#1176 |
Re: Got some new wheels: Boss 338's in 20x10 and 20x8.5
This info w/o filling the rest of us in on what they're going on is just mean....
#1177 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
#1178 |
Mine,
1968 C10 SWB Dropped 5 in tha back 3 in tha front My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=470902 |
#1179 |
Here's the current 20" rear wheel. They apparently have made the hub much thicker so spacers aren't needed. The lug nuts disappear into the hole.
#1180 | |
Thanks, ![]()
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
#1181 |
Found matching Nexen Roadian tires in 295/45/20 rear 255/55/18 front. Side wall is same front and back but I kinda wish I'd gone 1 size narrower on front cuz it looks a little fatter on the rim that the rear. Not real noticeable though.
#1182 | |
#1183 |
I dont know why all the guff, mine were a "bolt on"!
2-20, 2-21 whatever it takes! |
#1184 |
VA72C10
![]() Join Date: Mar 2008
what rotors did you use so others can look into those as an option?
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#1185 |
go back and look at page 2................ sorry....lol
#1186 |
Ha.
Your truck is one of the best looking trucks, running these wheels! (and the first to make them work with the HD rotors) Maybe all members running these infamous Boss 338 wheels should add their truck picture here. (Please include wheel size and tire size)
#1187 | |
Hickup you are #2......I mean Hickup you are the second. ![]() ![]() Lolife were is your picture? Just realized you started this thread over 3 years ago. WOW time flies! ![]() ![]()
I LOVE BURNOUTS ![]() ![]() NO BOZO's |
#1188 | |
It took forever to figure out the 1" light duty rotors were a bolt on. I still have the wheels,... but I sold the truck they were going on. I may use them on my '86.
#1189 |
RAT1968 '68 Cab/'71 Parts
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 08-25-2012 at 04:40 PM. |
#1190 |
Brandon's
![]() Yes they are 338's, We have renamed them 666's! ![]() ![]() ![]() Front 20 X 8.5 225-40-20 Rear 20 X 10 295-45-20 Machined front wheels and rotors. Modified spindles and dust caps. Rear has been narrowed 2.75" per side. Wheels are chevy car pattern(better offsets). No wheel spacers! That is what it takes to make them fit. BRANDON AND I THINK IT IS TOTALLY WORTH IT!!! ![]() ![]() ![]()
#1191 |
Love it!^^^
#1192 |
Just got done doing this for the front, for the 3AA Rims.
I have to say, this was one of the most painless modifications to date. I simple took a flap wheel, held it up against the rotor, and spun. I need to go update my build thread now :P
72 C20 http://www.houseofdewm.com Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=485286 |
#1193 | |
I have a buddy that just did the same thing. He also had to slighty dent the dust cap,... other than that they will bolt right on the HD rotors.
#1194 |
I haven't tried sticking the dust caps on yet, maybe I should :P I don't imagine it will be too bad, since the Eagle adjustments were only for the dust boot
#1195 | |
![]() I think they will look great on my little Orange truck.
#1196 |
Z10 let me know how it goes. I'm looking at the same wheels for my orange truck. LOL
1971 C/10 - Orange & White 2009 GMC 1500 - Lowered 3/4 22' KMC Slides |
#1197 |
Will do. Now I just need to get tires ordered, shipped, and installed.
#1198 |
Z10 - You should pull a front wheel and try to bolt one up can see if the center cap clears.
#1199 |
#1200 |
Ok, pulled a front wheel and attempted to fit the front 18x8 wheel. Not going to happen. So, I'll have to "Clearance" the brake hub. This wheel was made 6-29-12 so it's not been sitting on the shelf and was shipped direct from Boss. The rear's were made 7-19-12.
Here are a couple of pics. The second one shows the fitment issue.
