Old 09-24-2015, 03:06 PM   #76
zellway
zellway's Avatar
Re: What did you do to your Suburban Today?
How did I miss this one?! I have been posting on the truck side. I can't say I did much more then drive it like I have the past few years. I did use it as a truck if that counts?
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline   Reply With Quote
Old 10-05-2015, 12:05 PM   #77
Dburger
Dburger's Avatar
Drove one of them. 99% original 78,000 mile 1969 Suburban vs. flood water...
1953 Suburban Carryall 3106, 1993 S10 4x4 ext cab
1958 Suburban Carryall 3116 ex school bus
1959 Apache 36, 1984 C30 3+3 DRW 6.2 4MT
1967 C10 fleetside LWB, 1969 Chevy Suburban C10
1972 GMC Suburban C10
1972 Chevy Suburban C10 clam shell/tailgate
Dburger is offline   Reply With Quote
Old 10-06-2015, 09:03 AM   #78
highwinger
highwinger's Avatar
I replaced the starter last night. My solenoid bat terminal was loose and became inconsistent cranking. I replaced with the newer, smaller, higher torque (http://www.summitracing.com/parts/PWM-9112) starter. Of course things are never easy. I had to remove the dust guard because it was scraping when I accelerated and/or turned (only made it one house down). It also starts great when cold but wouldn't restart after I got to work. I noticed last night it was slower after a short test drive.
highwinger is offline   Reply With Quote
Old 10-06-2015, 11:57 AM   #79
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Took the hubs off my dana 60 after finally getting the right spindle nut socket.
Progress is slow at the moment. I think I might spend some time detailing the engine bay, etc while I save funds for the next steps.
https://www.youtube.com/watch?v=y-yTvQLBJ5I
68SWB4x4 is offline   Reply With Quote
Old 10-07-2015, 09:23 PM   #80
sierragrande71
sierragrande71's Avatar
Finished buffing out most of the paint with rubbing compound and installed the 15x5.5 steelies on the front with a slightly smaller tire for more a rake look still need to install the drop spindles and do the disc brake conversion. Ignore my dead grass (due to the drought and higher water rates)
sierragrande71 is offline   Reply With Quote
Old 10-09-2015, 02:00 PM   #81
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Sweet stance!
All the plants are dried up here as well, Can barely keep the succulents alive
Old 10-10-2015, 10:06 AM   #82
Number98
Prestige Worldwide
Number98's Avatar
Looking good!
Number98 is offline   Reply With Quote
Old 10-11-2015, 01:23 AM   #83
71_Burb
Very Nice sierragrande71 ..
71_Burb is offline   Reply With Quote
Old 10-11-2015, 05:54 AM   #84
Cobalt964ruf
Cobalt964ruf's Avatar
finished the dana 70 front axle install this week... didn't turn out as planned. never does. but nonetheless... more work, more work, lol
1971 K30 burb carbed LS6 th400 np205 d70f 14bff 4whl discs lifted 35 bfg's
1994 k3500 rcsb trophy truck ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1998 K3500 rclb ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1999 k3500 crewcab dually 4x4 496ci 4l85e bw4401 9.25ifs 14bff g80 6" lift 37 bfg's
Cobalt964ruf is offline   Reply With Quote
Old 10-11-2015, 11:39 AM   #85
sierragrande71
Thanks everyone for the compliments! This is what she looked like before I got her.
Old 10-12-2015, 10:21 AM   #86
highwinger
highwinger's Avatar
How to install a starter in only 6 days...
Wow, what a task that ended up being. I was able to physically install the starter last Monday night, but it took the rest of the week to get it right, specifically the wiring. I "upgraded" to the newer gear ratio starter which costs more but is smaller, lighter, less current and spins faster. I wasn't aware they are more sensitive to voltage. I rewired the electric fans to be off during start (when hot), I rewired the bat + & - increasing to 2awg wire. After all that, I still had to rewire the solenoid wire to go thru a relay. This gets the starter & solenoid voltage up over 11V...finally...and cranky very quick. I still have to reinstall the dust cover.
I also did a lot of timing gyrations thinking the initial timing was loading the engine too much which in turn was slowing the crank. In doing this, I did see the harmonic balancer seal coming out and a new plug wire gone from an exhaust manifold crack...my next week's entry in this thread.
Old 10-19-2015, 09:35 AM   #87
4shongo
Installed drilled and slotted rotors, new drums, new wheel cylinders, new ceramic pads/shoes, drum spring kit, new wheel bearings/seals. It was a busy day. Huge improvement!! Glad I will not have to do that for a long time!!!!!!
4shongo is offline   Reply With Quote
Old 10-19-2015, 10:29 AM   #88
highwinger
highwinger's Avatar
... I still have to reinstall the dust cover.
I spent Saturday getting those things taken care of. Although there wasn't a noticeable difference, there was definitely a comfortable feeling know some issues were resolved.
Old 10-20-2015, 10:54 PM   #89
rocknss
rocknss's Avatar
Replaced the windshield washer pump and all hoses for the windshield washer.
Steven
69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners
2017 50th Anniversary Camaro SS
2004 Chevy Impala LS
2016 Chevy Malibu LT
rocknss is offline   Reply With Quote
Old 10-21-2015, 01:25 AM   #90
71_Burb
I started carpeting the rear and made some new side panels along with that installed some rear Morel 6 1/2 coax. Still need to finish it off since my dogs ride back there figured should clean it up
Old 10-28-2015, 08:35 PM   #91
sierragrande71
Did a 5 lug and disc brake conversion with drop spindles from belltech.
Old 10-29-2015, 10:06 PM   #92
Waders
Waders's Avatar
Unhappy Re: What did you do to your Suburban Today?
Today when I walked by the ol burb I noticed a good layer of dust so I wrote "wash me" on the back window. The next time I walked by I crossed it out and wrote "finish me"
71 GMC swb 4x4 ...sold
72 suburban "family cruiser" in progress
67 chevy blazer truck
59 Chevy belair 2dr-high school sweetheart
Waders is offline   Reply With Quote
Old 11-01-2015, 04:01 PM   #93
Advanced Design
Advanced Design's Avatar
It was so nice today we took the Burb to town with our Grandkids to celebrate my wife's birthday.
Advanced Design is offline   Reply With Quote
Old 11-12-2015, 12:10 AM   #94
sierragrande71
Kinda of an odd idea but something I've been pondering with the theme I'm going for, using a gun rack to haul vintage skateboards, the one pictured is not vintage however just for looks until I find an old 70's longboard.
Old 11-12-2015, 12:12 AM   #95
sierragrande71
I also just rolled the suburban on to the street to sweep out the garage
Old 11-13-2015, 02:21 PM   #96
missionstreettattoo
missionstreettattoo's Avatar
well i caught mine on fire last night, from hot wires left hanging under the dash from the previous owner. so i added an amazingly real "been on fire" smell to my truck!
missionstreettattoo is offline   Reply With Quote
Old 11-13-2015, 04:28 PM   #97
Advanced Design
Oh wow...hopefully minimal damage!
Old 11-13-2015, 06:08 PM   #98
missionstreettattoo
i believe i put it out before it went crazy.
Old 11-16-2015, 01:42 AM   #99
67 Burb
67 Burb's Avatar
Because the weather was so nice, I took him for a little 150 mile cruise around S.W. Manitoba with a few other car guys and gals.
Bob
1967 2wd Burb, 350/TH350, 3.73 posi
67 Burb is offline   Reply With Quote
Old 11-30-2015, 11:11 AM   #100
highwinger
highwinger's Avatar
Over the past week...
I replaced all the shocks with CPP's brand and replaced the rear lower brackets with the relocation bracket. I may replace the upper bracket too at some point, but this really helped the ride and moved the rears enough to not hit the axle. Nice to have a smoother ride.
The next few days were spent moving stuff from the house into a storage unit. I probably made at least 10 trips. Nice to have the ability to haul.
I took a day off and went to the Daytona Speedway for the Turkey Rod Run which fills the whole infield with classic show cars, clubs and cars/parts for sale . Nice to have a people hauler that doubles a classic show car too. I saw 5 other burbs there which is more than I've previously seen. I hope this means we're growing in popularity and price.
In all, it's a fun, useful vehicle.
