Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 03-10-2019, 06:14 PM   #76
KFF 1
KFF 1's Avatar
Re: New project : 72 Suburban
Front lower section of right rear quarter fitted and tacked as well as the 3rd door rocker. If time permits this week I might get it welded in place one evening.
KFF 1 is offline   Reply With Quote
Old 03-10-2019, 06:46 PM   #77
04ls1gto
Looks great burn it in
04ls1gto is offline   Reply With Quote
Old 03-20-2019, 06:43 PM   #78
KFF 1
KFF 1's Avatar
3D analog digital dash from Itellitronix came today
Old 03-24-2019, 01:40 AM   #79
KFF 1
KFF 1's Avatar
Finished up the passenger side panel replacement
Old 03-24-2019, 01:52 AM   #80
KFF 1
KFF 1's Avatar
Started working on the new fuel tank. Welded a portion of the original neck to the new tank. Once the new electric fuel pump and sending unit are installed in the tank, wired and plumbed it will be ready
Old 03-24-2019, 06:12 AM   #81
04ls1gto
What did you go with for fuel pump?
Old 03-24-2019, 08:06 AM   #82
KFF 1
KFF 1's Avatar
Holley In-Tank Retrofit Fuel Module (returnless style)
Old 03-24-2019, 09:49 PM   #83
Dave
DND Trucks
Who makes the tank and why is it returnless? Are you running FI or carb?
Dave is offline   Reply With Quote
Old 03-26-2019, 07:09 PM   #84
KFF 1
KFF 1's Avatar
Bought the tank from LMC. The fuel pump itself is returnless ( Holley retrofit module ) some friends of mine at a shop recommended the pump. That is what they use on most of their builds, just seems to be less hassle I guess. I'm running a 4150 style intake with injectors and a throttle body
Old 03-31-2019, 07:54 AM   #85
KFF 1
KFF 1's Avatar
Finished assembling the fuel tank yesterday and installed it into the Suburban. Today will probably concentrate on plumbing the intake and running the fuel line. Hopefully in a couple of weekends the wiring will be complete as well and the motor will be ready to fire up for the first time
Old 03-31-2019, 05:14 PM   #86
LockDoc
The Older Generation
LockDoc's Avatar
Looks good!
LockDoc
Leon
Old 04-13-2019, 09:19 PM   #87
hvacfatboy
What motor mounts did you use, i'm doing a 6.0l ls in a 72 2wd blazer with a 700r4 trans and i am having issues with heigth of trans with trailing arm crossmember
hvacfatboy is offline   Reply With Quote
Old 04-14-2019, 03:59 PM   #88
KFF 1
KFF 1's Avatar
I used CPP sheetmetal motor mounts, they came in the LS swap kit I purchased from them
Old 04-14-2019, 04:09 PM   #89
KFF 1
KFF 1's Avatar
Getting closer to start up. Radiator support , radiator, and some plumbing completed. Waiting on some odds and end parts to come in so the motor and trans can be buttoned up and I can move on to the wiring
Old 04-22-2019, 08:50 PM   #90
Average Joe
Average Joe's Avatar
Great progress. Looks great!!
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 05-01-2019, 07:47 PM   #91
KFF 1
KFF 1's Avatar
Been working on the wiring for the Suburban (when time permits) I have the 3D analog digital dash from Intelletronix put together and powered up the lights with a 9 volt battery. should be a nice piece once it is installed in the dash itself
Old 05-04-2019, 10:37 PM   #92
LockDoc
LockDoc's Avatar
Wow! That baby really shows up. Will the dash light dimmer work with it?
LockDoc
Leon
Old 05-05-2019, 07:32 PM   #93
KFF 1
KFF 1's Avatar
LockDoc
There is a wire that is to be connected to the light switch so that when the lights are turned on it will dim automatically.
Old 05-05-2019, 07:52 PM   #94
LockDoc
LockDoc's Avatar
OK, That's what the newer cars do.
LockDoc
Leon
Old 05-08-2019, 03:44 PM   #95
Deathwish
You have put some serious work into that old girl! Looks good!
What scares me is that I am looking at duplicating your efforts on one I am looking at as far as all that rust repair. I guess the rust is in the "usual" places on these....pretty much anywhere water can find a place to pool.
Deathwish is offline   Reply With Quote
Old 05-12-2019, 06:11 PM   #96
KFF 1
KFF 1's Avatar
Today Dad and I were continuing on the wiring on the Suburban and made an amazing discovery. Powered up the wiring harness for the rear AC unit and the fans came on, all 3 speeds and the small cone shaped interior light underneath the unit is operational and working. Good day in the garage today!
Old 05-12-2019, 09:04 PM   #97
Average Joe
Awesome! I love it when things work out like that.
Old 06-01-2019, 10:49 PM   #98
KFF 1
KFF 1's Avatar
Wiring is just about finished on the Suburban. Last week Dad and I took a few days and built the exhaust system for it, came out pretty good. In the process of building a homemade oil primer for the LS. Hopefully sometime next weekend I will fire it up for the first time. Cant wait to hear it run!
Old 06-03-2019, 04:01 PM   #99
Average Joe
Cool! Just in time for summer!!
Old 06-09-2019, 07:06 PM   #100
KFF 1
KFF 1's Avatar
Started the Suburban up for the first time this afternoon. The 402 stroker LS sounds pretty good ! When I get back into town on Friday we are going to go through the gears in the trans to make sure it is good to go then Saturday start hanging the front clip on it ... Getting excited ! Cant wait to drive it for the first time !!!
