Old 05-02-2017, 08:05 AM   #1051
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 85 GMC Sierra "Scarlett"
Originally Posted by aggie91 View Post
Looks good!
Thank you sir. It's starting to take shape.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
"Refining Sierra"
Old 05-03-2017, 12:22 PM   #1052
N2TRUX
Happy to be here
N2TRUX's Avatar
I worked late last night so shop time was limited. I spent some time gathering materials to make the passenger side enclosure for the 6x9. Tonight I get started on the construction of the box.
Articles-
"Refining Sierra"
Old 05-04-2017, 09:44 AM   #1053
N2TRUX
Happy to be here
N2TRUX's Avatar
Wednesday night was lay out night. I measured and cut all the pieces to build the second 6x9 box. Normally I try to cut duplicate pieces at the same when I build one side. Due to so many design changes along the way I opted to wait. With all the pieces cut, I can start assembly tonight.
Articles-
"Refining Sierra"
Old 05-06-2017, 02:17 PM   #1054
N2TRUX
Happy to be here
N2TRUX's Avatar
Friday night I got the second box assembled. I double checked all my measurements and couldnt understand why some of my dimensions were off. I decided to measure the back of the cab and check the angles. Can you believe that the cabs on these trucks aren't square? I know, I know, it was a huge surprise to me too. Now that I know what Im dealing with I can compensate and move on.
With the adjustments made I replaced the affected pieces and started assembly. This time the process went much quicker. I still need to refine the filler pieces, but the main structure is complete.
Articles-
"Refining Sierra"
Old 05-06-2017, 02:36 PM   #1055
Bears63
...just another truck junkie..
Bears63's Avatar
You have some serious building talent. If I tried something like that I would just have a giant mess on my hands
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 05-06-2017, 09:30 PM   #1056
N2TRUX
Happy to be here
N2TRUX's Avatar
Trust me, my scrap pile is sometimes bigger than my keep pile. I have found that what I lack in talent, I can overcome with persistence.
Articles-
"Refining Sierra"
Old 05-06-2017, 11:02 PM   #1057
rustytruck50
rustytruck50's Avatar
Looking great as usual....wish I could see & hear in person
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 05-09-2017, 11:39 AM   #1058
N2TRUX
Happy to be here
N2TRUX's Avatar
Thanks.
Articles-
"Refining Sierra"
Old 05-10-2017, 09:30 AM   #1059
N2TRUX
Happy to be here
N2TRUX's Avatar
The final stage of construction on the Kicker Audio install is complete. I finished the last 6x9 #coaxial box and test fit a the pieces together.
Now it's time to sand everything smooth and prepare for wrapping them in vinyl.
Articles-
"Refining Sierra"
Old 05-10-2017, 09:43 AM   #1060
ultrahd4me
ultrahd4me's Avatar
Looks great Ken. I may have missed it, but how are mounting the speakers boxes after you wrap them. Thanks bud
Follow me on Instagram: @midtennc10
Youtube channel: Midtennc10
ultrahd4me is offline   Reply With Quote
Old 05-10-2017, 12:16 PM   #1061
N2TRUX
Happy to be here
N2TRUX's Avatar
Bobby I have tried several ways to avoid drilling holes. In this case I just couldnt help it. The Kicker Hideaway sub enclosure is heavy and needs ample support. I opted to drill two holes through the bottom of the box. I used a tap to cut threads in the floor pan for mock up. On final install I will add sealer, then install a nut and washer to ensure it doesn't damage the floor.
Articles-
"Refining Sierra"
Old 05-12-2017, 09:33 AM   #1062
N2TRUX
Happy to be here
N2TRUX's Avatar
Sanding, sanding, and more sanding. Maybe theres a better way to ensure a clean fit and smooth transition between panels, but I havent found it yet. Last night a pulled the passenger side 6x9 enclosure and sanded it smooth. It now fits like a glove and has nice radius edges.
Articles-
"Refining Sierra"
Old 05-12-2017, 12:26 PM   #1063
LT7A
Amen, brother.
Old 05-15-2017, 07:47 AM   #1064
N2TRUX
Happy to be here
N2TRUX's Avatar
Chris got the last bit of wiring done. He discovered that KMC 20 does not need a constant hot unless you want it constantly hot. We did not, so that was changed. Once more he double checked everything and covered it all in duct tape.
I worked more on the fit of the boxes. I fine tuned the gaps and added the last close out panel to the top of the 6x9 box. I added Silent Coat to the back of the box and closed it up for testing.
Chris linked his phone via Bluetooth and we fired it up. We started the tuning process by going neutral with all the settings. The #kmc20 processor has plenty of tuning capabilities so we spent some time roughing it in.
For our first round of tuning we turned the bass off and slowly brought up the mids and highs. We tried a variety of songs and found a happy place so we brought the bass back in. I like really tight lows so I want to play with frequency settings more, but so far we have a good base tune and we are pleased.
Before we blow it apart, I shot a short video. (Link) Now it's time to wrap the enclosure and get this segment of the build done. My next project is already underway.
Articles-
"Refining Sierra"
Old 05-15-2017, 11:45 AM   #1065
gringoloco
A guy with a truck
gringoloco's Avatar
Looking great! What's the next project?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 05-16-2017, 08:11 AM   #1066
Desert1957
Desert1957's Avatar
Ken,
Isn't the seat going to change any settings for sound your making anyway?
I know the low frequencies are omni directional, but mids and highs from the rears?
Desert
Desert1957 is offline   Reply With Quote
Old 05-16-2017, 10:01 AM   #1067
aggie91
I'm just glad to be here!
aggie91's Avatar
Great work on the sound system. I hope the next project is what I think it is. It was missing at LST...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-16-2017, 10:55 AM   #1068
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by Desert1957 View Post
Ken,
You are correct sir. I factored that in, and considered setting the seat in place. No doubt the seat, carpet, etc will have an impact. I was more concerned with balance and staging on the initial tune. Once we get it together I will see if my worn out eardrums will allow me to tune it properly. If not, Chris has a pretty good sense of sound too.
Articles-
"Refining Sierra"
Old 05-16-2017, 11:01 AM   #1069
N2TRUX
Happy to be here
N2TRUX's Avatar
I was asked by many people at LST 2017 "where's the 77?" When you going to bring the 77 back out" "you still have the 77?"
In response to the inquiries #the77remix is my next project. I made a commitment to my family and several vendors to bring it back with a fresh look. Don't worry, I promise to pay tribute to the look it has now. Stay tuned for more details soon.
Articles-
"Refining Sierra"
Old 05-16-2017, 01:14 PM   #1070
Low Elco
For your Ramjet issues on the 77- 'bout halfway down.
http://67-72chevytrucks.com/vboard/s...=657509&page=2
It opens up a bunch of possibilities, good luck!
https://www.google.com/search?q=obd+...F-8#q=mefiburn
Low Elco is offline   Reply With Quote
Old 05-16-2017, 06:51 PM   #1071
gringoloco
A guy with a truck
gringoloco's Avatar
Ooh, finally wide wheels out back?
-Chris
Old 05-17-2017, 08:46 AM   #1072
mcbassin
Still Learning
mcbassin's Avatar
Awesome work Ken! Very clean!
mcbassin is offline   Reply With Quote
Old 05-18-2017, 07:19 AM   #1073
N2TRUX
Happy to be here
N2TRUX's Avatar
Thanks for sharing
It depends on tires available.
Articles-
"Refining Sierra"
Old 05-24-2017, 08:07 AM   #1074
N2TRUX
Happy to be here
N2TRUX's Avatar
Progress has been slow and shop time has been limited. This is the time of year that my day job keeps me busy. I have been glueing, filling, and sanding the enclosure. Once it's all smooth as a baby's bottom I can start to wrap it. Here's a few pics from last night.
Articles-
"Refining Sierra"
Old 05-24-2017, 11:43 AM   #1075
NewType72
NewType72's Avatar
What a killer box, never though of adding silent coating to the inside of the box , that must help tremendously.. gets me thinking for my redo some decade haha
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
