Old 12-02-2013, 06:33 PM   #51
retdet1
Re: 1957 Chevy Truck
Heater core will be on my list of things to do over the winter. Thanks for the info.
retdet1 is offline   Reply With Quote
Old 12-02-2013, 09:49 PM   #52
57chevyman
57chevyman's Avatar
no problem
Frank
1957 Chevy 3100
2000 Silverado z71 SOLD
2012 Ram 1500 Quad Cab
1992 International 4700
57chevyman is offline   Reply With Quote
Old 12-02-2013, 11:49 PM   #53
_Ogre
_Ogre's Avatar
Originally Posted by 57chevyman View Post
correct, the headlight switch doesn't turn on the interior light like its supposed to , but it does turn on the headlights taillights and dash lights, so I didn't want to mess with it... the toggle switch was easy to add after I already had the door switches done.
the headlight switch would most likely work for the dome light if I attach the dome light wire... is it difficult to do?
chevyman the dome light has a 12+ hot wire to the light and the headlight switch grounds (12v-) the circuit.
the picture is a 55 chevy sedan headlight switch, it wires the same as the trucks of that era.
the left wire marked ''white-ground'' is the dome light ground wire
if you look at this picture the switch is upside down the connector is on the right
you can see the copper strip that acts as the switch and grounds it to the case
shop air compressor timer
Old 01-10-2014, 04:46 PM   #54
57chevyman
57chevyman's Avatar
I installed a coolant overflow tank today. no more coffee cup to catch the overflow!
Frank
1957 Chevy 3100
Old 01-10-2014, 05:06 PM   #55
OrrieG
OrrieG's Avatar
Looks good, another fan of Simpson connectors!
OrrieG is offline   Reply With Quote
Old 01-10-2014, 05:55 PM   #56
57chevyman
57chevyman's Avatar
Yeah, I gotta trim the brackets and paint them black, but so far so good
Frank
1957 Chevy 3100
Old 01-10-2014, 07:21 PM   #57
Kim57
Kim57's Avatar
That's nice.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 01-10-2014, 07:45 PM   #58
Dan in Pasadena
Dan in Pasadena's Avatar
Hey Frank, that overflow tank looks VERY familiar
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 01-10-2014, 07:48 PM   #59
Dan in Pasadena
Even our placement choice is almost identical. I like your radio choice too. I've been planning to buy one of those but I didn't know it had blue digital. I'd prefer green for my truck, naturally.
When you say you used speakers in the original location, but you used two I'm not really understanding where you put them. Are they very near each other in the middle?
Old 01-10-2014, 07:59 PM   #60
57chevyman
57chevyman's Avatar
I did some research, and I think the retrosound radio that I got is made better than the custom autosound... I read that the green background ( not green numbers) on the autosound is a little too much and its not dimmable...... retrosound may have a new model where you can choose what color you want the display to be.
the two speakers were already in the truck above the rearview mirror..... its made by autosound specifically to fit in that spot. they sound good, but no bass at all. I put a powered kenwood subwoofer under the seat and the stearo system sounds great now
Frank
1957 Chevy 3100
Old 01-10-2014, 08:32 PM   #61
Dan in Pasadena
Thanks. Are the two speakers in the old style sheet metal housings?
Old 01-10-2014, 08:54 PM   #62
57chevyman
57chevyman's Avatar
Yeah it's all one assembly with two speakers
Frank
1957 Chevy 3100
Old 01-16-2014, 11:04 AM   #63
57chevyman
57chevyman's Avatar
Frank
1957 Chevy 3100
Old 01-16-2014, 11:12 AM   #64
57chevyman
57chevyman's Avatar
is my rear suspension a 4 link?
Frank
1957 Chevy 3100
Old 01-16-2014, 11:45 AM   #65
Kim57
Kim57's Avatar
Those look like some ones attempt at traction bars. I haven't seen any 4-links with leaf springs.
Kim
My build thread
Old 01-16-2014, 12:18 PM   #66
57chevyman
57chevyman's Avatar
I haven't seen it with leaf springs either. Guess I have a unique setup. There's also a rod that attaches to the read end, you can see in one of the pics
Frank
1957 Chevy 3100
Old 01-16-2014, 12:39 PM   #67
msaintg
msaintg's Avatar
both of those bars are fighting against the leaf springs. You may not notice any problems on a 2x4 vehicle, but they will cause a lot of problems (especially the one going across) on a 4x4 vehicle that wants and needs articulation of the suspension. Basically, the bars want to move in an arch and the leaf springs only want to move up and down. (yes the leaf springs will move the axle slightly forward, but will still bind with the bar because the pivit points are different.) I guess it was set up that way to reduce axle wrap because of the tall blocks.
msaintg is offline   Reply With Quote
Old 01-16-2014, 01:14 PM   #68
57chevyman
57chevyman's Avatar
The suspension is very stiff. On a smooth road it's fine lol
Frank
1957 Chevy 3100
Old 03-05-2014, 07:17 PM   #69
57chevyman
57chevyman's Avatar
I love getting deliveries for the old truck...got some nice goodies...
Frank
1957 Chevy 3100
Old 03-05-2014, 08:37 PM   #70
Kim57
Kim57's Avatar
Shiny new parts. Very nice.
Kim
My build thread
Old 03-05-2014, 08:56 PM   #71
OrrieG
OrrieG's Avatar
4" is usually the maximum recommend lift block, any higher can roll over. But since I assume it is not subjected to the stressed like put my truck thru off-road (4" lift on the back) it is not an issue. That bar also negates the shocks doing anything useful, I would suspect it rides "different" with the read essentially almost solid axle and independent front??? It has obviously worked ok for 10 years, but you might want to look at some rearced rear springs to get rid of the bars and lift blocks.
Old 03-05-2014, 09:20 PM   #72
57chevyman
57chevyman's Avatar
It's a 5" lift block. It works for cruising around the neighborhood.
I few things on my list are
Upgrade the brakes to a dual MC
Find a 55-66 bed
Relocate gas tank ?
Frank
1957 Chevy 3100
Old 03-06-2014, 10:44 AM   #73
LordDevlin
LordDevlin's Avatar
nice truck...
those side window visor things kinda jumped out at me. I drive my truck in the rain and these might come in handy when I want to still keep the windows down as I dont have ac. They might look good on my truck painted the same as the body.
Where did you get them? Or were they already on the truck?
Elliot
1959 Chevy Apache SWB Fleetside - 350 GM crate with mild cam, 700r4, 4.10 rear
LordDevlin is offline   Reply With Quote
Old 03-06-2014, 11:58 AM   #74
57chevyman
57chevyman's Avatar
Thanks! Those visors were on the truck when I bought it. They're available in parts catalogs for around $30 for the pair
Frank
1957 Chevy 3100
Old 03-06-2014, 12:15 PM   #75
rambler
MOVE OVER
rambler's Avatar
just saw this post.. love the truck !
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
1957 chevy pu, 1957 stepside build
