Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Suspension > Suspension Marketplace
Old 12-31-2011, 11:45 AM   #76
robnolimit
robnolimit's Avatar
Re: 63-87 rack and pinion
list price for the complete kit is $849.00
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 03-03-2012, 12:55 AM   #77
LSPOWEREDC10
LSPOWEREDC10's Avatar
how much for just the bolt on bracket?
LSPOWEREDC10 is offline   Reply With Quote
Old 03-04-2012, 03:48 PM   #78
205dke187
yeah, how much for the bolt and bracket?
205dke187 is offline   Reply With Quote
Old 03-05-2012, 10:10 PM   #79
robnolimit
robnolimit's Avatar
sorry but we don't sell them seporately.
Old 03-06-2012, 03:58 AM   #80
DUTCHMAN
DUTCHMAN's Avatar
I'm in need for a new power steering box for my C10 stepside
Can someone tell me of there are any benefits on the rack and pinion vs the oem box?
06 BMW 330d aut touring full option
83 Jeep CJ7 360 aut sold
71 GMC Suburban
67 Chevrolet C10 stepside
54 Ford F100 sold
49 Chevrolet coe
48 Ford f6 coe
Strijen
the Netherlands
"NO MISTAKES NO PROGRESS"
DUTCHMAN is offline   Reply With Quote
Old 03-06-2012, 08:19 PM   #81
robnolimit
robnolimit's Avatar
I am hoping that others will chime in also. Our rack system turns lock to lock in 2 3/4 turns, which is much faster than a box. Eliminating the drag link and all of the extra tie rod ends also helps to tighten up the steering, giving the driver a better feel. The inner pivit points and Tie rod length are set to eliminate the factory bumpsteer. All of this adds up to a truck that drives and steers like a new truck or car.
Old 04-16-2012, 08:53 PM   #82
stevenbren
Will it work on my 68 K-10?
stevenbren is offline   Reply With Quote
Old 04-17-2012, 12:55 AM   #83
robnolimit
robnolimit's Avatar
sorry, 2wd only
Old 04-17-2012, 11:01 AM   #84
stevenbren
would you know what I need to convert to power steering? 68 K-10
Old 04-17-2012, 12:03 PM   #85
robnolimit
robnolimit's Avatar
I would hunt down the P/S box & linkage from a 71-72 K10, bolts on direct, or the 73-87 4x4 , but this will require a bit of fab work. Just trying to help here, I really don't know too much about the 4x4 stuff. I'm sure some members know a lot more than me.
Old 07-05-2012, 09:44 PM   #86
aggie91
I'm just glad to be here!
aggie91's Avatar
I want to get this set up for the '82 I'm building for my son. What is the issue that I have read about when using the stock 73-87 lower a arms? Has that been resolved?
Also, we did the same sectioning of the frame to raise the cross member like you did on JT. Does that effect the install of your rack in anyway? We are running McGaughy 2 1/2" drop spindles too.
Thanks, Karl
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 08-06-2012, 01:25 PM   #87
robnolimit
robnolimit's Avatar
If you want to see one in action, check out Smitty's build thread. Nice truck Chris.
Old 08-06-2012, 01:27 PM   #88
robnolimit
robnolimit's Avatar
Thanks, Karl
The problem with the stock 73-87 arms is the size of the bushings. Most aftermarket arms will clear. Since the rack is mounted to the crossmember, raising it has no effect on the steering geometry.
Old 08-07-2012, 05:21 PM   #89
aggie91
aggie91's Avatar
Thanks Rob. Brothers had one on there site that looked like the one on here. I called them and they said that they get them from you. During July they had them on sale with another 10% off on top of that. I call your shop and spoke with a young lady (you where out that day) and she could not match the price I was getting at Brothers so, I ordered one on the 23rd and yesterday they said I should have it by the end of next week.
If it hits the stock arms/bushings, I might just switch to a after market lower arm. I want to keep the coils spring for now, is there an arm you would recommend for that?
Thanks,
Karl
The LST Challenge:
Old 08-07-2012, 06:04 PM   #90
SCOTI
SCOTI's Avatar
If it hits the stock arms/bushings, I might just switch to a after market lower arm. I want to keep the coils spring for now, is there an arm you would recommend for that?Thanks,
You could also run pre-73 lower arms if the budget required.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-07-2012, 07:45 PM   #91
robnolimit
robnolimit's Avatar
I'd look at Nates new 'forward' lower arm, or Cpp for a stock coil.
Old 08-07-2012, 10:08 PM   #92
SCOTI
SCOTI's Avatar
PB's 'forward arm' should help w/the caster too.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-10-2012, 03:38 PM   #93
robnolimit
robnolimit's Avatar
Working a deal with Nate to package the P/S rack and a set of his "Forward Lower" A-arms. This combo will add caster, center the wheel and deliver great steering. Check out the suspension marketplace.
Old 08-10-2012, 05:44 PM   #94
gringoloco
A guy with a truck
gringoloco's Avatar
Aw, c'mon! Too tempting. Should be a great setup
gringoloco is offline   Reply With Quote
Old 10-23-2012, 09:26 AM   #95
aggie91
aggie91's Avatar
Rob
I got an issue I need your help on. I have your Rack and Pinion kit and PB Forward Lower Arms for my son's '82 that we are building. I have it all mounted now I am working on the steering linkage.
Where do you mount the support bearing on the frame rail. The factory holes are in different spots then on the 67-72 models. I have also raised the crossmemember in the frame like you did on JT. Any guidlines you can give me on where to put the bearing??
Thanks,
Karl
The LST Challenge:
Old 10-23-2012, 12:58 PM   #96
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Any updates?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-24-2012, 11:48 AM   #97
robnolimit
robnolimit's Avatar
Aggie, I'll have some picts up in a bit. With the raised crossmember, you will need a different type bearing support. I can help you with that.
Old 10-24-2012, 11:49 AM   #98
robnolimit
robnolimit's Avatar
Originally Posted by 68GMCCustom View Post
Any updates?
Yes, both Nate and No Limit have this package available now.
Old 10-30-2012, 11:28 AM   #99
aggie91
aggie91's Avatar
That would be great. I think this is the last piece I need before the frame comes apart for blasting and paint....
Thanks,
Karl
The LST Challenge:
Old 12-01-2012, 04:11 PM   #100
aggie91
aggie91's Avatar
