Old 03-25-2012, 10:56 PM   #876
shrunken66stroker
shrunken66stroker's Avatar
Re: Shrunken66Stroker's build thread.
Originally Posted by chad64chevy View Post
i got a question about this too! i get the 3" cut between the two bolts, but off the bottom of what do you cut for the 2" cut??
You'll have to cut the shaft down by the rag joint, sleeve it and weld it back together. I'm going the rack and pinion route so I'll have much more work when I get to it.
shrunken66stroker is offline   Reply With Quote
Old 03-26-2012, 04:30 PM   #877
chad64chevy
chad64chevy's Avatar
thanks for the info., i started to stare at your pictures more and realized you have to cut the shaft 3" and notch the cover plate, so it can be bolted up under the dash! i'm blonde and had a moment, lol!! i started cutting mine, should have it welded back together this weekend, and painted!!
chad64chevy is offline   Reply With Quote
Old 03-26-2012, 08:52 PM   #878
shrunken66stroker
Correct. You do have to cut both. The cover is basically a trim piece and just needs to be notched so it will fit back on after the shaft has been shortened. Good Luck!
Old 03-26-2012, 09:53 PM   #879
shrunken66stroker
As promised.
Old 03-26-2012, 10:21 PM   #880
daverod
SSN 706
daverod's Avatar
What where? This is'nt one of those things where your naked in some reflection somewhere is it?
daverod is offline   Reply With Quote
Old 03-26-2012, 10:26 PM   #881
shrunken66stroker
Ha. I'm trying to motivate myself with what little progress I'm making. Waiting for the snowball effect.
Old 03-27-2012, 10:00 AM   #882
Strodder
Daring to be Different
Strodder's Avatar
Dave, you are one sick SOB.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 03-28-2012, 12:38 AM   #883
shrunken66stroker
When I raised up the bed floor the tubs went with it. This mod was to compensate for that. The strips that are on the table were what I cut out of the side where the fender use to bolt to the bed. There's only two inches to cut out before I got to the part in the middle of the bed that bends at a 90 degree angle. I raised the bed floor up 3" so I had to put a 1" strip in the tub to lower down the flange to get under that 90 bend. I still have to finish the welding and plug the old mounting holes. Does that make any sense at all?
Old 03-28-2012, 12:40 AM   #884
shrunken66stroker
more
Old 04-06-2012, 07:12 PM   #885
R.A.D
don't stop now... soon the momentum will be at its peek, and then you'll be cruisin'
R.A.D is offline   Reply With Quote
Old 04-06-2012, 10:41 PM   #886
daverod
SSN 706
daverod's Avatar
I'm starting to see that getting a tight fit helps with good looking welds. Can you take your tires off with the bed on?
Old 04-07-2012, 03:13 AM   #887
shrunken66stroker
Tight fit is key, especially with tig. My wheels will barely come of when the bed is on. I still have to roll the lip of the fender under. That should make it easier.
Old 04-07-2012, 03:05 PM   #888
daverod
SSN 706
daverod's Avatar
Did you cut it?
Old 04-07-2012, 06:40 PM   #889
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Dude.....mad skills..
You do great work and thanks for showing the details like you do .
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 04-08-2012, 01:05 AM   #890
shrunken66stroker
Thanks. I haven't had a lot of time but I'm trying to finish the bed. I cut the little tabs off the tailgate that the chains hooked to when the gate was down. I rewelded the braces that hold the new gate checks on(or what ever the hell they're called) and plugged the holes in the side of the gate. Now on to filling the holes that are left and evening out the gap between the gate and bedside.
Old 04-08-2012, 08:57 AM   #891
R.A.D
very nice
Old 04-10-2012, 10:13 PM   #892
shrunken66stroker
I welded and drilled a tab where the stealth latches seat and made it part of the mount for the gate link assembly.
Old 04-11-2012, 12:05 AM   #893
shrunken66stroker
Tacked the patches for the notch and hole.
Old 04-11-2012, 07:26 AM   #894
R.A.D
can't wait to see the whole package
Old 04-11-2012, 11:19 AM   #895
65 old school
65 old school's Avatar
Nice work!, I like all the custom mod's you have made. I almost made the front wheel well modification on mine, and now wish I would have. but, IT'S JUST A WORK TRUCK!...
65 old school is offline   Reply With Quote
Old 04-11-2012, 01:50 PM   #896
McMurphy
McMurphy's Avatar
As always such nice clean work!
Looking at your pics makes me want to tackle my tailgate project too!!
Very motivating
I have some IDEAS !
Hahahahahah
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 04-11-2012, 07:33 PM   #897
shrunken66stroker
Very motivating
I have some IDEAS !
Hahahahahah
It's easy work but time consuming. The fab on the bed is close to being done, so it's on to the body work and prime. Then the hood mod.
Old 04-11-2012, 08:02 PM   #898
R.A.D
eyes are glued to the screen
Old 04-12-2012, 03:07 PM   #899
McMurphy
McMurphy's Avatar
Oh man oh man I cannot wait to see what your hood mod is going to be!
I just hope it isnt something that I wish I had done !!
....or cant do ....
Ok now the suspense is killing me.
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 04-13-2012, 11:41 AM   #900
Dinos63
chevy only
Dinos63's Avatar
Always such cool work!
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
1966, bagged, disc, long to short, stroker
