Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 01-22-2009, 10:38 AM   #76
BIG HEAD
Re: 72' Stepside 2 1/2 Rockwell Pond Truck
#2 3 inch body lift; #3 fuel filter; #5 both coolers in place
BIG HEAD is offline   Reply With Quote
Old 01-22-2009, 10:56 AM   #77
BIG HEAD
#2 picture of mid shaft and np200 transfer case; #3 foam in roof; #4 roof patch i made; #5 right front roof corner patch
Old 01-22-2009, 11:00 AM   #78
BIG HEAD
#1 left cab corner fitting; #2 all parts new, used, made, welded get sanded and epoxy primered after final fit, but while still exposed
Old 01-22-2009, 12:18 PM   #79
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Freak'n sweet !!!
Really like the colors
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 01-22-2009, 12:47 PM   #80
Yukon Jack
Post Whore
Yukon Jack's Avatar
What a beast! Wow, wow, wow!!!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-22-2009, 01:30 PM   #81
BIG HEAD
Because of the rust hole around the drip rail i am going to do away with it completely. I bought new drip rails but they are junk. Not even close to what i took off.
Old 01-22-2009, 07:58 PM   #82
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Wow man that is a sweet machine...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 01-23-2009, 12:30 PM   #83
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
WOW! Neat. Can't wait to see this one done.
LOW DOUGH is offline   Reply With Quote
Old 01-24-2009, 11:39 AM   #84
BIG HEAD
On friday after lunch i cut the drip rail off my cab. I have it welded up across the front and the passenger side is almost done it looks great. And it is easier to do than i thought. For the application i think it will work out well, it will not hold the water and mud.
Old 01-26-2009, 02:23 PM   #85
BIG HEAD
Some of the drip rail area rust
Old 01-26-2009, 02:25 PM   #86
BIG HEAD
More of the same, cutting off drip rail
Old 01-26-2009, 02:28 PM   #87
BIG HEAD
Welding drip rail. Looks good and getting rid of problem areas
Old 01-26-2009, 02:30 PM   #88
BIG HEAD
Front view and smothed dash
Old 01-27-2009, 02:48 PM   #89
BIG HEAD
when i finish the drip rail i am going to skin the doors.
Old 01-27-2009, 04:44 PM   #90
67ChevyRedneck
67ChevyRedneck's Avatar
Most people would have scrapped that cab (myself included) GREAT job on getting it back in shape!
I look forward to seeing it done... and please... take LOTS of pics of skinning the doors, I may do this to my original doors and put 'em back on the truck.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-28-2009, 10:27 AM   #91
BIG HEAD
after removing the outter skins of the original doors for the cab. i had them media blasted. the passenger door bottom was to far gone so i put a lower patch panel on it. the driver door needed only a small piece of metal in it. then they got a shot of epoxy primer.
Old 01-28-2009, 06:20 PM   #92
BIG HEAD
i got my door skins. took a scotch brite pad scuffed the inside and epoxy primed them. i bought a couple of sound deadner pads to put on before installing the skins. so i get more straight motor noise and less rattles.
Old 02-04-2009, 09:51 AM   #93
BIG HEAD
the cab is getting closer and closer. did not make my goal of jan 31 to have in final prime, but it is coming
Old 02-05-2009, 12:48 PM   #94
BIG HEAD
as i have prevouisly posted the cab was worse than i first thought. it came from the original owner. it had never been painted. but when i got it back from the media blaster i new i had my hands full. the crazy thing is how the project started. i wanted to build a 67-72 4 x 4. i've had several 2wd's. and i had enough parts to build a 4wd minus a frame. i just about decided i was going to convert a 2wd frame when i got a call about a 71' gmc 2500 4x4. after talking to the owner he wanted more than i was wanting to spend for the truck. but i went and looked at it anyway. i told the owner that i liked the truck but did not want to spend that much on the thing and left. later that nite the guy called me and told me he would take 1000.00 for it. he came off $2000.00 with out asking. so i bought it later that week after telling a friend about the purchase he told me he had a 72' short 4x4 frame behind his shop i could have if i came and got it. so i started this project with this free frame. i want to build a clean truck with a dana 60 front / 70 rear, 4.88 gears and lockers. aset of 44 bogger tires. that is what i did. well i had my rolling chassi. so then i went to a mud bogg and had to get some rockwells. i did, put some 4 inch blocks between the 12 inch springs and axles. when i had that all done i traded a buddy my springs for the coilovers and built the 4 link suspention.
i still have all the parts minus the springs to build a street truck. So that is what i am going to do next with the 71' 2500 gmc long bed.
Old 02-05-2009, 04:17 PM   #95
royo
royo's Avatar
man its going to be nice but dont forget pics lol
nickle and dime
royo is offline   Reply With Quote
Old 02-06-2009, 02:46 PM   #96
BIG HEAD
finishing up driverside cab corner replacement. and shaving drip rail off on driverside.
Old 02-07-2009, 10:21 AM   #97
BIG HEAD
If anyone has any sugestions or advice on what i am doing here, I am all ears. In the last week i have had about a thousand views, but not many commits. I finished up the drip rail area driver side yesterday. Made a few patchs. I have got to make one more small one for the driver side top of windshield post to roof area. It is looking very good. I have held off to last to install the rocker panels. I did this to keep as much grinding dust out of sealed areas as possible. When you get a bunch of metal dust sealed up in an area such as a rocker, there comes the rust again.
Old 02-07-2009, 12:27 PM   #98
msgross
msgross's Avatar
I think that most people are just amazed that you were able to save the cab. Nice work... more pics more pics please...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-08-2009, 12:06 AM   #99
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Awesome build, I love it.
--Josh
Old 02-08-2009, 04:32 PM   #100
BIG HEAD
I'll post some more cab repair pictures monday morning and by the end of week do some door skin replacement with pictures.
