Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 03-26-2014, 07:12 PM   #51
East Tex
Re: Project 6 Point Oh
Name:  Trandfer case 2.jpg
My 1972 K5 6.0 LTR 4L60 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=622068
East Tex is offline   Reply With Quote
Old 04-01-2014, 10:13 AM   #52
aggie91
I'm just glad to be here!
aggie91's Avatar
Looks like those guys have done some great work. Who did your powder coating?
I grew up in Tyler, moved away in '96 and got back to Longview in 2002. My sister still lives in Tyler.
For your 6.0, are you staying with the EFI or switching it to a carb?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 04-01-2014, 11:25 AM   #53
East Tex
It's a place in Flint, Tx called Ace Powder coating. They turn out some great looking stuff. I'm thinking of letting them powder coat the core support, frame and axle housings (and other misc stuff) instead of POR15. Not sure yet on that. I'm going fuel injection. I don't think that I'd ever put a carb on an LS motor.
Old 04-01-2014, 07:16 PM   #54
jim harig
jim harig's Avatar
Originally Posted by East Tex View Post
Attachment 1232421
Call me crazy, but I'm not putting a hard top back on this ride. If I do anything, I might put a soft top on it later. If there is a cloud in the sky, this truck won't leave my shop.
I did the same thing. Don't plan on ever putting the hard top on. I should sell it. I'm planning on getting a bikini top made for mine someday. In case I need some shade.
jim harig is offline   Reply With Quote
Old 04-03-2014, 03:54 PM   #55
East Tex
I sold my double wall top a few days ago. It was in decent shape, so I had a hard time convincing myself to sell it. But, now I don't have to deal with storing it and taking it on and off. Hopefully I won't regret that decision. I'm thinking about a black Soft Topper but your idea of a bikini top has me thinking about getting that instead. Oh well, I have plenty of time to figure it out.
Old 04-26-2014, 10:02 PM   #56
East Tex
NP205 transfer case ready to go!
Old 04-26-2014, 10:05 PM   #57
East Tex
4L60 rebuilt and ready.
Old 04-26-2014, 10:09 PM   #58
East Tex
Getting ready to mock everything up. Before powder coating the frame.
Old 04-27-2014, 11:17 AM   #59
East Tex
I'm going to replace the four bolts that hold the transfer case to the transmission. Only two of the bolts, supplied by Advance Adapters, fit. One of these days I want to get a big bolt bin, full of zinc plated grade 8 bolts, nuts, flat washers and lock washers. Then I wont be running to the hardware store buying a hand full at a time.
Old 04-27-2014, 11:23 AM   #60
East Tex
Time to pull out the factory cross member so I can install the Pacific Fabrication cross member. It's made to swap LS motors in these old 4x4s.
Old 04-27-2014, 11:26 AM   #61
East Tex
Old 04-27-2014, 11:27 AM   #62
East Tex
Old 04-27-2014, 11:33 AM   #63
East Tex
You can see the passenger side is notched out so it doesn't interfere with the brake lines, that run along the inside of the frame rail.
Old 04-27-2014, 11:39 AM   #64
East Tex
I pulled the brake lines off to make the installation of the cross member easier. Plus I've got new stainless brake lines ordered from Inline Tube, so they would have to come off in order to check the fit of the new brake lines anyway. (picture was taken before I removed the brake lines)
Old 04-27-2014, 11:48 AM   #65
East Tex
The driver's side is not notched out. There's a brake line that runs along the inside of the frame on that side too, so I'm not sure why it's not notched out like the other side. I'll either notch it out myself or do some custom brake lines on that side.
Old 04-27-2014, 02:03 PM   #66
jaros44sr
jaros44sr's Avatar
Nice work so far, is it possible to swap crossmember right to left, so the notch will clear brake lines. Just a thought.....
Never mind, miss read your post
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 04-27-2014, 09:06 PM   #67
East Tex
How can this be $95.00 worth of stainless and zinc plated nuts and bolts?
Crazy.
Old 04-27-2014, 09:07 PM   #68
East Tex
Thank you JAROS44SR. It is slow going, but I'm having fun.
Old 04-27-2014, 09:12 PM   #69
East Tex
Name:  Radiator support.jpg
Name:  hood latch.jpg
Got a few things back from the powder coater.
Old 04-27-2014, 09:17 PM   #70
East Tex
Name:  brake bushings.jpg
I need to reassemble the brake pedal assembly. But I can't find these bushings
in any catalogue.
Old 04-27-2014, 09:21 PM   #71
East Tex
I need to strip the harness and the accessories off the motor.
Old 04-27-2014, 09:28 PM   #72
East Tex
Old 04-27-2014, 09:36 PM   #73
East Tex
Old 04-27-2014, 09:40 PM   #74
East Tex
Looks like the water pump was leaking. Is everyone running Dexcool back in these LS motors? Or good Ol green antifreeze?
Old 04-27-2014, 09:49 PM   #75
East Tex
Name:  removing plugs.jpg
I just realized that it has been over a year since this motor has been ran.
It has been sitting on a motor stand in my shop and I haven't turned it over
by hand or anything.And I probably won't fire it up for a few more months. So, I pulled all the spark plugs out and squirted motor oil
in each cylinder, cleaned the plugs, and put them back in.
