03-19-2021, 02:31 PM | #801 |
Re: 1971 Stepside LS Build
I like the boards on the ramp to keep it from dragging the headers on the cinder block entrance of the doorway. I bet it can stop on a dime and roll down the road like it was on rails!
'Hay Burner' 1969 C10 Long Bed, 454 BB, Hooker Headers, TH-400 w/3500 B & M Stall, 4.11 w/ Auburn-Pro Limited Slip. http://67-72chevytrucks.com/vboard/s...d.php?t=813448 "Wouldn't say I was missing it Bob" |
03-19-2021, 03:15 PM | #802 | |
Almost Satisfied
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
03-23-2021, 03:01 PM | #803 |
Almost Satisfied
This thing is finally legal. Got my plates today....I was probably more excited about being at DMV than I should have been
03-24-2021, 09:05 AM | #804 |
Look at you all legal now... That is great news Shannon. the tune date will be here before you know it.
Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
03-26-2021, 04:54 PM | #805 |
Always a good day when the DMV dragon is slayed!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
03-29-2021, 09:33 AM | #806 |
Almost Satisfied
We took our first maiden voyage out of the neighborhood over the weekend. The first trip was short and all went well. On the second trip I decided to go fil her up with gas. The gas station was a little further and it would be a good test. On the way back to the house I decided to keep going. It was a beautiful day and the truck was on the road!!! Well, I should have stopped
Got down the road about 1/2 mile and the front brakes decided to hold on and not let go. At first, I thought the transmission was the culprit as it wouldn't shift out of first gear. Then I realized it was the brakes holding it back. Limped back up the hill to the house and the brakes were hot! Let her cool down and they freed up. Everything I've read points to the pin being too long between the MC and booster. I'm going to shim the MC out tonight and see if that cures the problem. We have a dyno appointment Friday we have to be ready for! LOL
03-29-2021, 09:42 AM | #807 |
There's always something, isn't there? But that's the purpose of short trips - work out the little bugs that come up in the first 50 miles.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
03-29-2021, 05:02 PM | #808 |
Gosh, truck looks just awesome. Momma said there will be days like this.
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
03-30-2021, 09:55 AM | #809 |
Almost Satisfied
In the vain of "it's always something" here we go.
I went home last night enthusiastic about putting a couple spacers in the MC and feeling confident that would resolve the front brake locking issue. I drove the truck around and finally felt the pedal getting hard. NASCARed a jack under it and the front wheels wouldn't turn by hand. Started to back off the nuts on the MC to find this!! Not sure if the shop broke it putting it back on when they were messing with it or if it broke due to stress or what. To add insult to injury after the nuts were loosened the front tires freed up some but not like they should. So, I need a new MC and still don't know what is causing this issue. I'm now leaning more toward the prop valve than I am the MC.
03-30-2021, 10:13 AM | #810 |
Well that's not something you see every day. I stuck with the factory booster/master cylinder/prop valve off the Astro van and haven't had any problems!
03-30-2021, 04:56 PM | #811 |
That's an odd break for sure. I am running the aftermarket one from CPP. Prior to that I was running a factory one off a Tahoe that had hydroboost. I chose that one because it had front disks and rear drums. I'll look at mine tonight to see what I can learn. How is yours mounted to the firewall?
Dave
03-30-2021, 05:35 PM | #812 | |
Almost Satisfied
03-30-2021, 09:14 PM | #813 |
I agree that ghe hydroboost is all the same. I'm pretty sure mine is off a truck but that won't matter. I do have a 1/4 inch plate between mine and the firewall. My rod is also adjustable. I'm not sure what would cause your brakes to hang like that.
I don't know if you can see what I have going on in the picture
03-30-2021, 09:22 PM | #814 |
I'm remembering that I used that plate because of the nut or a step so it wouldn't sit flat. I don't have a bracket per say just that plate. If that makes sense
03-30-2021, 10:17 PM | #815 |
My brakes were a total mishmash. I had a Cpp master with a spacer in the piston to allow it to go manual or power. Also has an adjustable out pin on the booster. Wound up cutting the spacer down and fine tuning with the adjuster. The one I just finished was a Cpp kit and the master had to be spacered out 1/4" to not drag/overpressure the brakes. Works great now. That intersection is so important, yet so overlooked.
04-01-2021, 12:26 PM | #816 |
GM has 2 different styles of HB setups.
http://67-72chevytrucks.com/vboard/s...d.php?t=677763 Is it possible you have the long shaft one and need the short shaft one? Im running a C3 disc/disc master on my one of my HB setups.
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
04-01-2021, 02:22 PM | #817 | |
Almost Satisfied
04-01-2021, 10:18 PM | #818 |
My HB has the short shaft. I still think this is the issue, but the shop that now has it thinks it is the calipers themselves. They could not get the pressure to release at the MC or prop valve but it does at the calipers. I'm just not sure I am buying that both Wilwood calipers are bad.
__________________ 1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3000 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Other toys always push it aside, but one day....one fine day, she will be back on the road. "I can't complain, but sometimes I still do. Life's been good to me so far." 1971Stepside is offline Report Post Reply With Quote Multi-Quote This Message Quick reply to this message U need to call wilwood to verify but I believe they are right. Wilwood calipers from what I’ve been told can’t do HB. The pressure is to high. Roughly 1200 psi is what they can handle. So..if u run manual or regular booster, then they will work. Hydro has 1800 or more psi and the pistons n the calipers are not designed for that. This is why when they got the pressure off of the caliper the brake released. |
04-02-2021, 09:43 AM | #819 |
67-72 parts collector,…
I’m pretty sure there are MANY cars and trucks running a Wilwood m/c with hydro boost.
Many companies sell them together as a kit. Your issue looks like a “pushrod length” problem to me. That would explain the calipers locking up and the broken mounting tab.
04-05-2021, 10:15 AM | #820 | |
Almost Satisfied
04-05-2021, 10:48 AM | #821 |
Almost Satisfied
Got the tune done on Friday at LSxKilers Custom Calibrations in Bonner Springs KS. She runs well now. Got an extra 70hp out of her with a cam and headers. Next upgrade will be bigger injectors as the dyno proved it needed them beyond 4700 rpm. I was just glad it all held together on the pulls
Beaterku dropped by with his beauty queen.
04-05-2021, 01:54 PM | #822 |
That's awesome Shannon, you will be tearing up the streets now for sure. Looking forward to seeing the ole girl out and about.
Dave
04-06-2021, 09:17 AM | #823 |
Almost Satisfied
At a former job I used to coordinate tv commercials for the firm. I got to know the people at the studio very well so, when they contacted me about using the truck in an infomercial I was pretty excited to get to work with them again. This was a two hour shoot for a vacuum cleaner. They basically set it up to look like the guy was just out cleaning his truck in the driveway....we had to add dirt
Made a little money and when they are all done I will get a vacuum. Win win. Not sure where this will air, but when I get the link I will share it.
04-06-2021, 12:13 PM | #824 |
Glad you got it tuned. Guys, this truck is even better in person. It’s crazy nice. Ready to see some rolling burnouts
04-06-2021, 01:31 PM | #825 |
I'm trying....
My favorite pic is the yellow tape on the rockers. Took me a second...because at first I recoiled seeing that boot casually dangling out the door.
But of course you had that covered. It all looks fantastic. Here's wishing you many miles and no bugs (biologic or mechanical).
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
