Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 06-16-2015, 03:54 AM   #76
Cobalt964ruf
Cobalt964ruf's Avatar
Re: 1971 K30 burb - LS3, 4l80e, np205, Dana 70f, 14bff, Detroit lckrs, 4"lift, 35" BF
hey guys, its been slow going. but have got some progress done on the truck. here is the new steering shaft I built from scratch from parts I had laying around the shop.
1971 K30 burb carbed LS6 th400 np205 d70f 14bff 4whl discs lifted 35 bfg's
1994 k3500 rcsb trophy truck ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1998 K3500 rclb ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1999 k3500 crewcab dually 4x4 496ci 4l85e bw4401 9.25ifs 14bff g80 6" lift 37 bfg's
Cobalt964ruf is offline   Reply With Quote
Old 06-16-2015, 03:59 AM   #77
Cobalt964ruf
I also now have the griffin 4 core aluminum radiator in it, still need to build a fan shroud tho. and I have the lift springs on it too. todays pic with lift. the lift is all springs, no blocks. I flipped the rear shackles. it still sags about 1" in the back so I have a set of m1028 1.25ton military chevy pu rear springs that will raise it about 1.5" in the rear.
Old 06-16-2015, 04:02 AM   #78
Cobalt964ruf
Originally Posted by tedfrk View Post
Just wondering what year rears your bolting in there ,I want to do the same swap
73-87 are a bolt in. at least mine was. the rear axle in it right now is out of a 78 3/4t truck. but I have one from a 1995 1 ton with g80 Detroit in it. that is going in it next with the dana 70 front. the 95 rear axle will require spring perches to move a bit but not bad.
Old 06-16-2015, 01:30 PM   #79
LockDoc
The Older Generation
LockDoc's Avatar
Glad to hear you are making progress on it..... Keep us posted.
LockDoc
Leon
Old 06-16-2015, 04:01 PM   #80
NorCalAnthony
+1 Truck is looking great. Keep up the good progress
NorCalAnthony is offline   Reply With Quote
Old 06-16-2015, 09:26 PM   #81
Cobalt964ruf
thanks for the support guys.
Old 06-17-2015, 09:29 PM   #82
Average Joe
Average Joe's Avatar
Originally Posted by norcalanthony View Post
+1 truck is looking great. Keep up the good progress
x2!
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 06-26-2015, 02:37 AM   #83
Cobalt964ruf
worked a bit on it the last few days. new rancho extended shocks all around. new leaf spring grade 8 bolts all around. got a new aluminum oil pan, new aluminum trans pan, new aluminum timing cover. gonna fix some leaks here in the next few days.
Old 06-26-2015, 03:23 AM   #84
Cobalt964ruf
oh and I have the serpentine setup off a 94 im going to adapt to the old 350 as well when I do the timing chain/gears, and timing cover.
Old 06-26-2015, 09:13 AM   #85
lowrodderchev
lowrodderchev's Avatar
How about some pix
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 06-27-2015, 06:07 AM   #86
Cobalt964ruf
Originally Posted by lowrodderchev View Post
How about some pix
post 77 is a pic from last week.
Old 06-27-2015, 06:09 AM   #87
Cobalt964ruf
today; walmart battery crapped out, had to go get a new one. no cost was under warranty tho.
Old 08-20-2015, 10:36 AM   #88
Justin@EntropyRad
Justin@EntropyRad's Avatar
beast!
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 08-21-2015, 03:52 AM   #89
Cobalt964ruf
Originally Posted by Justin@EntropyRad View Post
beast!
thank you for the compliment Justin
Old 08-21-2015, 04:06 AM   #90
Cobalt964ruf
I have been daily driving the burb for the last week. my regular daily driver went on to its next owner.
Old 10-06-2015, 03:45 AM   #91
Cobalt964ruf
pulled the dana 44 hd front axle today. and installed the dana 60 hd/d70 front.
Old 10-06-2015, 03:47 AM   #92
Cobalt964ruf
I have been daily driving the burb for a few months now. running good, very reliable. no so concerned about the appearance of it yet. still changing the mechanicals. soon will be rear disc conversion, and ls swap/4l85e/np205.
Old 10-08-2015, 05:15 AM   #93
Cobalt964ruf
ok... progress turned into 20 steps backwards today... got the dana 70 front axle install done only to find out the truck had only been driving as a front wheel drive since I bought it apartently. it has a th350, np203, and had a old dana 44hd that did not have lockouts. so it was a full time 4x4. when I put the 60hd/70 in it I of coarse unlocked the hubs as I could now drive it as a kinda 2wd until I needed the front axle locked in. it just sat there in its tracks and would not move. apparently the 203 is toast. only sends power to the front wheels. so I relocked the hubs back in and it moved again. but it would only go straight. try to turn it and the power steering pump would go nuts. the front 60hd/70 does have a locker in it. so im going to have to put ram assist on it now. and to make matters worse the 60hd/70 needs new kingpins and bushings.... ugh.
Old 10-08-2015, 07:15 PM   #94
Average Joe
Aint that the way it goes sometimes. Glad to hear you are making progress. That will be a serious wheeler when you get your transfer case sorted out.
Old 10-09-2015, 01:13 PM   #95
Cobalt964ruf
hey average joe, yep seems like that's how it goes all the time lol. but I have a rebuilt np205 that I built already. but wasn't really wanting to dig that deep in the truck yet as it was pretty much a daily driver... so I thought. now it will be major surgery. cause I also have a rebuilt ls motor, rebuilt 4l85e, and rebuilt np205 to go in it. but if im in it that deep likely will clean and por15 and detail the frame, clean and paint the engine bay. just wasn't ready to go this deep. ugh
Old 10-25-2015, 04:14 AM   #96
Cobalt964ruf
got a new steering hydraulic ram. building a new steering gearbox with an fittings for hydro steer.
Old 10-26-2015, 05:17 AM   #97
Cobalt964ruf
rebuilt the Saginaw steering box with new Saginaw parts. also drilled and tapped the pressure port side and return port side with 2 6an fittings for the hydraulic steering assist ram.
Old 11-20-2015, 03:45 AM   #98
Cobalt964ruf
motor, trans, and transfer case coming out this weekend. prepping truck for the ls/4l80e/np205 swap
Old 11-20-2015, 10:40 AM   #99
lowrodderchev
I envy you I want to do that to my truck it ain't cheap though
Old 11-21-2015, 02:35 AM   #100
Cobalt964ruf
i agree, give it time you will get there.
