02-03-2022, 09:15 PM | #76 |
Re: Vacuum erratic when electric fans turn on
So I borrowed a friend multimeter and went to start up my truck tonight and it turned over once and then would not turn over. The starter motor would just make a clicking noise. I looked at my voltmeter and it was down around 12 V. I use the multimeter that I borrowed and check the battery and it also was around 12 V. So I jumpstarted my truck and it started. I then proceeded to use the borrowed multimeter to check my distributor. Sure enough it did the same erratic reading then I moved the negative probe to the ground strap and it held steady at 14 V. I waited for the fans to turn on and it then held steady at 13.3 V. I have no idea why the battery drained that quickly in 2 days. I have not had any problems with my battery draining for a few years. The readings I am getting from my the borrowed multimeter are the same as the second one so I think that I am okay using my second multimeter.
02-03-2022, 09:21 PM | #77 |
I wonder if the battery draining is causing by starting the truck over the last couple of days and not driving it and just letting it sit at idle not giving the alternator a chance to change the battery. Also I wonder if my fan is connected to my starter instead of to the fuse block. I saw on a different thread someone saying that there fan instructions said to connect it to the starter and people said that you should not do that.
02-03-2022, 09:24 PM | #78 |
Moderator
Is there a fan relay or just a power switch?
02-03-2022, 09:27 PM | #79 | |
(I did notice that when I reinstalled my battery that positive battery cable sparked a little when it touched the post.) You have a short somewhere draining the battery down.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
02-03-2022, 11:25 PM | #80 |
Are there any tricks to chasing that down?
02-03-2022, 11:26 PM | #81 |
02-03-2022, 11:42 PM | #82 |
Yes
By process of elimination. Disconnect one circuit at a time. I would start with your electric fan circuit. Then your Alternator. Use caution and tape wires that you take loose so then do not touch anything and ground out against anything. You can disconnect each component. Then check for the (arc) at your battery.
02-04-2022, 12:04 AM | #83 |
Good idea. Also I have a battery shut off switch that I turn off when not using the truck so that might help me illuminate some components. I have it for security reasons.
02-05-2022, 05:08 PM | #84 |
Is the starter supposed to be grounded somehow? Ir is it grounded because it is bolted to the engine block? I have a mini starter.
02-05-2022, 07:33 PM | #85 |
Forest, for general voltage troubleshooting on your vehicle, that multimeter should do just fine.
Bob 1967 2wd Burb, 350/TH350, 3.73 posi |
02-05-2022, 07:34 PM | #86 |
Starter is grounded to the engine block.
02-05-2022, 08:17 PM | #87 |
02-05-2022, 08:34 PM | #88 |
There is a seen in Better call Saul, where his brother tears all the wiring out of his house and yet he still cannot get the meter on the outside of his house to stop turning. That is how I felt today. I disconnected nearly everything I could think of and still it sparked when I touched the positive cable to the battery. I disconnected the:
Radio Alternator Fans Distributor Removed the power window fuse Removed the turn signal fuse Ac Head lights Unplugged the ignition Choke Cigarette lighter Windshield wiper Steering column Break light switch Neutral safety switch Voltmeter Oil pressure sender Removed the dome light fuse Removed the giant Painless Performance fuse. After all of that it still sparked at the positive cable. The only things I didn’t try was the starter which I don’t know how I could do that without removing the positive battery cable. I also could not figure out a way to disconnect the fuel sending unit. When I switched off my battery kill switch I still seemed to get a spark. My only thought is that I need to ground the switch. Ground the starter and ground the radiator support to the frame. I took a photo of the starter plug. |
02-05-2022, 08:51 PM | #89 |
Here’s the photos
02-05-2022, 08:54 PM | #90 |
Every so often I get a shock from the horn when I press on it and the horn fuse goes out from time to time.
02-05-2022, 11:55 PM | #91 |
Moderator
That would be a short (fuse goes out) Need to ground your column also.
02-06-2022, 12:33 AM | #92 |
How should I ground my column? Is there a specific bolt that you recommend?
02-08-2022, 03:56 PM | #93 |
This is the battery cut off switch that I have. https://www.summitracing.com/parts/tay-1032
I am trying to figure out the best way to ground it. Would it work if I soldered a ground wire to the mettle housing? |
02-09-2022, 01:12 AM | #94 |
Did everyone give up on me?
02-09-2022, 07:17 AM | #95 | |
02-09-2022, 01:00 PM | #96 |
02-10-2022, 05:21 AM | #97 | |
http://67-72chevytrucks.com/vboard/s...10&postcount=3 |
02-10-2022, 11:39 AM | #98 | |
02-10-2022, 02:13 PM | #99 |
02-10-2022, 03:01 PM | #100 |
That definitely seems like the kind of part that an good intentioned back yard mechanic friend might leave off after not reading the instructions.
I will try something like this over the weekend. https://www.corvetteforum.com/forums...rag-joint.html |
