10-31-2021, 10:47 AM | #1 |
Just here to tinker
Re: 86 Suburban w/ 56k miles
I was scrubbing the tank, prepping it for POR15 and found another build number. 83. It’s written everywhere: under dash, on firewall, on rad support, on frame. Pretty sweet that it is all still legible.
Got the new sender installed, going to paint the top of the tank with POR 15 and repair the few surfaces on the frame where the anti-squeak padding was holding moisture and causing rust. The rest of the frame in that area is still factory black and shiny which is awesome. Next will be all new fuel hoses, gluing on the new anti-squeak pads and then getting the tank back in.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
12-01-2021, 10:04 PM | #2 |
Just here to tinker
Well I got the fuel tank and all new hoses installed. Hooked up the new sender and…nothing. It still doesn’t work. Kinda made me mad a little bit. But, oh well we’ll continue troubleshooting. I thought maybe the gauge went south on me so I figured I’d get a new one. But then while I was looking up a new gauge, I started eyeballing the aftermarket tach kits and thought, yep, I’ll add that since I’m in the dash anyways.
So I got that installed tonight and works wonderful. I’m very impressed with the quality of the LMC tach kit. It’s probably the best aftermarket/reproduction part I’ve ever seen. It’s nice to see some high quality parts coming back on the market. Now I have to focus again and solve this dang fuel gauge problem. I’m almost certain I have a break in the wire somewhere….
12-02-2021, 12:31 AM | #3 | |
Evan B. |
12-10-2021, 01:49 AM | #4 |
That tach conversion is really clean. I'd like to do it, but I think I'm just going to go with the aftermarket column mounted / fold away tachometer option.
04-10-2022, 01:43 PM | #5 |
Just here to tinker
Finally we have a nice day in western Michigan!
04-10-2022, 01:45 PM | #6 |
Just here to tinker
This week I replaced the rusty original 2 1/4” tailpipe with a new 3” factory style like my ‘88 has.
12-30-2022, 05:33 PM | #7 |
The wheel and tire combo looks good. Glad you kept some sidewalls on the tires. Looks so much better than the rubber band look.
12-30-2022, 06:22 PM | #8 | |
Just here to tinker
I went with this size also because it is almost the exact same height as the 255/70/15 so I don’t need to change speedo gears or anything.
01-05-2023, 06:50 PM | #9 |
That looks very good. Love your Suburban!
01-05-2023, 07:04 PM | #10 |
Just here to tinker
01-07-2023, 11:44 PM | #11 |
Just here to tinker
That’s more like it.
01-08-2023, 08:01 AM | #12 |
01-08-2023, 02:08 PM | #13 |
Just here to tinker
Thanks Bill!
I think it looks even better outside!
01-08-2023, 02:18 PM | #14 |
Just here to tinker
Time to get this thing a little lower now. Drop spindles and rear shackles should be here in a couple weeks!
01-08-2023, 05:31 PM | #15 |
Just here to tinker
Moving right along, time to tear down the engine for a new Melling MTC-1 camshaft. I plan to tow my boat quite a bit in the future and need a little more uumph than the underwhelming 165 factory horses. Haha
This is as far as I got today.
01-09-2023, 12:13 AM | #16 |
Cam swaps with the engine installed always add some fun to the mix. Interested to hear your seat of pants comparison to the stock cam.
01-09-2023, 03:02 PM | #17 |
Will be a nice project to do. I will be following along too.
01-11-2023, 06:21 PM | #18 |
Just here to tinker
Waiting for the engine parts to show up, but my lowering shackles arrived so I thought I might take a swing at those tonight. Boy will this be fun….
Turns out the ol’ assembly line put this bolt in so there is no way you could ever get it out. Time for the sawzall.
01-12-2023, 06:16 PM | #19 |
Just here to tinker
Yep, I immediately regret digging into the suspension right now. Every bolt is frozen and needs to be cut out. Jooooooyyyyy.
01-13-2023, 06:03 PM | #20 |
Just here to tinker
Well this escalated quickly. Every bolt was seized in the leaf spring eyes. I ended up cutting out everything. So! New leaf springs, hardware, and u-bolts are on the way. And can someone tell me what GM was thinking on the forward leaf spring perch, putting the nut in that little pocket? How is anyone supposed to get in there!
Here she is as of today. The axle is just laying there loose. I’m going to drop it off at a shop in town and have the pinion seal replaced while I’m in here.
01-14-2023, 02:04 PM | #21 |
Just here to tinker
Got everything apart and all the perches and frames cleaned up ready for install. Now just waiting on parts!
Have to get a neighbor over here to help me load up the axle so I can take it to a shop for new seals.
01-25-2023, 08:57 PM | #22 |
Nice work on the drop, the Burb looks really good!
03-11-2023, 03:45 PM | #23 |
Just here to tinker
Thanks!
The rear is gonna have to come down some more for sure. I went to the shop and hooked it up to the boat trailer. She still sits too high even with a load on it, so I’ll be ordering the 4” drop leaf’s later this year.
03-11-2023, 03:51 PM | #24 |
Just here to tinker
I ended up having some custom 1” wheel spacers made for the rear. The tires sat too far inside for me. These spacers are hub centric and very high quality. Pretty happy with them.
04-11-2023, 03:50 PM | #25 |
Suburban is looking good! My K2500 has a 2" spacer on the rear, not big on the sucked in look myself.
Will you need to do an air bag helper with the 4" drop leaf?
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
