Old 03-06-2014, 06:39 PM   #76
bj383ss
bj383ss's Avatar
Re: 64 C10 Stepside "Jaybird"
Originally Posted by Grizz1963 View Post
Good progress and tool collection Brett.
Thanks Rian.
I got the driver floor pan tacked in this morning. Working on getting the kick panel to fit properly at the top.
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 03-07-2014, 10:50 AM   #77
1963c-10
1963c-10's Avatar
I'll be doing the same thing in a few weeks. Nice job.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 03-17-2014, 08:42 AM   #78
bj383ss
bj383ss's Avatar
Well I started out sandblasting the front of the frame yesterday but the North winds quickly put a stop to that. Blowing in at 27mph. So I switched gears and almost finished welding up the floor pan. I still have a few holes to weld up. Taking the time to let it cool was killing my patience just wanted to keep going and finish.
Metal to metal bondo is going to be my friend on this job. Although no one will ever see any of this once it is done.
Can't wait to get the cab finished so I can pull it and start serious on the frame and suspension.
I start vacation in 11 days. I will be off for 12 days and hope to get all of the cab welded up so I can pull it and start on the bottom of the cab and the frame rebuild. Ordering all of the suspension parts and frontend rebuild on Thursday.
Bret
Old 03-17-2014, 07:46 PM   #79
WhippinSaw
WhippinSaw's Avatar
Nice job repairing the floor in your truck, I looked back at post 17 to get a before and after view, looks good, it really came together nice. Are you using flux core or Gas with your mig welder?
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle.
WhippinSaw is offline   Reply With Quote
Old 03-19-2014, 06:51 AM   #80
bj383ss
bj383ss's Avatar
Thanks Whippinsaw. I started out using Gas but it ran out and my dad didn't want to rent the cylinder anymore as he hasn't used his welder in the last five years so we switched it over to flux core. I find the flux core easier even though you have to do some cleaning after.
I spent 2 hours after work yesterday and got the passenger floor cutout. Should be able to weld the patch in tonight. I found a huge wasp nest in the front cab support!
Bret
Old 03-19-2014, 11:42 AM   #81
TJ's Chevy
TJ's Chevy's Avatar
Looks good!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 03-19-2014, 12:02 PM   #82
1963c-10
1963c-10's Avatar
Nice job on the cab repair. Everything looks like it lined up nicely for you.
Old 03-20-2014, 08:33 AM   #83
bj383ss
bj383ss's Avatar
Thanks guys. It came out alright. I got the passenger side welded in last night. It lined up much better. My first cut was damn near perfect. Instead of using the sheet metal clamps I used the big triangle welding magnets and the made it much easier to lineup up the panel.
Just ordered all my parts for the frontend rebuild and the rest of the cab patch panels I needed. I saved a ton of money buying all my fontend parts from Amazon. All Moog too. The difference between O'riellys and Amazon for all my parts was like $350 difference!
Here is what I bought
upper and lower ball joints
upper and lower control arm shaft assemblies
Inner and outer tie rod ends
rear control arm bushings (polyurethane)
track arm bushings (polyurethane)
Idler arm
Pitman arm
I also bought a new ram jack for my engine hoist since it already failed after only 2 uses and some metal to metal bondo from Evercoat And a 9/16" drill bit for the lower control arm u bolt upgrade.
Bret
Old 03-20-2014, 08:36 AM   #84
Grizz1963
Grizz1963's Avatar
Good progress
Amazing how much money you can save shopping around.
Will call you again sometime when I am awake late so it takes up the time difference.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 03-20-2014, 09:53 AM   #85
Mikes66ChevyC10
Mikes66ChevyC10's Avatar
Great job repairing your cab. Looks like you didn't have to replace your cab supports? Also like the sand blasting booth you made up! Think I will do the same!!
1966 C10 Stepside swb
http://67-72chevytrucks.com/vboard/s...d.php?t=617778
Mikes66ChevyC10 is offline   Reply With Quote
Old 03-20-2014, 10:19 AM   #86
bj383ss
bj383ss's Avatar
Thank you Mike. No sir the cab supports where good which I am very thankful. My cab rot was really not that bad. The rear cab corners are good with only a few pin holes. The rot in the floorboards would have been less if they had been repaired correctly. The driver side just had a piece of galvanized steel plate spot welded over the rust and made it worse. The passenger side was patched with fiberglass very poorly and then the footwell was riveted to the firewall! I did coat the front cab supports with a rust coating since I could access them.
Bret
Old 03-20-2014, 10:24 AM   #87
Ta2Don
Ta2Don's Avatar
Sure don't know how I missed your build, but I am caught up now….
I would be seriously concerned about your boy that's in a pic on page 1… He looks deep in thought, mmmm what can I do to get this away from dad??? Just joking! Great bonding time!
Sandblast booth... consider that plan stolen...
Very Nice on the cab repair...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 03-20-2014, 03:54 PM   #88
bj383ss
bj383ss's Avatar
Thanks Don. Its funny you should notice that as my ultimate goal is to build this truck for my boys to enjoy when they get older. They are 5 and 7 so I have some time. The one in the picture is the 5 year old and he loves being in the garage and helping with everything. He is going to be a maker for sure.
Of course I am going to enjoy it as well until they are old enough too.
Bret
Old 03-23-2014, 05:39 PM   #89
bj383ss
bj383ss's Avatar
I spent some time this morning working on the passenger fender. I guessed it was hiding some damage as the core support on that side was damaged a little. From then inside there were several holes with bondo coming out of them and about a 3/4" deep dent. OUCH.
I cleaned off all the bondo
I had to remove this brace to have access for the hammer on the inside
This is what I ended up with after some hammering. Not to bad will still require some bondo but not 1/2" thick at least
I switched gears after that and starting stripping all the front suspension. Here is where I ended for the day.
Bret
Old 03-24-2014, 01:34 PM   #90
1963c-10
1963c-10's Avatar
nice...I'll be there in the next week or two myself.
Old 03-25-2014, 09:16 PM   #91
bj383ss
bj383ss's Avatar
I have got all my goodies for the front end except the idler arm. Should be here in the next couple of days. Also still waiting on my patch panels from Top Banana
Here is all the stuff I bought on Amazon.
One more 10 hour shift and then I'm on vacation for 12 days!
Bret
Old 03-25-2014, 09:25 PM   #92
bj383ss
bj383ss's Avatar
This is a quick video I made last year before the tear down. I don't think I ever posted it
https://www.youtube.com/watch?v=P8rx...6b8e0CcGKJNG_Q
Bret
Old 03-25-2014, 09:44 PM   #93
pdxhall
pdxhall's Avatar
That's a great stack of parts you got there! I'll bet you can't wait to get started. I just finished vacation and didn't do a thing to the truck. Just played.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 03-25-2014, 10:18 PM   #94
TJ's Chevy
TJ's Chevy's Avatar
Nice stock of parts there! And good work!
Old 03-26-2014, 09:55 AM   #95
Ta2Don
Ta2Don's Avatar
Parts, Parts, and more Parts...
DON
Proverbs 27:17
Old 03-26-2014, 10:36 AM   #96
aggie91
I'm just glad to be here!
aggie91's Avatar
Looks like you are going to be able to get some stuff done vacation!
BTW those are some cool wood projects on you bench. Did you make them?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-26-2014, 06:29 PM   #97
bj383ss
bj383ss's Avatar
Yes sir. Woodworking is my other serious hobby. I build mostly furniture and scale models. I spent almost 10 months building the steam train.
And last summer I had a little time frame with rockets. They are pretty simple to make on the lathe and a lot of fun.
Mark I
Mark II
Mark III
Mark IV This was my favorite one.
I also spent a year making this 1/10 scale Scania Truck
and my 1/10 scale small block Chevy for the 32' Ford I'm building.
Bret
Old 03-26-2014, 07:18 PM   #98
Ta2Don
Ta2Don's Avatar
Awesome Woodworking!!!
GRIZZ Needs to see this...
DON
Proverbs 27:17
Old 03-26-2014, 07:35 PM   #99
TJ's Chevy
TJ's Chevy's Avatar
WOWZA! That's some sweet work you are doing! I wanna buy the steam train!!!!!!! LOL! Nice job!
Old 03-27-2014, 09:52 AM   #100
aggie91
aggie91's Avatar
Your woodworking skills are top notch. My grandfather built custom cabinets after he retired from the fire department. I wish I could have learned more from him before he passed away. Your attention to detail on those projects is awsome!
Karl
The LST Challenge:
