Old 12-08-2014, 03:14 PM   #51
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: K30 Downgrade to Cummins Project
Wow, that's a bad deal for some one and good deal for you. Do you plan to use the dmax in anything later?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-08-2014, 05:43 PM   #52
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Ryan, not sure how much of The engine is good. The fire got pretty hot on top of engine also the fire dept sprayed water in the iintake . I' d like to find a rear or right hit Silverado to use these good parts on.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 12-11-2014, 10:41 AM   #53
Vintage Windmills
Vintage 4x4s
Working on making an engine mounting plate for an engine stand I should build. Can one of you guys tell me what the circled dimension is below for these 6bt's? My bellhousing is still on the engine and I can't measure hole to hole spacing on these.
Old 12-11-2014, 05:33 PM   #54
Dieselwrencher
I can measure that for you tomorrow as I have a couple off engines. I also have a couple of blocks sitting here I could measure off of. Ryanroo might have these measurements saved though.
Ryan
Old 12-12-2014, 01:02 AM   #55
ryanroo
ryanroo's Avatar
Sorry i didnt get back to you Jud, i forgot about your message in the chaos of the holiday. ill try to shoot a file to you over the weekend. my measurements are good enough for an engine plate but not super exact.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 12-12-2014, 10:57 AM   #56
Vintage Windmills
Vintage 4x4s
No worries, if I could just get the one dimension ASAP I can get this plate in with a batch of stuff going to the lasercutter today. Otherwise I will leave them out and drill them later.
Old 12-12-2014, 08:35 PM   #57
Vintage Windmills
Vintage 4x4s
Did you guys hear the news on the cummins 5.0? Looks like GM missed the boat again. http://cumminsengines.com/pickup-truck
Old 12-13-2014, 10:05 PM   #58
jbclassix
Junk Yartist
jbclassix's Avatar
Yep... Nissan will be running it and Toyota will be picking it up a year or two later. I am hoping they do a Cummins Sequoia.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 12-14-2014, 07:33 PM   #59
patdaly
I'm more excited that Nissan is serious about the little 4 cyl. Cummins for the intermediate truck.
http://www.greencarcongress.com/2014...-frontier.html
https://www.youtube.com/watch?v=yzHmnvWAQss
patdaly is offline   Reply With Quote
Old 12-15-2014, 02:51 AM   #60
Vintage Windmills
Vintage 4x4s
502 left yesterday
cummins and driveline pallet wheeled in the shop
Old 12-15-2014, 03:05 AM   #61
Dieselwrencher
Those things sure eat up the storage real estate, don't they?
Ryan
Old 12-15-2014, 10:04 AM   #62
brimc
brimc's Avatar
That's a real nice looking pallet Wish I could find a pallet like that.
I also like what you've done with the core support. Are you changing the front fascia to the newer style?
BRIAN
1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater.
My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509
brimc is offline   Reply With Quote
Old 12-28-2014, 01:47 AM   #63
Vintage Windmills
Vintage 4x4s
Yep, I need to get to rebuilding whats on it! It came out of the crappiest body truck I've ever had on my property!
Core support was just hacked apart to get the engine out and save the front geometry so I can work on mocking up an intercooler. The core support was jacked at the top and I've got a super nice one to replace it with at some point. Keeping the 86 front end, I think its better looking in my opinion.
Old 12-28-2014, 01:56 AM   #64
Vintage Windmills
Vintage 4x4s
Been working on a engine stand. Modeled it up in solidworks since I don't want to spend any more time than necessary on getting it to work like I want. It also makes analyzing the strength a snap.
I cut all the steel yesterday, just need to weld it together. Thanks to Ryan roo for the inspiration to do a heavy duty stand with an adapter plate. Only thing I need to decide now is if I want to direct couple the gearbox, the downside is it will add a foot to the overall length. Alternative is to do a chain drive but thats more work and not as clean. Here are both versions. What do you guys think? Shop space is at a premium for me.
Old 12-28-2014, 11:32 AM   #65
ryanroo
ryanroo's Avatar
are you putting casters on the stand? i would make sure the front side of the stand will work with your engine crane. mine is a little bit of a pain. i have plans to build my own engine crane to work with and stand proud next to frankenstand.
i would direct drive the box. putting a sprocket on it will put a radial load on the shafts, and add a lot of slop to the system. unless it is perfectly balanced, which it cant be as you add or remove parts, it will overcenter and jerk. mine still does it as it takes the lash out of the connections and worm gear, but it is very minor. also, i am curious about the adapter plate to shaft connection. it seems like the bolt pattern is a little small.
what is the material being used for everything? and the spacing on the separated column? it looks really wide. i am interested in the simulated load readings. we never ran mine through the EFA program. but the real world test has proven the design..
as far as shop space, it will eat tons of it. mine is like having a VW in the garage. but it is pretty darn cool! also, the most important question is, what color will it be painted? Pink?
looking forward to more!
72 K20 12v build
Old 12-28-2014, 02:20 PM   #66
Vintage Windmills
Vintage 4x4s
Good point on the backlash. I was going to make this thing collapsible but with my tendency for having stuff sit around , this will probably always have a 350 or 6bt on it. Bolt pattern is 4 inch so its going to put about 4000 lbs tension at most on the top bolts, not much for 1/2 bolts going into 5/8 thick material. I think my engine is bigger than life, its not scaled yet. I have it 40 inches from top of valve cover to bottom of oil pa. 7Inch spacing between uprights could be reduced, 2.5 Square tubing on those, 3inch on Horizontal parts. Unit will get casters but my engine hoist is made by john Deere so no worries there
Does anyone use aandroid for posting on this forum? Setup auto correct is insane to use, how do I turn?off? settings show everything is off andI am about ready to smash something. . this post took 10 minutes extra to type up because of flipping auto corr. t
Old 12-28-2014, 05:06 PM   #67
ryanroo
ryanroo's Avatar
the JD hoist is a more versatile unit that mine! i doubt the bolts will ever cause issue, i was more thinking the joint where the plate with the bolt holes joins the shaft. if the plate is small the leverage is increased on that joint. diameter of the shaft will be the factor there though so i guess that doesnt matter. the space between the members of the column does seem wide. mine is 3" tube and a 3" space between. it is hell for stout in that area. i would guess you could shorten that a bit and save some overall length.
i considered doing mine modular so i could unbolt the column and attach it to the floor, but i decided like you said, i have enough junk, and the stand is cool enough, it will have something hanging off of it most of the time.
i was just telling Ryan earlier that i would have busted the crap out of my phone a long time ago if i was 5 years younger. i only use them for forum posting if i am away from home, but just texting it corrects so many things stupidly it amazes me.
72 K20 12v build
Old 12-28-2014, 06:48 PM   #68
Vintage Windmills
Vintage 4x4s
Yep, I think the plate to "axle" connection needs some small gussets. The plate is 5/8 or 3/4 thick and will have a hole in it but gussets are just cheap insurance.
As for the color, I like your idea of getting creative! Maybe not pink, but I may just spray bomb it graffiti style with all my almost empty cans
Old 12-29-2014, 03:09 AM   #69
Dieselwrencher
I'm on an android type device right now and I'm about to off it! I like the gear box direct idea.
Ryan
Old 12-29-2014, 11:05 AM   #70
Vintage Windmills
Vintage 4x4s
A guy is tempted to get an iphone at times isn't he!
Hoping to get it tacked together today and figure out the ball bearings on the big shaft
Old 01-02-2015, 12:39 PM   #71
Vintage Windmills
Vintage 4x4s
Alright, I scaled the engine, it was way too big in the first concept above.
Below is a shot after doing the engineering on the stand. I just did it with the old fashioned stress and deflection equations (statics and mechanics of materials) since I trust the tried equations more than my ability to set up solidworks simulations with assemblies at this point. I've got parts down but assemblies take more. Also, I don't have fancy geometry, perfect to keep my math skills honed. I put a screenshot of some of the 6 page mathcad worksheet I used to to the computations. I'm lucky to have access to mathcad since it makes iteration a snap, but all this could be done with a simple calculator and paper.
I'm glad I did the math on the main shaft that supports the engine. The 1.875 heavy DOM I wanted to use would have had 80,000 psi in it! Stepping up to a 2.5" Od with pretty much any ID gets me below 36,000 so I don't need to worry.
Better to take a few hours doing the math than be rewelding and adding material in the shop. Or worry about it coming down!
Old 01-02-2015, 09:36 PM   #72
Vintage Windmills
Vintage 4x4s
Called the trans shop about the getrag. Got an estimate, told them nothing is wrong with it, just normal wear and as long as its out, go through it. They said 750 to 1000, what do you guys think of that price? Wondering if I should tackle it myself or if thats a good price....
Old 01-02-2015, 10:08 PM   #73
Dieselwrencher
It just depends what all they have to put in it. I haven't rebuilt a getrag, but I know ghuys that have rebuilt them in an afternoon. I don't think they're any harder than a NV4500. $750-$1000 isn't bad really. Most trans shops charge $1100 on up for a good quality NV4500 rebuild.
Ryan
Old 01-03-2015, 11:15 AM   #74
Vintage Windmills
Vintage 4x4s
Yeah, I didn't think it sounded too bad since that includes parts. Did you have a chance to work up engine parts prices? I'm thinking I'll do the work on engine now with my fancy stand and all but still need parts
Old 01-03-2015, 11:18 AM   #75
Vintage Windmills
Vintage 4x4s
As long as I was cutting steel and welding stuff, I built a forklift for my tractor. This is something I've wanted for awhile. Should allow pretty good visibility and places to hang chains on. Just need to finish up wire feed welding it together (everything is tacked now) and get it painted
