finder to make perfect cuts. The seams and welds would look better, even though it is under the truck you can see it real good behind the tire in the wheel well.
BRIAN
Old 07-22-2013, 08:53 PM   #62
brimc
brimc's Avatar
So tonight I got the cross member all bolted in place with the 20 new grade 8 bolts. Used some blue thread locker and torque wrenched them down. This thing is super solid now!
I also bolted the front springs onto the frame for the final time.
NOTE: The stock spring shackles are temporary. I will make a new set at least 1" longer and will be 1/2" wider and made out of 3/8" material. I may wait until I see the ride height before I do though.
So next I started to install the front Axel.
I use the engine hoist for just about everything.
Just have to keep fishing it into place by unhooking and hooking back up again.
Then just lift it up into place. Line up one side first then the other.
Then just draw it up tight against both pins.
I pulled it up tight until the frame started to lift off the saw horse at the front. Then started bolting on the new U bolts.
I lined it up best I could and just did about half torque for now until I get all the weight on the springs. Then I installed a second nut to make the spot to cut off the excess bolts as they are too long for me.
All 8 cut off and sanded down.
Now just a few pics of the cross member and front Axel installed for I hope the last time!
Now I can install the engine for the last time, get the hubs, brakes and tires on and I have myself a roller real soon. ( I hope ) Can't wait to fire this thing up!!
BRIAN
Old 07-23-2013, 04:55 PM   #63
Dieselwrencher
It looks really nice!
Ryan
Old 07-23-2013, 05:02 PM   #64
mknittle
mknittle's Avatar
Now I am starting to get excited!
Mark
My GMC build.
Old 07-23-2013, 05:51 PM   #65
gerfunken
gerfunken's Avatar
well, it sure is a lot prettier than mine is at this point.
-Scott
1972 Chevy K20
Picture Gallery
Build Thread
1930 Chevy AD
Picture Gallery
1929 Ford Model-A
Picture Gallery
1975 Triumph TR-6
Picture Gallery
Old 07-23-2013, 07:12 PM   #66
brimc
brimc's Avatar
Haha, Thanks Guys! It's slowly coming together. Just keep plugging away at alittle at a time.
BRIAN
Old 07-31-2013, 06:54 PM   #67
brimc
brimc's Avatar
Wow, time for an update....
I got the rear 14 bolt put together just enough to get the wheels back on it. I need to turn the drums but have decided to hold off because they will just rust up. I'll do it after this winter when the project will be closer to finished.
Just need to seal the axle shafts and diff cover, then fill. Oh ya and run the new lines.
BRIAN
Old 07-31-2013, 06:59 PM   #68
brimc
brimc's Avatar
Then I installed the engine for the last time ( I hope ) into the frame. Checked final clearance to the front balancer and oil pan to crossmembers. I think they turned out alright for my first time !
BRIAN
Old 07-31-2013, 07:05 PM   #69
brimc
brimc's Avatar
I also got the injection lines painted up as well as the oem fuel filter canister.
The next few weeks I hope to have it on 4 wheels and fuel system finished, pickup all the filters and oil etc. then fire this thing up for the first time in almost a year.
BRIAN
Old 08-01-2013, 04:06 PM   #70
Dieselwrencher
Looking good man! I don't see one and I don't remember if you said anything about one, but do you plan on installing a steering box brace on the frame? If not, I'd really consider it as these frames love to crack there and the added weight with the big tires will really progress that wek spot. On your fuel filter housing, those are a nice piece but really suck to replace the filter in a dodge.
Ryan
Old 08-01-2013, 09:14 PM   #71
brimc
brimc's Avatar
Thanks for the compliment. I too think it is starting to look good. It is nice to get most of the dirty work finished and start putting things back together and start taking shape. I know about and have thought about the steering brace several times. I checked this area when I bought it and when I removed the box and there is no signs of any stress or cracking as of yet. This truck was run kinda hard with 35's for awhile off-road before I got it. I might just leave it be and call it a test to see how it does. This project has been a learning curve for all the pro's and con's for when I build the next one. This one might just be a training project
As for the filter housing, I like them better than the older spin on's. I had no problem changing on the Dodge. Should be just about the same in the Chev. Might not be there long as I might "upgrade" the hole low pressure side.
BRIAN
Old 08-03-2013, 11:02 PM   #72
Mattman2010
Mattman2010's Avatar
I would get the steering brace. It's only a half ton frame and a ton of them get cracked just driving around the steets. The extra weight of the drive train is going to add a little more stress to the steering. I would get one and install it and you won't have to worry about it. If it does crack your going to have to drill the ends of the cracks, grind the cracks out some and then weld it all back up grind it smooth and have to install a brace anyway.
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 08-17-2013, 02:50 PM   #73
brimc
brimc's Avatar
Well time for an update. Been longer than I thought. Between having some summer holidays the first week of August and building us a 10X10 "Garden Shed" there hasn't been as much time on the truck as I would like. Nothing fancy, just some extra space to clear up much needed space in the main Garage!
Still needs a bit of trim work and paint in the next few weeks, but turned out good.
BRIAN
Old 08-17-2013, 02:55 PM   #74
brimc
brimc's Avatar
Been shopping on Kijiji as I always do. Got a line on several things and found a brand new front tint windshield. Going to go get that one this week. Also I found this, kijiji.ca/c-cars-vehicles-auto-parts-tires-transmission-drive-train-77-chev-dana-60-front-axle. with 4.10's. I wish I was ready to start stocking parts for my next project, but have to pass on this. Just thought I'd share.
BRIAN
Old 08-17-2013, 03:03 PM   #75
brimc
brimc's Avatar
So the truck is now rolling on it's own 4 wheels. 4 brand new ball joints and new high lift steering arm installed.
Just stuck the old rims and hubs/breaks on for now until I get it closer to finished. Pushed it outside to "Bake" in the sun and take a few pics outside.
It is getting closer. Next will be fuel tank and plumbing then repair and install cab mounts.
BRIAN
