Old 08-25-2018, 02:35 PM   #51
1Rusty90
Re: 72 Swb starting from the bottom
Can't wait to see it finished. Keep up the good work.
1Rusty90 is offline   Reply With Quote
Old 08-31-2018, 07:14 PM   #52
J3rm0ff
Got ridetech lower strongarms to help level out the truck. The rear was sitting A lot lower. Now the inside of the fender is sitting on the tires and it has lowered an inch and a quarter or so. Still has a lot more to go down but I’m going to set it up so it sits level with the rear.
J3rm0ff is offline   Reply With Quote
Old 09-01-2018, 09:28 PM   #53
brainfood
this is an awesome build, i"m piecing together a turbo setup right now for mine, so this is getting me stoked.
brainfood is offline   Reply With Quote
Old 09-02-2018, 09:56 AM   #54
Red71gmc
True imaginary thinking you have. The dash idea is awesome to suit your taste. I like how you say the "original dash never did anything for you" so you just simply change it to your liking. Nice!
Red71gmc is offline   Reply With Quote
Old 09-10-2018, 09:17 AM   #55
J3rm0ff
Thanks! Although I can't take all the credit as a few other forum members have also done this dash swap.
Old 09-10-2018, 08:40 PM   #56
J3rm0ff
With the ridetech control arms in the first thing that became very obvious was these inner fenders aren’t going to work. I found frizzle fry’s inner fender post and kind of worked off of that.
Old 09-13-2018, 09:28 PM   #57
J3rm0ff
Ended up remaking the intercooler mount so I could get a set of filler panels for between the grill and core support. Also, have a pair of viair gen 2 air compressors on the way.
Old 09-18-2018, 08:33 PM   #58
J3rm0ff
Got a 9” tuff stuff booster and got it flush mounted... for the most part. Going to have to modify the steering column bracket a little bit. Also knocked out the studs from the brake pedal bracket so I could mount to this booster. Going to get a rhd s10 master. Hopefully that will be enough for the Brembos. Read about this combo over on the pro-touring forums.
Old 09-21-2018, 11:02 AM   #59
J3rm0ff
Worked on the coldside piping last night. I think I have it pretty much figured out and found a 4” piece for the intake that I think will work out perfect. Also got a dual pack of viair 485c gen 2 compressors. Just need to make the brackets to hold them and the tanks.
Old 09-23-2018, 08:56 PM   #60
J3rm0ff
Got the intercooler piping where I think it needs to be. Still needs welded though.
Old 09-29-2018, 05:19 PM   #61
J3rm0ff
Pushed the truck out of the garage today to clean had to get a picture of it with the c7.
Old 09-29-2018, 10:10 PM   #62
cornerstone
cornerstone's Avatar
The 2 very best choices that a man could want. You've got all bases covered.
cornerstone is offline   Reply With Quote
Old 09-30-2018, 02:10 PM   #63
72 tigger
72 tigger's Avatar
https://www.youtube.com/watch?v=B-gzNi6MRwI&app=desktop
Saw your C7 on a youtube vid the other day
72 tigger is offline   Reply With Quote
Old 09-30-2018, 03:13 PM   #64
J3rm0ff
Thanks I enjoy both of them in different ways. Can’t wait for the day I drive the c10 tho.
Old 09-30-2018, 03:13 PM   #65
J3rm0ff
I wish that was mine! Lol
Old 09-30-2018, 10:44 PM   #66
silvertonguedevil
silvertonguedevil's Avatar
I think your dog thinks you're crazy. LMAO!
-Greg
My Chevy trucks, past and present:
1962 C10 SB Fleetside
1964 C10 LB Fleetside BBW
1966 C10 SB Fleetside
1966 C10 SB Fleetside BBW
1968 C10 SB Fleetside
1971 C10 LB Fleetside
1971 C10 SB Fleetside
1972 C10 SB Fleetside Cheyenne
1972 C10 SB Fleetside Cheyenne Super
1972 C10 LB Fleetside Cheyenne Super
1974 C20 Cheyenne
1979 K5 Blazer Cheyenne
1982 K10 SB Fleetside Custom Deluxe
1982 K10 SB Fleetside Scottsdale
1986 C10 SB Fleetside Silverado
2008 Silverado 1500 4x4
silvertonguedevil is offline   Reply With Quote
Old 10-01-2018, 06:58 PM   #67
tinydb84
tinydb84's Avatar
Great work.
David
Instagram: myfabguy
Old 10-02-2018, 11:42 AM   #68
J3rm0ff
I’m sure she does! Lol
Originally Posted by tinydb84 View Post
Great work.
Thanks!
Old 10-02-2018, 08:07 PM   #69
J3rm0ff
Got the tank and compressor brackets made and mounted. Two 3 gallon tanks and 2 485c compressors
Old 10-04-2018, 10:41 PM   #70
J3rm0ff
Was going back and forth on the shock location and ultimately decided on keeping them in the stock location mainly so that I can run the exhaust out the back. Still have to finish the mounts but here is the rough idea.
Old 10-16-2018, 08:43 PM   #71
J3rm0ff
Got the shock brackets tacked on and the cab pulled off and started working on the exhaust. Splitting the 4” downpipe to a dual 3”
Old 10-18-2018, 09:22 PM   #72
J3rm0ff
Made some more progress on the exhaust. Need to get a driveshaft to make sure I’ll have enough clearance between it and the exhaust. After calling the local driveshaft place and getting a quote on a 2 piece I’m leaning towards 1 piece. I took out the carrier bearing mount and mocked up what a 3.5” driveshaft would be and it looks like it’ll work with a little clearancing on the crossmember.
Old 10-20-2018, 08:36 AM   #73
ilikethewoods
ilikethewoods's Avatar
Awesome build!
ilikethewoods is offline   Reply With Quote
Old 10-21-2018, 11:34 AM   #74
J3rm0ff
Originally Posted by ilikethewoods View Post
Awesome build!
Thanks! Just checked out yours. Really like the direction you’re going.
Old 10-25-2018, 12:22 PM   #75
J3rm0ff
Got the passenger side exhaust tacked up back to the axle. Now to get it under the driveshaft without hanging down low.
