Old 02-18-2014, 11:17 PM   #76
RangerCB29
Re: Eaton HO72/HO52 vs. 14 Bolt FF
i actually just saw a 9" housing on craigslist and thought the exact same thing haha. the guy I bought my eaton from deals a lot with 4x4s and says he runs across these things all the time it seems like. so maybe he finds another one soon enough and I can make it happen. so with a 14bolt locker I just need the shafts cut down a bit and the side gears right?
1971 gmc shortbed, in the middle of a frame up job, accuair e-level, 496 big block, full porterbuilt suspension, intro wheels...way too much work
1967 International Travelette 4x4...aka the coolest truck ive ever owned
1999 cummins ext cab swb 2wd, 200hp sticks, compound turbos. 5"exh. smarty/comp stack, My daily driver.
RangerCB29 is offline   Reply With Quote
Old 02-19-2014, 01:52 AM   #77
Captainfab
60-66 Nut
Here is a build thread where a guy built a Eaton HO52/72 front differential. Unfortunately the build has been canceled and the parts are being sold off. Hopefully a member here ends up with the parts and does something with them.
http://www.67-72chevytrucks.com/vboa...d.php?t=504535
Old 02-19-2014, 01:27 PM   #78
whitedog76
Ranger-
I'm not for sure about the specifics of the 14B locker in the Eaton housing. I saw a link awhile back but can't find it now. I know you have to but down the 14B shafts, but I believe you have to mill a little bit off the locker or differential carrier to get everything to fit. The 14B locker is just slightly wider than the Eaton carrier.
Boyce equipment has 4x4 GMC military axles also. They are seriously heavy duty. Would be kind of cool under a vintage truck though.
whitedog76 is offline   Reply With Quote
Old 02-19-2014, 04:56 PM   #79
RangerCB29
Man that dudes build is amazing. Pm was sent about the eaton front end so we'll see.
Old 02-19-2014, 09:37 PM   #80
whitedog76
That was a pretty good build thread. Seemed like he went overkill on everything though and got burnt out.
Old 02-20-2014, 02:57 AM   #81
swamp rat
swamp rat's Avatar
I PM'ed him about some of his stuff a while back and i think he was selling all the power train stuff locally..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-23-2014, 11:03 PM   #82
RangerCB29
yep. very easy to get burned out. you definitely have to pace urself when ur in the middle of a frame up nuts and bolts kind of job
Old 02-26-2014, 02:52 AM   #83
RangerCB29
Whitedog-so the bearings you have listed will match up if I keep my eaton hubs but use 14bolt axles? I was also wondering if a 14bolt spool would work in one? had a spool in a street car once and it never bothered me a bit. even in rain with drag radials. don't drive like an idiot and you stay between the lines just fine.
Old 02-26-2014, 11:19 AM   #84
whitedog76
Yes, the bearings I listed will work for the Eaton hubs on 14 B full floaters. I went through the Timken catalog to figure it out.
It won't work the other way though. 14 B hubs won't fit the Eaton axle without machine work. The inner bearings/races are compatible, but the outer would need to be machined to take the Eaton bearing.
When it comes to brakes, you will have to get creative. The Eaton hubs, at least the ones I have, don't have as much offset as the 14 B dually hubs.
I've never ran a spool. Can't telly you anything about it.
Old 02-27-2014, 03:20 AM   #85
RangerCB29
cool thanks. There are a couple of places that I have read 14bolt disk brake kits will work on an Eaton.
Old 02-27-2014, 10:33 AM   #86
whitedog76
I think the van disc setup is different from the trucks. The van setup I have came off of a semi float D60. The flange is different than the 14 B. It actually looks like the same flange that the Ford Rearends use. Makes sense, since Ford is still using D60's in 1/2 and 3/4 ton trucks.
I need to get to a machine shop and have one cut, so I can weld it on.
Old 03-10-2014, 01:30 PM   #87
jpyle
Are the brakes shoes you show 13"x 2 1/2" thank you
jpyle is offline   Reply With Quote
Old 04-25-2014, 05:14 AM   #88
71Dually
71Dually's Avatar
Greetings Jeremy,
Thank you for posting the brake swap information. It helped me to come up with a solution for my out of round Eaton drums.
I did the brake swap in a pic-a-part yard and purchased the complete rear end with the 14BFF brakes.
Heres a pic of that Eaton rear end:
I put the larger 13" X 3-1/2" brakes from a 1982 JB8 optioned P30 Step Van. They fit perfectly.
One subject that I have found that has not been touched on here is the Eaton's hub bearing lubrication system. The Eaton uses gear oil to lubricate the hub bearings. I do not know anything about the 14BFF hub bearing lubrication system but it could very well be the same as the Eaton using gear oil from the housing to lube the hub bearings. However, the Eaton axles did use oil slingers to help prevent oil contamination of the brake linings where the 14BFF I pulled the rear brakes from did not. The Eaton drums have two holes to accommodate this in their design and assist in extracting any oil seepage from inside the drums.
A pic of the Eaton drum with the oil slinger holes:
The 14BFF drums do not have these holes.
A pic of the 14BFF JB8 option drums without the holes:
The oil slinger system is a two piece system with a slinger on the axle housing spindle and a slinger on the inner drum flange mating surface.
While it is necessary to remove the slinger off the housing spindle to install the backing plate the pictures you have shown do not have this slinger reinstalled.
Here is a picture with the slinger reinstalled after the 14BFF backing plate has been installed:
A poor pic of the slinger mounted inside the drum (Eaton drum left, 14BFF JB8 drum right) This pic was actually taken to show a comparison of the brake contact surface area between the drums:
A better pic of the slinger that goes on the inside of the drum:
Since this oil slinger design is in the original engineering of the Eaton axle would it not be important or beneficial to retain this design with the 14BFF brake conversion? What do you think?
It would be my conclusion that it would be best to retain this design and drill the holes in the 14BFF drums.
I would accommodate that by mating the drums together with a few lug studs and with a transfer punch transfer the location of the holes to the 14BFF drums. I would then drill 1/8" pilot holes (to retain accuracy and drum balance) and then drill the pilot holes to proper size.
A pic of the drums mated together:
The proper location of the brake drums oil slinger holes:
A transfer punch is used for accuracy to attain the proper hole center locations:
I found wheel fitment and clearance not to be a problem on my 16" wheel dually application. The 16" wheels and wheel weights had plenty of clearance with the 14BFF drums.
A few pics of the wheel to drum clearance:
Lots of space to spare for wheel weights:
Hard to tell from this shot but the clearance is there:
Looking straight down thru the drum wheel clearance you can see the hand hold holes on the opposite side of the budd wheel:
Again Jeremy thanks for the write up. It did help a lot with my conversion.
Hope the info I have posted helps to enhance your presentation.
1971 Chevy C30 Custom Camper Cab Chassis Dually 402 TH400 4.10:1 Eaton HO72
1969 Ford Mustang "Mach 1" 428CJ 4 speed "R Code"
1970 Mercury Cougar "Eliminator" 351C-4V C6
1972 Ford Ranchero GT 351C-2V C6
1974 Honda XL-350
Member of the "6 C's and a D" 1-Ton Fun Club!
71Dually is offline   Reply With Quote
Old 04-26-2014, 11:09 PM   #89
jbclassix
Junk Yartist
jbclassix's Avatar
71Daully, Those pictures are awesome! Thank you so much for posting them!
As for the oil slingers, you are correct. They are added protection and a good safety measure.
Oil contaminated drums or shoes should never be re-used. So directing the oil out of the drums is very smart.
The 14 bolt does use gear oil to lube the bearings, there is no inner-axle seal.
The Eaton and the 14 bolt also share the same hub seal as well.
Again, thank you very much for your contribution to this thread. I hope others find your info very useful.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 06-26-2014, 11:18 AM   #90
jcgrobbe
So from what I've been able to gather, these came with 11, 12, and 13" drum brakes on them, how do I go about identifying the size parts I need to order? Do I measure the ID of the drum, or do I measure the backing plates?
jcgrobbe is offline   Reply With Quote
Old 06-26-2014, 12:08 PM   #91
jbclassix
Junk Yartist
jbclassix's Avatar
The Eaton's came with 11". The drum I.D. will be cast on the drum itself. When measuring rear brakes, measure the I.D. of the drum as well as the depth, or width of the pad. You can convert to the 13" brakes found on 1973+ GM trucks. They are easier to find parts for.
-Jeremy
Rebuilding an NP205
Old 08-12-2014, 04:01 PM   #92
Former member Yoder213
Well my n00bness got the best of me, I purchased DIY4x4's 14bff disc brake swap after being told I had the 14bff, then the next shop told me I had the GM 10bolt. Now after looking around some more I have the Eaton.
Wouldn't it just be lucky if the 14bff disc swap worked for my Eaton? I've got the Detroit lock and just put discs on my front d445cf (disc parts from the 14bff's matching d445cf) and really didn't want to play around with matching gear ratio's.
thanks for the info everyone, I absolutely love this site
Former member Yoder213 is offline   Reply With Quote
Old 08-12-2014, 04:40 PM   #93
swamp rat
swamp rat's Avatar
If memory serves, most of the brackets for a 14 bolt will bolt right up to the Eaton, then all you need are stock 72 front rotors.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 08-12-2014, 04:52 PM   #94
This is just a really lucky mishap then, I have the rotors, calipers, and m/c ready to install. think I'll need new lines though. drop in the bucket.
Old 08-13-2014, 12:29 AM   #95
Captainfab
60-66 Nut
Yes I believe the 14 bolt caliper brackets should bolt up to the Eaton HO52/72. However you might want to confirm that with Kert at DIY4x, in case there might be something different about his brackets that prohibit that.
Old 08-14-2014, 09:51 AM   #96
jbclassix
Junk Yartist
jbclassix's Avatar
Can you please post pictures when you are done. Seems we get this question a lot. Yes, The 14 bolt disc swap will fit.
-Jeremy
Rebuilding an NP205
Old 09-18-2014, 08:45 PM   #97
truckeez
Originally Posted by Longhorn 70 View Post
Jeremy, first thanks for posting and accepting questions on this subject.
I have recently converted the front drum to disc on my 1970 C20. I would like to stop better and have the same size studs on the rear as well as install a locker. I take it from reading that I have an EATON FF rear. What would I need to change to go to 13" brakes and bigger stud hubs and have my brakes work? Would it be better to get a disk kit from someone like BlackBird and go to disc? Or should I look for a newer rear end with brakes, locker and all in it?
Thanks in advance,
Vince
i just knoticed someone roughstuff, or roughcountry selling disc brackets for the 14 bolt /and eaton for $50 the kit - uses slide on rotors/ calipers from 75 up 3/4 ton
http://www.ruffstuffspecialties.com/...g/EHO5272.html
truckeez is offline   Reply With Quote
Old 11-02-2014, 01:49 AM   #98
60sIron
60sIron's Avatar
Great post! The drums on my Eaton have been turned to the max. And they're small. I'd love to impove the brakes. It looks that by swaping brakes with a 14 will move the wheels out about an inch on each side. Anyone know if changing to discs will increase the track? I what to keep the wheels where they are.
60sIron is offline   Reply With Quote
Old 11-02-2014, 12:09 PM   #99
jbclassix
Junk Yartist
jbclassix's Avatar
Your brakes, either drum or disc will not affect your wheel mount surface (WMS) on the eaton. Some later 14 bolt full float (14Bff) axles do have slide on drums, but the swap I covered does not include those.
-Jeremy
Rebuilding an NP205
Old 12-03-2014, 01:14 PM   #100
Jvanloon
Have some questions about the ho52 locker. I'd like a locker for my 72 K20, and I don't feel like swapping and machining axle shafts to use a 14bff Detroit. My only option then is the factory locker? What type of locker is it? Cable selectable? And how strong/reliable are they?
Jvanloon is offline   Reply With Quote
