02-02-2021, 07:37 PM | #1151 |
Re: What did you do to your truck today part IV
Bolted bed together. Had to fiddle some as it’s a 7 footer. Long story
02-02-2021, 08:08 PM | #1152 |
Was it easier doing it upside down?
02-06-2021, 07:08 PM | #1153 |
I yanked out my kick penal speakers that I was vary happy with. The reason I had to do so was because I blocked off my vents the air pressure inside the cab when I shut my doors caused the bondo and paint in my roof to crack. Real bummer but I don’t want my paint cracking
02-06-2021, 07:10 PM | #1154 |
Moderator
Put my engine in by myself.
02-06-2021, 08:18 PM | #1155 |
02-06-2021, 10:37 PM | #1156 |
Reinstalled the freshly painted core support and grill support, installed the VA condenser, trans cooler, associated lines, etc.
02-08-2021, 12:11 PM | #1157 |
Treated the truck to a new console cupholder from www.cupholdersplus.com $165 w/Free Shipping
I also order 2 Rockford Fosgate 6.5" speakers to be installed on each side (comes pre-cut), I'll make up 2 quick disconnects incase I have to remove the console if needed.
http://s1299.photobucket.com/user/jb...23904108567829 |
02-08-2021, 12:47 PM | #1158 |
It's Better With Nitro
Nice, Jacob! Does it stay pretty stable on the trans hump (what keeps it from sliding around)?
02-08-2021, 01:00 PM | #1159 |
The two 'wings' are bendable and fit the trans hump very well.
02-08-2021, 11:50 PM | #1160 |
Wow, nice interior JB
02-09-2021, 12:04 AM | #1161 | |
02-09-2021, 11:44 AM | #1162 |
I believe I have the Hugh hump as it about 7-8" higher than the floor
http://s1299.photobucket.com/user/jb...23904108567829 Last edited by jbgroby; 02-09-2021 at 02:50 PM. |
02-09-2021, 11:45 AM | #1163 |
got the first speaker in and mounted
02-09-2021, 02:51 PM | #1164 |
You can push it back about another 2-4".
02-09-2021, 02:53 PM | #1165 |
I really need a speaker location and I really need cup holders but I love having that open space.
02-09-2021, 05:25 PM | #1166 |
I'm making the speakers wire leads with quick RCA disconnects so I can remove the box if needed
02-09-2021, 05:26 PM | #1167 |
02-10-2021, 09:26 PM | #1168 |
Finally got my rockers/doors on hopefully have engine running next week
02-14-2021, 06:17 PM | #1169 |
Installed some tie downs in the bed, straps would rub the sideboards when I used the tie downs on the outside of bed.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
02-14-2021, 09:33 PM | #1170 |
Making progress on the Vintage Air install. Pulled a vacuum on the system today to check for leaks prior to buttoning everything up. It held 29 inHg for hours.
02-14-2021, 11:43 PM | #1171 |
Not super exciting, except to me! Finally did compression check, all 8 cylinders held at 150. Super happy about that, troubleshooting overheating and running rough/backfiring so glad to rule out compression. New spark plugs since the old ones out anyway. Passenger side rear plug had some oil on it but the compression was good so...
George still runs a little rough so tomorrow I will check timing. Another thing I did was to finally track down a parasitic draw, thanks to instructions off YouTube I used a test lamp attached btwn battery Neg post and Neg cable, pulled fuses to see when the light goes out. Not a fuse, so started checking other inline fuses the PO had added. Finally tried the horn relay, that was it! Disconnected horn relay and light went out. Will check battery tomorrow morning, used to be if I kept battery connected overnight George woke up dead. Also planning to switch out thermostat for the heck of it in case that was causing overheating.
-Pickman (Mike) 1964 C10 Fleetside LWB “George” 1963 C50 “Green Machine” 2019 Silverado 2500HD My story (Welcome Page) |
02-15-2021, 01:42 AM | #1172 | |
1961 GMC half ton, short step, Canadian model. Just starting work on it. |
02-15-2021, 04:35 AM | #1173 |
Yes, probably drawing somewhere else like the horn button on steering wheel, I will have to track it down. all I know is when I unplugged the relay the light went out! Just happy to stop the draw
02-15-2021, 10:26 PM | #1174 |
63 C10 |
02-15-2021, 10:28 PM | #1175 |
What a professional looking job! well done man
63 C10 |
