Old 06-23-2014, 03:03 PM   #76
Lowl!f3
Lowl!f3's Avatar
Re: 1965 C10 Long Bed
Yeah Thorbros has been behind since 3 or 4 years ago. There is people waiting on stuff still.
1965 C10 Project
Lowl!f3 is offline   Reply With Quote
Old 06-29-2014, 08:08 PM   #77
Lowl!f3
Lowl!f3's Avatar
Today CCP billed me for my 5 lug conversion. So guess thats a week out from delivery. Also ordered poly trailing arm bushings from brothers truck.
So today I finished cutting out for my pancake.
1965 C10 Project
Old 07-03-2014, 11:15 PM   #78
Lowl!f3
Lowl!f3's Avatar
Yeah! My Brothers Truck order came in and so did my CCP conversion kit.
1965 C10 Project
Old 07-04-2014, 05:16 PM   #79
Lowl!f3
Lowl!f3's Avatar
Messed around a bit and painted the drums so they didnt rust up .
1965 C10 Project
Old 07-06-2014, 06:30 PM   #80
Lowl!f3
Lowl!f3's Avatar
Yay happy birthday to me . To bad ima at work tonight.
1965 C10 Project
Old 07-06-2014, 10:30 PM   #81
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Happy B-day bud! WOW!!! Green brake drums! WOW! LOL!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 07-07-2014, 05:21 PM   #82
Lowl!f3
Lowl!f3's Avatar
Lol thanks.
And today I painted the rearend pan Green Oh and picked up replacement springs for the rear brakes.
Look some of the springs are already painted lol
1965 C10 Project
Old 07-08-2014, 01:05 AM   #83
Lowl!f3
Lowl!f3's Avatar
Why is porterbuilts step notch $500? That seems way over priced.
1965 C10 Project
Old 07-08-2014, 09:30 AM   #84
aggie91
I'm just glad to be here!
aggie91's Avatar
There is a lot too the PB Step Notch. It is more than just a few pcs of steel you have to weld together. Theirs is a complete BOLT IN set up.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 07-08-2014, 02:54 PM   #85
Lowl!f3
Lowl!f3's Avatar
Yes but dont you think thats way over priced for a step notch?
Anyway I got out there and tacked up my crossmember today before the rain kicked off.
1965 C10 Project
Old 07-08-2014, 03:25 PM   #86
aggie91
aggie91's Avatar
Depends on how you look at it on the step notch. With your fabrication skills, the unwelded cut parts that are available from ************* or other places for $150 would be fine. But on the other hand if you don't have a welder or just want something that will bolt in with hand tools and a sawsall, the PB kit is the ticket since it is fully welded and comes with all the hardware.
For me, since I like to fab stuff and have most of the tools I need, I would just buy some 3/16"-1/4" plate at a scrap yard and make up my own...
Karl
The LST Challenge:
Old 07-10-2014, 06:56 AM   #87
Lowl!f3
Lowl!f3's Avatar
I definitly have a welder brother lol. And yes im looking for the notch with the bends for around $150. I have one now that does not have the bends and can be used with more fab work making it fit. However, I would rather use the extra work somewhere else on my truck.
Just FYI for anyone. The pancake is a 2 inch pancake. After tacked back together. The measurement is 1-7/8 inch. So it should be close enough for a first timer on pancaking .
And man oh man was I itchy after 3 cut off wheels cutting it out hahah.
1965 C10 Project
Old 07-13-2014, 11:40 AM   #88
Lowl!f3
Lowl!f3's Avatar
Well im still welding up my crossmember. Still have some more grinding and welding to go.
1965 C10 Project
Old 07-13-2014, 08:25 PM   #89
Lowl!f3
Lowl!f3's Avatar
Today I welded up a little more of the crossmember and cleaned up some of the brake parts and painted them.
If any of you guys have metal parts you want cleaned to tje metal. Soak it in white vinegar for a few days. Be warned tho. If you soak smaller parts such as E clips and thin washers. It will eat them completely away. Such as the small washer and E clip that holds the E brake level to the brake shoe.
After you get the parts out of the vinegar. Clean them with soap and water as soon as possible and wire brush then dry them. Then paint.
By the way. The vinegar freed up the seized brake adjuster also. It was stuck big time and I was thinking I may have to find new ones. However it ate all the rust from the thread and it screwed right apart fairly easy.
1965 C10 Project
Old 07-16-2014, 08:08 PM   #90
jayoldschool
Moderator
I keep a bucket of vinegar (case bought at Costco) for derusting. Toss in parts, take out a few days later. Easy, cheap, works.
jayoldschool is offline   Reply With Quote
Old 08-12-2014, 06:45 PM   #91
Lowl!f3
Lowl!f3's Avatar
Been to hot and raining since I posted last. Did a little gringing yesterday on the crossmember. Removed one of the rear springs and installed my new vice on my fab table. Going to buy a shop fan this payday to help with the heat so I might be able to hack it.
1965 C10 Project
Old 08-15-2014, 12:23 AM   #92
Lowl!f3
Lowl!f3's Avatar
Well here is a video update on youtube of how she sits right now. Went out today and picked up a few things. https://www.youtube.com/watch?v=FWTZ...e_gdata_player
1. A shop fan that moves some air. Now im in the cool.
2. I also picked up some discs for the grinder. Lors knows we cant pass up on those being in stock at the house.
3. 4 used tires that I will use to mock up my suspension. Then it will be white walls afterwards.
4. 3 pieces of 3/16 plate for the lower control arms and trailing arm crossmber.
Images of todays material.
1965 C10 Project
Old 08-15-2014, 10:28 AM   #93
Realnoisy
Realnoisy's Avatar
Looking good!
A spirit with a vision is a dream with a mission - Neil Peart RUSH
Realnoisy is offline   Reply With Quote
Old 08-15-2014, 12:53 PM   #94
Lowl!f3
Lowl!f3's Avatar
Originally Posted by Realnoisy View Post
Looking good!
Thanks Mark
1965 C10 Project
Old 08-15-2014, 09:57 PM   #95
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Coming along...and looking good! lol!
Old 08-17-2014, 02:07 AM   #96
Lowl!f3
Lowl!f3's Avatar
Thank you. I know it's not fast. However it is moving. Order my step notch from grant kustoms.
Today I popped the rearend out. Going to clean it up and install my 5 lug axels and spider gears.
1965 C10 Project
Old 08-17-2014, 10:37 PM   #97
Lowl!f3
Lowl!f3's Avatar
Today a little more progress. Pulled the rear end out to the driveway and pressure washed it a bit.
Removed the trailing arms and other axel, brakes and drum. Put all parts into vinegar to clean them up real well.
1965 C10 Project
Old 08-19-2014, 09:57 PM   #98
Lowl!f3
Lowl!f3's Avatar
Today after work I replaced the outer axel bearings and seals. Cleaned up and painted the rearend. Installed the spider gear set & 5 lug conversion axels. Then put the cover on.
1965 C10 Project
Old 08-20-2014, 01:03 AM   #99
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
Looking Good Bro. Just read thourgh the whole thread.... I'm Diggin the green Drums and Cover... Just down the Road from You.... Chris..
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 08-20-2014, 07:04 AM   #100
Lowl!f3
Lowl!f3's Avatar
Hey thanks man. You wouldnt happen to be the guy that knows Mark out of houston are you? His tag on here is Realnoisy.
1965 C10 Project
