02-10-2019, 06:16 PM | #51 |
Re: 1958 Chevy 60 Viking
Well..that's where your creativity comes in
but not for a while, we first got to get her on the road and have the new wheelbase documented. you're more than welcome to come by and have a live look! We always have a cold beer standing by.
Feedback is always welcome! projects: 1969 Chevy C10 1950 GMC 100 1958 Chevy C60 Viking ratrod Last edited by Steve-W; 02-10-2019 at 06:18 PM. Reason: spelling |
03-02-2019, 04:36 AM | #52 |
just found the project , im from haarlem btw , i might be interested in the 6 inline after you done the engine swap
i got a c10 they converted to a v8 problem is they never changed it on the registration and they changed the cab without transferring the vin (over here chassisnumber is vin but they do check if they match ) so i be 2/3ths changed (over here they alow only the chassis or the drivetrain or the body to be changed / replaced by other same model stuff and the truck still seen as original) so i would be illegal in therms of being an oldtimer truck and have to pay roadtax again ) so rather than going through the rdw (dmv) **** i rather change the engine before getting the truck recertified within the 1/3th change alowed rule the reason they made this rule : over here in the yeah olden days cars and trucks older than 25 years where considered oldtimers and where exempt from roadtax smart people figured out that if the replaced oldtimer landrover bodies and drivetrains with the newer 4 door landrover bodies and drivetrains that fitted straight on a oltimer chassis they had basicly new cars but didnt had to pay roadtaxes for and started converting them on a pretty large scale , so the rdw gotten wize and changed the rules
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts Last edited by watahyahknow; 03-02-2019 at 04:52 AM. |
03-07-2019, 04:16 AM | #53 |
That's possible, but you'll have to wait a while. I'll send you a PM.
Feedback is always welcome! projects: 1969 Chevy C10 1950 GMC 100 1958 Chevy C60 Viking ratrod |
05-18-2019, 06:14 PM | #54 |
So we got the F250 finished, it's been to the Dutch DMV and passed the scrutineering. Which means we're back at the Viking again
Disassemble time! Doors, Fenders, front clip etc. also took out the steering column, because we were unable to turn the wheels and it turned out the steering gear box was all locked up because somehow the grease got replaced by water, which in turn did wonders for the bearings... Now we'll have to find a way to rebuild the steering box. anyway, everything came off quite easy and we only found some rust at the front cab mount (read: holes) but nothing we can't fix. Something stood out for me and that's the alternator, it's 12V. was that the standard in 58 already, or special order seeing it was meant for export?
05-19-2019, 03:19 AM | #55 |
could be its replaced at a later date or the standard in heavier truck , like they use 24 volts nowadays
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
05-20-2019, 10:44 PM | #56 | |
55-up was 12 volt for chevy, i believe 56-up for gmc
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
06-28-2019, 07:54 PM | #57 |
Took the cab off today
First moved it backwards and then the three of us lifted it off On order to do so, we had to take off the lid of the gearbox (SM420) because we had no Idea how to get the gear lever out. Hmm doesn’t look good.
06-29-2019, 04:18 AM | #58 |
looks like there was water in there , the rubber seals where probably damaged during the fire have water from dousing the fire pour through the cab floor and maibe having the truck parked out in the rain before you bought it without windows probably didnt help either . you can dunk some diesel / waste oil or so in it and cover the metal parts up then seal it up with some plastic and tape to keep the worst of the rust and junk out but you whont use it anyway and pulling the driveshaft out will cause the oil to leak out again making a mess on youre floor
the gearstick usually isnt atached to the cab just sticks through a hole and it covered up with a rubber covering the gearlever is usually thightened with two bolts on the top of the gearbox , could be the same dust cap rubber has glued the cab to the gearstick the older trucks have prety thick sheetmetal , you might be able to save that cab with a good sheetmetal wordker and some cutting slots and rewelding to get the expanded metal and buckling ou
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts Last edited by watahyahknow; 06-29-2019 at 04:28 AM. |
06-29-2019, 10:45 AM | #59 | |
hope we didn't bite off more than we can chew.. with the doors and front clip still on, everything looked to be lining up pretty good. doors opened/closed nicely. only visible warped metal is the roof.
06-29-2019, 11:07 AM | #60 |
not sure if you look at cars and cameras on youtube , one of the guys on the show crafted a roof and part of the doorpillars from another truck to the original cab , there definetely not professionals at metalworking but the cab is about ready to be painted about now
https://www.youtube.com/watch?v=I8jXoj0prW4 another youtube and different way to do the same thing : https://www.youtube.com/watch?v=QRKkm96MVPc i think the carsandcamera way is the best even with the headliner metal in there as it help keep the cab in shape a little better
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts Last edited by watahyahknow; 06-29-2019 at 11:29 AM. |
07-08-2019, 04:28 PM | #61 |
had a look in the gearbox and the covered it again doesn't look like anything that elbow grease and a steelbrush won't fix. the gears still travel on the shaft, or at least most of them..
with the cab of I could take a closer look at the brake booster. never seen a system like this, but I guess it works the same as a modern one? I love that it's made by Bendix Aviation Corp. the Master brake cylinder probably needs some work and here is the PTO, driving the rear hydrolic lift..which is gone, so we'll have to find some good use for this.. maybe a tilt front? I had to look it up but this truck has a driveshaft parking brake system..I heard of it 30 years ago learning to be a mechanic, but never seen one until now. wondering whether it is linked to the PTO? so when you engage the parking brake, the PTO starts building pressure?
07-08-2019, 04:40 PM | #62 |
Post Whore
nope...its simply a parking brake...nothing to do with the pto....my truck has one as well
07-09-2019, 12:52 AM | #63 | |
https://www.freeasestudyguides.com/h...ke-assist.html at a closer look ....i dont think it is , but it be a good idea to change it intoo hydroboost
07-31-2019, 07:07 AM | #64 |
Came back sunday from a two weeks holiday in Curacao, where to my suprise aren't any nice old trucks.
yesterday evening after work I wanted to get back to it, so Ferry and I build a transport wagon for the Cab, which will fit on our lift as well. During my holiday he cleaned up some parts of the cab with a machine bristle brush and treated it with rustöl I think this is a very nice finish, we'll just test on the glovebox whether we're going to (mat) clearcoat it. so now with the wagon it is easy to work on and we got a good look at the rot which looks not to bad, considering these are the only spots, which are really gone.
08-01-2019, 12:42 AM | #65 |
think you can buy replacement sheetmetal for that
https://restorationpartssource.com/s...Body_Parts.htm https://restorationpartssource.com/s...lass_Parts.htm https://restorationpartssource.com/s...rake_Parts.htm https://restorationpartssource.com/s...trip_Parts.htm
08-01-2019, 06:57 PM | #66 |
Thanks for the links, we usually get stuff from LMC, but in this case seeing we're going for the ratification, we'll fabricate ourselfs.
09-20-2019, 05:26 PM | #67 |
at work!
made some cab mount support brackets this will replace the old time is a bit hard to find lately, have been very busy with work, family etc. but we're not in a rush, so this thread wil be continueing slowly but surely/ the floorboard is a bit warped on the right side, but when we mount the brackets we'll pull it back together.
09-21-2019, 04:27 AM | #68 |
looks good
05-17-2020, 07:36 PM | #69 |
September ’19 was my last update, jeezz time flies and to be very honoust I’ve been spending a lot of time on the Stovebolt forum, because there is so much specilized knowledge there for this age truck. But I don’t want to keep you hanging, so here’s an update
The only really bad spots were the front cab mounts and the lower Door hinge mounting point. So the door hinge part we ordered new, but the cab mounts we fabb’d ourselfs. The bolt hole should line out perfectly, the hight is questionable, but thats what shims/spacers are for. Cab mount fabrication finished We discovered that the Owatrol Rustol is sprayable! Which save sus huge amounts of time, and it gets in spaces, you can’t get at with a brush. Next we needed to get some space to work on the rest of the sheetmetal and doors. So we found out the cab fits nicely in the back of my C10. Time to tackle the rest of the sheet metal; cleaning, scotch brite, decrease and shoot the owatrol on it. it is designed for rust, but it sits pretty nice on paint. Perhaps it washes off in the first rain shower, but thats for later worries. The front fenders had a good amount of bondo on them, so we had a discussion whether to sand them down to bare metal, or just removing the cracked and loose pieces. We choose the latter, just because it is less work and this whole rat rot is about doing whatever we want.. we call it artistic freedom. After all that metal word, it was time for the mecanical part. The gearbox has had standing water in it, so it looked pretty ruff. But we cleaned out the gearbox as good as possible by giving it a diesel bubble bath. Check movie. https://www.youtube.com/watch?v=DdSGaSFMCqw after this and filling it up with some fresh oil. So far we’ve found 2 forward gears and what we think is reverse, but until it’s on the ground with wheels we’ll just have to wait. Then we turned our attention to the engine. Mechanics 101, replace all electric stuff; plugs, wires, points, condensator, rotor, distributor cap and even the coil. Fresh oil and such, hose from the fuel pump into a reservoir and helping it with a large syringe ..see movie for the result. https://www.youtube.com/watch?v=stST2Ery03Q At this point we had a working’ish gearbox, a running motor and even brakes.. because we blead the master cilinder, the hydrovac and all 4 wheels and we have full lock on all of them. So we’re not pulling the drums, first of all because apart from the fire, everything indicates this car has been maintained meticulously and secondly, we have no idea how to get the drums off The one major problem we were facing apart from the wheels, was the steering. The steering gear had been destroyed by the standing water and all my google experience couldn’t find us an affordable solution of either replacing the steering gear, or rebuilding it. I was getting estimates of $700,- or more, which for just a steering gear wasn’t an option. So trying to break the endless searches in “the old interweb” Ferry and I had a build off; who makes the prettiest mirror frame. He choose copper, I did steel. Also I ordered in all the glass which a reseller here in the netherlands had in stock! Christmas! In the meantime i’ve been in contact with a fabricator who specializes in steel wheels. I presented the problem of the 3 piece wheels and asked if we could turn them into tubeless. Now, here’s some things I didn’t know. 20” truck tires are never tubeless, but going to 22,5” would be an enormous overhead in cost ánd then the tires.. so perhaps it was better to look at 19,5” but the problem there is the gigantic rear drums with a circumference circle of 130cm (which translates into 51”) At the raised Lip at the back it’s even 136,5cm (53,7”) I can’t in my right mind drop 5K into wheels and tires where whe whole truck cost me less than 4. And seeing we’re trying to do this as economical as possible, we’re sticking tot he 20”. I know tire size is an issue..but we need a rolling chassis now to proceed and when we go to the DMV and they OK the shortened frame then I’ll rethink wheels and tires. Here are the pics of what the wheels will look like. Front rim Rear rim And with paint I was able to create a dually view with some cutting and pasting. A while back I bought some stuff from a guy parting out a 1985 G30, among other things a front bench and a steering column whith steering wheel. Now the Column had to much plastic and electronics on them, so we pulled it apart and where left with a naked column with tilt! Waiting for wheels, and being bummed out that we could find a solution for the steering gear we focussed out frustration on the G-wagen steering wheel, which in our opinion had to much plastic aswel. So we pulled the airbag out, and the got medieval on its assc ….I like the result. And if you’re wondering how we’re going to make the horn work? Artistic freedom, a.ka. we’ll see. But then suddenly everything turned bright pink and an Unicorn presented itself. Just by googling in Dutch instead of english (Steering Gear vs. Stuurhuis) I Found a C60 steering gear in the Netherlands! So I raced 135Mi north to get there as fast a possible. It turned out to be a small, privatly owned ww2 Canadian Allied Forces museum, who had some C15, C50 and C60 stuff for sale. As soon as I got back to the garage I showed my price possesion to Ferry, only to discover it was from a right hand drive!! (canadian ww2 vehicles were RHD..) luckily we could convert everything tot he old steering box and now it works. It runs, it shifts, it brakes and it goes around corners.. yippiekiyaaaay !
Feedback is always welcome! projects: 1969 Chevy C10 1950 GMC 100 1958 Chevy C60 Viking ratrod Last edited by Steve-W; 05-17-2020 at 07:41 PM. |
05-18-2020, 06:10 AM | #70 |
This is a great project and you guys are doing so well finding and fixing and making what you need. I'm glad for your good luck of finding the glass and steering box even though it was wrong handed to begin with. I look forward to following along. If you have a thread at the stovebolt site maybe you can post it here. I hope that you will give us as many details as you have time for though. Thanks for telling us about this.
05-18-2020, 09:46 AM | #71 | |
I wasn't sure if you can "promote" other forums here, but here it is: Stovebolt C60 build thread
05-18-2020, 09:53 AM | #72 |
You have been busy. I LOVE the steering wheel idea!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
05-26-2020, 04:07 AM | #73 |
Nice work Steve!
All this can be repaired, the damage of the fire could be really bad... Great to find the parts you need in good ol’ Holland
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
06-03-2020, 06:10 AM | #74 |
The problem with fire damage is you have no idea how hot things have gotten and whether the structural integrity has been compremissed. So far everything was looking up. some warping in the roof, but thats about it. the doors looked straight, so we decided to fit them just for argument sake and seeing we had replaced the lower hinge support on both sides, we were curious if the doors would still fit. well, you tell me:
the reason for the right door to be so clean is that they left it open when they bolted to get away from the fire the story behind this truck is almost moviescript worthy. Seeing we have all the glass and rubbers, we started assembling the doors using as much of the original parts as possible. To our supprise we were able to re-use everything except the left door lock Done! having completed the doors in a matter of hours, we turned our attention to our seating possition. I bought a bench from a '85 G30 a while back, which I actually wanted to put in my C10, seeing that is also blue...but I guess I'll have to buy another one we used some 2x4's to get to the right hight (vision center window) and while we were at it, my mate quickly cut out a templet for the dash which is actually a piece of sheetmetal of the G30 hood. now we're despreatly waiting on the wheels, because we want to put that cab back on!
06-22-2020, 04:05 PM | #75 |
Great job.....will be following along.....
http://67-72chevytrucks.com/vboard/s...82#post8619382 |
