Old 11-27-2014, 09:45 PM   #51
skymangs
skymangs's Avatar
Re: Rico F. - 1954 3600 Long bed S10/LS conversion
Here is the installation on the door weatherstrip. I let it sit overnight to be sure that the trim adhesive has completely adhered.
Pic 3 is routing/crimping AC lines for the vintage system.
I had a little issue with the core support. This is the first build I've used the stock Denso compressor. The lower hose opening on the radiator was interfering with the AC clutch, so I had to move the lower radiator channel higher to clear it. pics 4 and 5 are what I did to get around it.
skymangs is offline   Reply With Quote
Old 11-27-2014, 09:53 PM   #52
skymangs
skymangs's Avatar
Here's how the radiator and fan setup came out. VERY tight. there is about 1" of clearance between the water pump pully and the fan motor. The fan is controlled by the PCM, and comes on at 200 degrees.
Old 11-27-2014, 10:02 PM   #53
skymangs
skymangs's Avatar
Finishing some interior work. 1 piece headliner installed (covered in charcoal material), battery, seat frame, and power locks are installed.
Old 11-27-2014, 10:09 PM   #54
skymangs
skymangs's Avatar
Passenger door glass and vent installed. second pic is how I made the stock inner handles operate the bear claws. I cut the stock rods down, and added a few inches to them, so then you pull them back, the lower the mechanism.
Third pic is the boots I used to run the wires from the dash to the power lock solenoids
Last pic is the driver side vent and window installed
Old 11-27-2014, 10:18 PM   #55
skymangs
skymangs's Avatar
Door panels and window trim installed.
AC condenser and trans cooler installed (the trans cooler is a mid 90's Ford explorer plate style cooler)
Air intake and MAF finished up.
Old 11-27-2014, 10:38 PM   #56
skymangs
skymangs's Avatar
This is how I re-rust repaired spots. It's a mix of Hydrgen Peroxide, White vinegar, and salt. If sprayed on bare metal, you can watch it rust before your eyes. let it dry and re-spray to get the rust darker. Seal it with Pentrol when you've achieved the proper amount of surface rust.
Old 11-27-2014, 10:43 PM   #57
skymangs
skymangs's Avatar
This is the used tailgate I had to work with. I needed to make it match the truck if possible.
the rest are in progress pics
Old 11-27-2014, 10:47 PM   #58
skymangs
skymangs's Avatar
Here is the tailgate finished and mounted up. The dark spots over the bare metal are from the pentrol (still wet).
The last pic is just after the initial test drive. Ran great, lots of power, and smooth as glass!
Old 11-27-2014, 10:52 PM   #59
skymangs
skymangs's Avatar
Exhaust finished up, duals hide nicely just below rear cross-sill height. Front and rear bumpers installed.
Old 11-27-2014, 10:56 PM   #60
skymangs
skymangs's Avatar
Rear fender rust repair.
Old 11-27-2014, 11:02 PM   #61
skymangs
skymangs's Avatar
Caps and trim rings installed. Spare tire carrier modified to handle the HUGE spare (255/60R15)
The last few are the DX oil can I modified to cover the fuel filler neck. I cut the lower inch off the can and flipped it so the lower portion gets captured by the upper half. Then I riveted some latches to the base, and used a holesaw to cut and access hole for the fuel cap.
Old 11-27-2014, 11:08 PM   #62
skymangs
skymangs's Avatar
Here's the oil can installed in the bed. The bed is made of 3/4" roofing grade plywood (bedlined on the underside), and skinned in tongue and groove.
The last two are the buttoned up engine bay. Ready to hit the road!
Old 11-27-2014, 11:11 PM   #63
skymangs
skymangs's Avatar
Here's some finished shots. I'm pretty pleased with it, and so is the owner!
Old 11-27-2014, 11:14 PM   #64
skymangs
skymangs's Avatar
Final few shots. Truck is home now, and the family loves it.
Old 12-22-2014, 09:46 PM   #65
wibas
Hey your truck looks great. What did you use for door panels? Did you do your own seat upholstery?
wibas is offline   Reply With Quote
Old 12-25-2014, 12:07 PM   #66
skymangs
skymangs's Avatar
Door panels and seat are one off custom, built by Ron's Auto Trim in Warsaw MO. Yer nice work for a VERY reasonable price. He kept a template so he can make them any time I need a set.
Speedo finally arrived from Red Line Gaugework, all new electronic guts, original look. Pretty damned nice work if you ask me!
Old 12-26-2014, 08:49 PM   #67
Advanced Design
Advanced Design's Avatar
The gauge does look good. Did they refurbish the original one?
Advanced Design is offline   Reply With Quote
Old 12-30-2014, 07:03 PM   #68
RCbowtie69
RCbowtie69's Avatar
Nice work & looking good.Keep up the good work & keeping these trucks on the road.Keep on Truckin"
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15.
Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e,
RCbowtie69 is offline   Reply With Quote
Old 01-06-2015, 12:07 PM   #69
Uncle Jimi
Uncle Jimi's Avatar
Skymangs, this truck turned out incredible!
I'm wondering about the remote power door locks??? Who do you suggest to get them from? Are the cheap kit's on amazon ok? Or go with something from speedway?
Thanks!!
Uncle Jimi is offline   Reply With Quote
Old 01-11-2015, 11:38 AM   #70
skymangs
skymangs's Avatar
Thanks all. The owner is VERY happy with the truck. It's been in his family as long as he can remember.
Redline cleaned the old gauge face and bezel, but we wanted to keep it matching the other side, so they left the patina. Was damned expensive though.
I buy door lock motors and the remote from ebay. Inexpensive kits work just as well as the high dollar stuff. I think I had $60 in the power locks on this truck.
Old 01-11-2015, 02:31 PM   #71
Advanced Design
Thanks Skymangs...appreciate you sharing your knowledge and experience.
Old 01-11-2015, 06:41 PM   #72
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Very Nice. I like the battery location also
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 01-14-2015, 01:44 PM   #73
tlorber
tlorber's Avatar
Sarge,
Do you have any close up pics of where the wiring harness enters the firewall on this build, and also, any pics of the PCM/TAC module mounted in the interior?
I'm trying to figure out which holes to weld up in the firewall and which to keep.
Much appreciated.
tlorber is offline   Reply With Quote
Old 01-14-2015, 11:24 PM   #74
skymangs
skymangs's Avatar
Thanks guys. Post number 40 and 51 show where the engine harness enters the firewall. The PCM is mounted across the dash support rods behind the speedo and the TAC module is mounted about 6" above the throttle pedal on the firewall brace (sorry, no pics). I really enjoyed this build. Check out my new one "Cecil". Going back a couple decades with a TPI motor.
Old 01-14-2015, 11:25 PM   #75
skymangs
skymangs's Avatar
I weld them all, except the steering column and the left side wiring harness hole.
