Old 03-29-2011, 12:51 AM   #76
pig rig
pig rig's Avatar
Re: MY little Project....
I see why it sets up so high its resting on your exhaust
lol I hardly doubt it
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 03-29-2011, 01:10 AM   #77
pig rig
pig rig's Avatar
hey I was just looking at 502's build and got thinking about your springs when I spoted this picture
then yours
your front spring eye dosnt look as if its up as high as your and the arc almost looks tighter (I'm guessing that how I want to explane it) or maybe I'm just seeing things but I see your shocks are both to the front as were mine and 502's have one going each way
Old 03-29-2011, 08:41 AM   #78
madcow75
madcow75's Avatar
What he means is when you took that many leaf out and you lowered it. Did you check you pinion angle? Better check before you start blowin u joints. You use a wedge to correct this, which is the easy way.
madcow75 is offline   Reply With Quote
Old 03-29-2011, 09:37 AM   #79
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
then yours
yeah pig this truck is crazy. use to be a tow truck and there is a whole bunch of crazy things with it that don't match a regular dually (my vin says it's a Cab and Cahassis?) i do kinda like the rake but if i can get ride of it that would be cool too.
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 03-29-2011, 09:39 AM   #80
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
oh ok i'll take it to the spring shop and have them look at it of can i do this from home?
Old 03-29-2011, 12:35 PM   #81
pig rig
pig rig's Avatar
if your pinon angle is bad enough to tare up u joints you'd feel the vibration I've got a 4/4 drop on my crew cab and no shims for the pinon and I havent had a problem
Old 03-29-2011, 03:04 PM   #82
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
i'm thinking it's my carrier bearing it looks to be in bad shape.
Old 03-29-2011, 04:14 PM   #83
502ss
502ss's Avatar
Shims can be bought here
http://www.stylintrucks.com/parts/pi...0114_3354.aspx
1984 CC Dually - 454 - TH400 - Western Hauler Edition
Big plans are coming!
My build thread HERE
502ss is offline   Reply With Quote
Old 03-29-2011, 04:18 PM   #84
502ss
502ss's Avatar
You definitely have a different spring pack! Here is a good side pic of mine after lowering. You can see that I had no choice but to remove the overload spring stop pads that were on the frame because the leafs would have been touching yet you look at yours and you have tons of clearance. If I was you I would be looking to replace the spring pack with a stock c30 pack and that thing will come down quite a bit more!
Old 03-29-2011, 04:42 PM   #85
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
yeah i see it now! new spring packs it is!
Old 03-29-2011, 10:33 PM   #86
383Chevy
[><]Sofa King Dirty 4x4[><]
383Chevy's Avatar
How much drop is this? looks damn good cant wait for updated pics
00' Chevy Silverado 1500 z71
33"s
3" lift
5-speed
Past trucks
85' Chevy C10 Step side
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
92' S10/Tahoe sbc swap
383Chevy is offline   Reply With Quote
Old 03-29-2011, 11:30 PM   #87
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
it's about 5 in the front and 4 in the rear.
Old 03-30-2011, 06:13 PM   #88
502ss
502ss's Avatar
You replace that spring pack and you will gain another 2" easy!
Old 03-30-2011, 09:32 PM   #89
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
lol yeah prob!
Old 04-04-2011, 10:32 AM   #90
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Got a new updated list to tackle:
-Put a new hangger breaing
-Fix gas tank (new sending unit)
-hitch
-fix the Hydro boost (it's leaking some where might throw a new steering box also.)
-fix leaky valve cover
-fix leaky oil pan
-fix oil press guge
-fix dash lights (they majically all came back on while driving?)
-Get stock C35 rear leaf packs (has old tow truck ones raises the back up about 2 inches more than it should be)
-mabye while the motors apart paint and clean it up a little.
Think thats it.
Old 04-04-2011, 07:32 PM   #91
502ss
502ss's Avatar
-hitch
-fix leaky oil pan
-fix oil press guge
Think thats it.
That's a decent list! One step at a time and you will be amazed at how quick it moves!
Old 04-04-2011, 07:47 PM   #92
y5mgisi
Second Chance Program
y5mgisi's Avatar
Hate it when i miss stuff like this for so long! Looks like a cool project!
y5mgisi is offline   Reply With Quote
Old 04-04-2011, 10:12 PM   #93
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
for most of the motor stuff (seals an stuff) i kinda want to pull the motor but on the other hand i don't lol. Hmmmm what to do.
Old 04-04-2011, 10:12 PM   #94
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Thanks! it's been and interesting project for sure
Old 04-10-2011, 11:40 PM   #95
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Heck of a truck! I like it!!!!
John
1999 Toyota Tacoma 4x4
Old 04-10-2011, 11:50 PM   #96
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Old 04-28-2011, 05:53 PM   #97
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
So been thinking about lowering my truck MORE! was thinking of doing a flip and 3 inch coils. because with my spring pack i think i can get away with it worst coes to worse move my shackle and hanger set to 1 inch? any thoughts?
Old 04-28-2011, 06:42 PM   #98
mooseknuckles
mooseknuckles's Avatar
def go lower man...quit foolin with springs and shackles and start bagging it!! lol.
mooseknuckles is offline   Reply With Quote
Old 04-28-2011, 07:45 PM   #99
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Would love too but i have no idea where to start or how to go about it
Old 04-29-2011, 09:35 AM   #100
502ss
502ss's Avatar
Will it be a driver or a heavy hauler?
