Old 08-06-2011, 01:11 PM   #76
woodwright
Enjoying left field
woodwright's Avatar
Re: Ultimate work truck/ 70 K10 diesel
get in touch with Heath Diesel if you have any questions. They live and breath these motors. They've got a land speed truck with a 6.5 and have set a bunch of records.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 08-06-2011, 05:20 PM   #77
jbclassix
Junk Yartist
jbclassix's Avatar
I read and re-read their tech articles
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 08-22-2011, 12:48 AM   #78
woodwright
Enjoying left field
woodwright's Avatar
FINALLY, I have some progress to report. I got my new springs, and got both sets hung.
Got my steering box clean, painted and drop pitman arm on.
Got my front end painted and put back together.
My new front springs are a little stiffer than my old ones, so I put my 6.5 and tranny in place to see where they squatted to.
I gained an inch and a half. I hope they settle some.
When I was putting my dana 44 back together, I couldn't remember what order the outer pinion bearing and shims went.
I found a blowup of a dana 44 online, and put the shims in first, then the bearing, slinger, and then the seal. Is that correct?
Clint
Old 08-22-2011, 01:33 AM   #79
jbclassix
Junk Yartist
jbclassix's Avatar
I spy cross-over steering! and yes, I believe you are correct on the order but I will have to double check in the morning!
-Jeremy
Rebuilding an NP205
Old 08-22-2011, 02:48 AM   #80
plummen
so thats what progress looks like,show off!
hopefully the pieces for my frame that were supposed to be made 2 weeks ago will be made this week so i can get back to work,atleast i started glass beading my cab!
plummen is offline   Reply With Quote
Old 08-22-2011, 10:50 PM   #81
woodwright
Enjoying left field
woodwright's Avatar
I've always hated the stock chevy steering. I still need to build my steering arm, but I've got all the pieces.
Plummen, what parts did you have made?
Clint
Old 08-23-2011, 04:05 AM   #82
plummen
im supposed to pick up my frame pieces today/tomorrow,once te frame is done i can get my other springs/axles under there and start figuring out my suspension /steering.
my ace in the hole is my dad was a blacksmith/boiler maker/spring maker for railroad for 30 plus years.
back in the 70s/80s he used to build springs/lift blocks/u-bolts/steering arms for many 4x4 trucks with 44s under them.
he grafted a steering box from a concrete truck under a brand new mid 70s f250 4x4 that kept blowing out stock steering boxes because the tires were too much for it,made it all look like it belonged there!
its only steel is his phylosophy on life!
ill let you know when i get that far
Old 10-31-2011, 05:59 PM   #83
6thcav
hey i am thinking of doing a 6.5 diesel swap in my 68 K10 what did you use for an engine harness, fuse box, computer, dase harness, gauge wiring, and heater wiring. i also want a 5spd what did you use tranny and t case wise and how did you adapt them
6thcav is offline   Reply With Quote
Old 10-31-2011, 11:01 PM   #84
woodwright
Enjoying left field
woodwright's Avatar
My 6.5 is a '93, so there is no computer. There's really not much to the non-computerized versions, and I'm gonna put a new wiring harness in my truck. When I pulled the motor i dissected the engine harness to figure out what wires went where.
I got a smoking deal on a 2wd NV3500. Not the strongest tranny, But it was cheap. If you can, get a NV4500. I also went with a mid 70's Dodge divorced 205 T-case. With the divorced T-case I can change out the tranny later pretty easy, and 2wd tranny's are generally cheaper. I'm hoping to get back working on it soon, I've been trying to make my blazer a driver.
Clint
Old 11-01-2011, 09:38 AM   #85
birdistheword
birdistheword's Avatar
Subscribed. This truck is gonna turn out sweet. Amazing fab work too.
birdistheword is offline   Reply With Quote
Old 11-10-2011, 06:37 AM   #86
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Like the fab work, and like the diesel swap. Subscribed, cool build!
fryer1979 is offline   Reply With Quote
Old 11-10-2011, 12:22 PM   #87
woodwright
Enjoying left field
woodwright's Avatar
Thanks guys, I'm almost done with my blazer, so I'm hoping to get back to my truck soon.
Clint
Old 11-11-2011, 01:27 AM   #88
DBear
DBear's Avatar
Clint, what's up Bro? Haven't talked to you in a while. Hope your doing well. I will try to give you a call this weekend.
DBear is offline   Reply With Quote
Old 12-23-2011, 11:38 PM   #89
Chevymaniac
Awesome fab work on your truck. Any updates to report? Also could you tell me what grade, size, and length of bolts you used to bolt 4x4 parts to the 2wd frame. I'am doing the same thing to my 72 swb 2wd truck. I got 2 70 3/4ton 4wd's trucks for parts. How did you figure where to mount rear leafs to frame. My truck has trailing arm suspension. Is there a reference point to start with? Thanks for any help you can provide.
Chevymaniac is offline   Reply With Quote
Old 12-28-2011, 11:06 PM   #90
woodwright
Enjoying left field
woodwright's Avatar
Maniac, With the bed still on, I measured from the center line of the rear axle to the rear cab mounts. Make sure your front and rear cab mounts are equal and square. I'm not sure what the stock dimension is, I think I moved it back an inch or so to center it in the wheel well. Start on post 28. I used grade 8 zinc coated hardware. 9/16" for the spring mounts and shackles, and mostly 3/8" bolts for brackets. If you're gonna wheel or work your truck hard you could use 7/16" bolts.
I finally got my truck back in the garage. I've got to get back in build mode. I'm not sure what to do first. Any body got any suggestions?
Clint
Old 12-29-2011, 12:58 AM   #91
mosesburb
I had a V-8
mosesburb's Avatar
Something small and easy, then move on to something a bit more involved once you are back in the swing of things.
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 01-02-2012, 06:26 PM   #92
Chevymaniac
Thanks for the advice.
Old 01-04-2012, 03:26 AM   #93
woodwright
Enjoying left field
woodwright's Avatar
Have a few slow weeks finally, so I'm able to get some things done. I built a tower for my TC shifter.
Then I built linkage out of 2 heim joints, and some1/2"OD tube.
I still need to finish my shifter handle, and get my jack shaft built. Then I think I'm gonna work on my rear axle. I need to swap in my 3.73 posi carrier, and get it cleaned up and painted.
Clint
Old 01-04-2012, 06:05 PM   #94
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work on the shifter set up. That's sweet!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-04-2012, 06:50 PM   #95
jbclassix
Junk Yartist
jbclassix's Avatar
that's cool!
-Jeremy
Rebuilding an NP205
Old 01-04-2012, 06:52 PM   #96
jbclassix
Junk Yartist
jbclassix's Avatar
are you gonna run your exhaust under the crossmember?
-Jeremy
Rebuilding an NP205
Old 01-04-2012, 08:12 PM   #97
woodwright
Enjoying left field
woodwright's Avatar
Its gotta snake under the tranny and down the drivers side. The square cutout is for the driveline.
Clint
Old 01-05-2012, 12:56 AM   #98
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
I like your shifter attachment.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 01-26-2012, 09:18 PM   #99
woodwright
Enjoying left field
woodwright's Avatar
Small update, I've got the cab off and tipped over on its back so I can prep and paint the bottom. Had to do some small patches on 3 of the support braces. I've been using a paint stripping disk on my grinder and my cheap siphon sand blaster. Tomorrow I'm gonna go look at renting a small pressure pot blaster to finish it up. I'll try to post some pics tomorrow.
Clint
Old 02-03-2012, 12:11 AM   #100
woodwright
Enjoying left field
woodwright's Avatar
Built the steering arm for my crossover steering. Welded the threaded ends into a piece of 1 1/4" DOM.
Everything fits and looks good and I've got lots of adjustability.
Clint
