04-10-2020, 02:53 PM | #76 |
Re: Anti-theft devices ideas and suggestions
Yep. Super easy to install and works great
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
04-10-2020, 02:56 PM | #77 |
I did a similar thing in my truck 3 years ago and works great. Very simple to install. I mounted 4 - three position switches under dash my steering wheel.
So it’s like a combination of those 4 switches with 3 positions in order to start the truck. The switches I used are on in the up or down position and off in the middle position. So after I park I put all 4 in middle position. Switch 1- goes to horn in both on postions. I was going to ad a timer to this but never did. Switch 2 is nuetral safety switch off. Switch. 3 brings power in and when in right position takes power to the 4th switch Switch 4 sends power to the HEI. That along with power locks on $75 alarm system ________
04-10-2020, 09:28 PM | #78 |
I know what you mean; if someone wants to steal my credit card they'll have to make a payment on it to get it to work.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
04-11-2020, 09:12 AM | #79 |
I installed a battery disconnect, a hood lock and a hidden kill switch that grounds out the HEI tack lead. I don't have a straight panel or fender on my truck, so that may be the best deterent of all!
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
04-11-2020, 09:30 AM | #80 |
Here's a suggestion , leave the keys in the dash and park in dark alleys once you've over insured it . After all this Corona virus stuff it's the only way to get paid back what you have invested in it .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
04-11-2020, 10:18 AM | #81 |
On an old Z28 I had, I spliced into the ignition wire at the distributor, ran it to a toggle switch in the trunk, then back to the distributor. Locked the hood with a chain and it seemed to work ok. I guess if they wanted to drag it away not much was going to stop them. If they want the vehicle bad enough, they will figure out a way to get it
11-14-2020, 09:53 PM | #82 |
LMC and Brothers sell locking hood latches for our trucks. about $100. they are year specific.
roger |
11-15-2020, 12:29 AM | #83 |
Can you give a link to that please?
11-15-2020, 07:29 AM | #84 |
Kill switch on the coil is good but depending on work schedules, have a car parked behind your chevy
11-15-2020, 01:56 PM | #85 |
11-15-2020, 05:43 PM | #86 |
I was hoping you found something that was actually a lock, as in a hardened device you put a key in and turn. The cab is pretty much effortless to open with a slim jim or just break a window, which is inexpensive to replace, then pull the knob.
11-15-2020, 05:59 PM | #87 |
My truck is always in my locked and alarmed shop unless we are at a car show over night staying in a hotel. I have drilled and slotted brake rotors on my truck so I put a 10-24 socket head thru each rotor and fasten it with a ny-lock nut. If it's moved the bolts come up against the caliper mount. It's hard to see if they try to drag it out a parking spot in the middle of the night. And I guessing most thieves won't have an allen wrench and a 3/8" wrench to take the ny-lock nut off.
11-16-2020, 10:07 AM | #88 |
Well everyone... Having spent a few years chasing down the people that think yours can be theirs, I have to say that if they want it bad enough nothing short of you standing there to greet them with some back up with Samuel Colt is going to stop them. Unfortunately even that is no guarantee. Just have to do what we can and hope for the best.
A little side note for a chuckle... RUMOR has it...there is a very large salvage yard in my neck of the woods that many years back was doing a booming business, still there but smaller operation.The "big boys" from a large community on Lake Michigan stopped by and informed the owner that he was now going to be a part of their business operations and he didn't take kindly to their offer. Couple of his employees closed and locked the gates and then blocked the entrance with the big yard truck. While the company reps were entertaining themselves with a cigar he hopped into his loader and proceeded to clear the drive of the trespassing Lincoln by shoving it into his crusher. Some tense conversation later included a warning that next time they will be in the car when he hits the button. They took a cab all the way back to the big city. Yes, sounds like a movie...but knowing one of the now passed surly gate keepers that related this tale I have little doubt about its authenticity. That group was a pretty intimidating looking clan. |
11-17-2020, 10:28 AM | #89 |
1967 K30 461/TH400/Np205/D60/14FF/BDS MTZ 375/75/16 on 16x10 Pro Comps |
11-17-2020, 10:35 AM | #90 | |
ETA: I also have a battery disconnect on the negative terminal I unhook whenever I park it. Not fool proof but an added deterrent. My son swaps the coil wire to a plug wire spot and the plug wire to the coil as well. I don't since I can't reach it but he says most car thieves won't think to check that. Multiple layers offer more protection, IMO.
1967 K30 461/TH400/Np205/D60/14FF/BDS MTZ 375/75/16 on 16x10 Pro Comps Last edited by trukman1; 11-17-2020 at 11:06 AM. |
11-17-2020, 10:39 AM | #91 |
Nothing stops a flat bed and most people will not question one picking up a vehicle. If they know what they are doing the vehicle can be gone in a couple of minutes. Other than parking other vehicles in front I do not know how to prevent this from happening!
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
11-17-2020, 02:44 PM | #92 |
I have a steering wheel club, try to always have the front wheels turned Also a electronic lockout in the distributor. Try to make it not a quick easy grab. Also at home it's in a locked garage.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
11-17-2020, 03:39 PM | #93 | |
https://zlokhoodlock.com/
1966 Ford Mustang 1969 Chevy C10 1971 Chevy C20 |
11-17-2020, 06:44 PM | #94 |
A few years ago, my Department's "Auto Theft Task Force" was giving these CLUBS away to the local community as a way of getting their name out there with the public. As cases of these sat in the Watch Commander's office for quite some time, my guess is that not many modern cars had a use for a CLUB...so they started giving them to the Car Clubs. I use mine on the Beach-Burban whenever I park in public...but at home during hours of darkness, I leave my '03 Envoy parked blocking it in as the main deterrent! I might also have a couple other hidden deterrents...but Shhh...don't tell anyone!
Woody |
11-18-2020, 09:23 AM | #95 |
Has anyone tried a keyed negative disconnect such as a cat style one.
Another thought is a Mico Lock for the brake system. 72 GMC 4 x 4 |
11-18-2020, 10:56 AM | #96 |
Purchase a modern seat belt, one that has the switches built into the female portion of the belt and use those switches as a kill switch. The last thing a thief will be concerned with when attempting to start the truck is buckling up.
Again if they want it bad enough all you can do is slow them down. |
01-30-2022, 05:59 PM | #97 |
This cracked me up!
1970 k20 6.0l/nv4500/np205/14bff in progress build linkhttp://67-72chevytrucks.com/vboard/s...d.php?t=677014 |
01-30-2022, 09:35 PM | #98 |
I have two GPS device, one of which is a dash cam that will alert me if my vehicle is hit or moved. Then the three of us will meet you outside - me, Mr. Smith and Mr. Wesson (the three of us tend to hang out together).
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
01-30-2022, 09:56 PM | #99 |
I took the red wire going to my ignition switch under the dash and wired it into the on off switch on my am radio. If the radio knob isn’t turned on the truck won’t get spark. As everyone else has said, it won’t stop a really motivated thief but it’s better then nothing. More times then not I forget that I turned it off and go to start the truck and think “crap my battery must be dead”
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 |
01-30-2022, 10:35 PM | #100 |
I've used a Ravelco device (https://www.ravelco.com/) in my C10 for more than a decade. I believe they're pretty hard to beat.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus! Last edited by Zonaman; 01-31-2022 at 01:19 AM. Reason: typo |
