Old 08-16-2015, 09:04 PM   #76
flashed
Re: "Oaky" Farm Fresh '73 Short Step
And it is still where you left it .
flashed is offline   Reply With Quote
Old 08-17-2015, 12:01 PM   #77
GAc10boy
GAc10boy's Avatar
Thanks for watching over it. I'll be up that way with new wheels/tires soon.
- Robbie
UNITED BY TRUCKS - classic truck video content
YouTube: www.youtube.com/c/unitedbytrucks
Instagram: @united_by_trucks
Paw Paw '68 508 Dark Blue Custom C10
Teddy '68 GMC SWB 503 Light Green LS Build
Mississippi Mud '75 Skyline Blue Patina SBC Build
GAc10boy is offline   Reply With Quote
Old 10-09-2015, 04:10 PM   #78
aggie91
I'm just glad to be here!
aggie91's Avatar
Don't know how I missed this one Robbie, but I like it. That stuff on the paint was WAY worse than what I had to deal with on White Trash...
Have you gotten the brakes worked out yet?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 10-09-2015, 04:59 PM   #79
flashed
I think Robbie is M.I.A. ,I wonder what he is up to.
Old 10-12-2015, 08:29 PM   #80
GAc10boy
GAc10boy's Avatar
Hey, guys! Thanks for checking in. I've been super slammed lately but I'm still here.
Aggie91 - I'm just glad I was able to get it off and preserve what paint was actually there. As for now, I haven't even touched the brakes and it's sitting in my garage. I do manage to crank it up every week or two though. I need to get back on it!
- Robbie
Old 10-12-2015, 08:41 PM   #81
flashed
So what is the word on Big Al ?
Old 10-13-2015, 11:36 AM   #82
GAc10boy
GAc10boy's Avatar
Big Al is now enjoying his new home with Number98. He's already been making a few upgrades and has more planned to make it a good driver.
- Robbie
Old 10-15-2015, 03:56 PM   #83
burger
Have you torn into your 307 yet? At one point my 307 had a very similar combination of parts to what you've listed (-416 heads and a Comp 262XE). I didn't really like it. There's not enough torque to move the truck around. If I were to use those heads again, I would match them to this Ultradyne cam:
254/262 112 .401/.432 199/207 Great in 305's bigger & better mileage and power. Smooth idle, broad power range. Works with stock valve train, power accessories. Biggest cam recommended for high altitudes. Great in 305 IROC-Z with TPI. IDLE-4800
The Ultradyne cams are now manufactured by Lunati. Here's a link to the cam at Lunati's site
Here's a quote from UDHarold, the cam designer:
Lunati 301A1LUN--254/262 at .0045, 199/207 at .050, .401/.427 valve lift, and 112 LSA.
This cam has won the SCCA Stock championship twice, and never been detected by a emmisions sniffer while winning. Putting it into a stock 305 TPI IROC-Z gives a 35-HP gain, and power increases from idle to about 5000. Blueprinted 305 IROC-Zs get about a 55-HP gain. In 305 pickups the mileage is increased and overall power is very noticably increase. It would work in your engine.
Food for thought! Great looking truck, by the way.
41 chevy
70 skylark
85 c4
dumb house that always needs work
4 stall detached car hole
burger is offline   Reply With Quote
Old 10-16-2015, 11:34 AM   #84
GAc10boy
GAc10boy's Avatar
Thanks, burger! Based on overwhelming recommendations, I'm planning to use the Lunati 60101 (<---- old p/n) (256/262, Lift .454/.468) also developed by UDHarold for Lunati. It's powerband is supposed to be from idle to 5500 rpm and I already have the heads, springs etc set-up for that cam/lifter set. The machinist/engine builder who did my heads said he had a similar set-up in a c10 and it really surprised him. He also encouraged me to leave the intake valve at 1.84 instead of opening it up to 1.94 so as to maintain torque (and better gas mileage). Based on what I've read and the head gaskets purchased (Fel Pro #1094), I'm expecting my CR to be between 9.6:1 and 9.8:1. I'm no engine building expert but I do a ton of research and ask a ton of questions and this seemed to be the best route and consensus among many.
I'm just getting started back up on this truck and ordered a new rear brake line so I can just cut the old wheel cylinders out and ordered all my gaskets for the rebuild (oil pan, heads, and valve covers). I'm starting to get pumped about this ride again. Still need to purchase cam, intake and have my quadrajet rebuilt by Cliff Ruggles.
- Robbie
Old 10-16-2015, 02:10 PM   #85
burger
I hope the cam works out for you! The 262XE, which is 218/224@.050, doesn't really start to make power until 3000 RPM in a 307. It pulled hard from there out, but still a meager 16.0 1/4. It was just too soft from a dead stop. Somewhere along the line I put in a 2800 RPM converter. At full throttle, that completely covered up the flat spot, but made the truck a real dog for normal driving, especially up hills. I never took it to the drags on that configuration unfortunately.
You're picking a smaller cam so I think you'll have better results.
41 chevy
70 skylark
85 c4
Old 10-16-2015, 03:28 PM   #86
GAc10boy
GAc10boy's Avatar
I'm really hoping it works out, too. I'm running a stock converter which Lunati and others said should be fine. We shall see. I can always put in a converter and change gear ratio if necessary. This will just be a shop truck so I'm not necessarily looking for gobs of power but I do hope it's strong enough to get out of its own way.
- Robbie
Old 10-16-2015, 03:57 PM   #87
burger
The 262XE was too big for the stock converter. I would get a massive RPM drop from park to drive, meaning that I would set the idle at 1200 RPM in park and then it would die down to an unsteady 650-ish when put in gear. That made tuning the carb a bear, as the transfer slots were open too far with the idle screw turned in that much. Those issues (and my part throttle driveability) went away with the loose converter.
I want to say again that I really like your truck. The 4/6 drop and 15" steel rims really do it for me.
41 chevy
70 skylark
85 c4
Old 10-16-2015, 09:48 PM   #88
GAc10boy
GAc10boy's Avatar
I really appreciate that! I'm hoping to powder coat the steelies black and the caps white very soon. I think that will really clean it up and make it look sharp. I'll eventually paint the entire truck white with saddle interior but until then I'll rock the crazy patina/multi-layered paint.
- Robbie
Old 10-16-2015, 10:14 PM   #89
burger
Any plans to restore the interior? A recovered seat and new dad pad would do wonders! The problem is that I just listed $800 worth of upgrades! Might be cheaper to find good used parts.
41 chevy
70 skylark
85 c4
Old 10-16-2015, 10:18 PM   #90
burger
Btw, my 73 came from the factory with white steel rims and the same white hubcaps that you have. I have rally rims now, but I'm thinking about going vac to the white rims as it is time for new tires.
41 chevy
70 skylark
85 c4
Old 10-17-2015, 02:24 PM   #91
GAc10boy
GAc10boy's Avatar
I'm definitely planning to do the interior eventually. I'll ultimately do carpet, door panels, and seat. As of now, I'm more worried about the drivetrain so it'll be a bit before I get to the interior. That stuff is expensive.
I love the steelies on these trucks. I got your pm and tried to message you back but it's full. Just text me when you can and we can chat.
- Robbie
Old 11-03-2015, 06:30 PM   #92
Hankster
Hankster's Avatar
Following,
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 11-03-2015, 08:10 PM   #93
burger
Hey Robbie,
Any updates?
Ed
41 chevy
70 skylark
85 c4
Old 11-07-2015, 07:43 PM   #94
GAc10boy
GAc10boy's Avatar
Hey, Ed - I've been runnin around crazy lately but I have been ordering a few parts this weekend to get the motor running well. I bought some Doug's longtube headers, edelbrock EPS manifold, K&N X-Stream Air Cleaner Kit, and the Lunati 60100 cam and lifter kit. All I need to figure out is my carb. Either going to have Cliff Ruggles build my quadrajet or buy an Eddy 1406.
Thanks for steering me in the right direction on the cam. You're the reason I found some longtubes that tuck up in the frame to help keep some of the torque intact instead of the shortys.
- Robbie
Old 11-13-2015, 11:57 AM   #95
slammed427
slammed427's Avatar
Sweet stepper with a cool story. I'm in.
74 C10 LWB 350/T5 Dropped on 20's
Soon to be Bagged and Injected
84 C35 Crew Cab Dually. 454/400 Dropped a lot.
Instagram: mmmdropp
slammed427 is offline   Reply With Quote
Old 11-13-2015, 11:12 PM   #96
GAc10boy
GAc10boy's Avatar
Thanks, slammed427.
Got some new parts today. More to come.
K&N X-Stream Air Cleaner kit
Doug's D-310 Longtube Header (will ceramic coat black)
Edelbrock EPS Manifold - returning since I decided to use my Quadrajet
Bought Edelbrock 2101 Performer manifold for Quadrajet
Sending Quadrajet to be built by SMI
- Robbie
Old 11-13-2015, 11:36 PM   #97
flashed
Them are some nice looking parts .
Old 11-14-2015, 08:04 AM   #98
rusty76
rusty76's Avatar
Cool
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 11-14-2015, 09:08 PM   #99
GAc10boy
GAc10boy's Avatar
Originally Posted by rusty76 View Post
Cool
Thanks, guys! Got him out and ran him down the driveway and down to the next street but the brakes still really need some work. The rear drum is sticking and the pedal is definitely not consistent. I'm hoping to get them all sorted out in the coming weeks and then begin the tear down.
SMI is going to be 6-8 weeks on my carb so I have a bit of time.
- Robbie
Old 11-23-2015, 02:48 PM   #100
blake's first
blake's first's Avatar
Hey Robbie this is Joe Blake's uncle .. I need a little help..how do you get the blue letters on your thread so they can be clicked on to go to your thread
blake's first is offline   Reply With Quote
