Old 08-05-2011, 12:02 PM   #101
shenk10
shenk10's Avatar
Re: 1982 C10 swb "SS"
I used paint stripper and a putty knife to get most of it off and then little spots that I missed or were different to get off I used a wire wheel...the stripper takes the black stuff off really easy though compared to using the wire wheel. I can't remember what kind I used, I'll try to remember to get a picture today though.
Jordan
1972 Chevy K5 Blazer, 6" Lift, 35x13.5R15, 6.0/6L80E/NP205
1982 Chevy C10 SWB, 2006 LS2/4l70e
In progress....
http://67-72chevytrucks.com/vboard/s...d.php?t=439860
shenk10 is offline   Reply With Quote
Old 08-05-2011, 03:26 PM   #102
pwtr02ss
Originally Posted by baclay9 View Post
What did you use to remove the black stuff from the firewall?
Lacquer thinner works good
pwtr02ss is offline   Reply With Quote
Old 08-05-2011, 03:32 PM   #103
baclay9
I'm sure this is a stupid question but those things are going to take the paint off as well correct?
baclay9 is offline   Reply With Quote
Old 08-05-2011, 04:59 PM   #104
Jonboy
Slots go on anything!
Paint stripper will. The black stuff is undercoating, it should be petroleum based. Try mineral spirits or acetone, and get more agressive from there. Once the mineral spirits soften it, use a plastic scraper to avoid scratching the underlying paint too much.
1974 Jimmy- 5.3/4L80e/NP241
Old 08-16-2011, 03:11 PM   #105
shenk10
shenk10's Avatar
yea, I'm not sure the best way to get rid of it without taking the paint off, but I finally got the power steering figured out so I'll get pictures of it tomorrow.
Jordan
In progress....
Old 08-16-2011, 03:48 PM   #106
Can't kech me
Can't kech me's Avatar
this has probably been mentioned, but i'm too lazy to find it, but what size tires are those with the american eagle rims?
"As I walk through the valley of rice i fear no honda, for i have torque!"
Can't kech me is offline   Reply With Quote
Old 08-16-2011, 08:54 PM   #107
shenk10
shenk10's Avatar
no problem, the rears are 295/40/20 and the fronts are 245/40/20
Jordan
In progress....
Old 08-18-2011, 01:10 PM   #108
shenk10
shenk10's Avatar
Well I finally got the power steering done. My camera died while I was trying to take more pictures so I only have a few. The p/s pump fitment was a little tighter than I thought it would be, but it will still work so I'm happy. I also ordered all the parts for my trans lines, gas lines and parts for the trans conversion. Just have to order the shift kit and then I can finally get the trans swapped and put in the truck, and things should finally move faster after that.
For those that want to know, I just used the old p/s lines from the truck...they work fine although they are a little long, but as long as they work and look decent they are fine by me.
Jordan
In progress....
Old 08-19-2011, 12:20 AM   #109
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Were you able to use the fittings as is or needed to use adapters on the lines?
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 08-19-2011, 07:59 AM   #110
Greenlee
Greenlee's Avatar
I just swapped to a serpintine belt setup from a 1990 Suburban. From what i can tell the power steering pump looks just like this one. I used the lines from my 87' and everything was the same.
Greenlee is offline   Reply With Quote
Old 08-19-2011, 08:57 AM   #111
shenk10
shenk10's Avatar
I was able to use the fittings as is, I don't think they have changed the power steering fittings at least since the 80's, and the pumps are almost exactly the same too.
Jordan
In progress....
Old 08-21-2011, 11:25 AM   #112
shenk10
shenk10's Avatar
Well I got some new pictures. I finally got some parts in the mail. So I have everything to run all the lines. I am waiting on a shift kit before I get the transmission swapped, so I'm not sure when that will be, but won't be too long. I also got FI rated hose clamps yesterday so I'm going to get those put on today. Here are some pictures:
Here is what the back of the p/s pump looks like:
The fuel rail adapter fitting as well as a straight an fitting:
Some clean up on the transmission:
Jordan
In progress....
Old 08-21-2011, 09:13 PM   #113
shenk10
shenk10's Avatar
Jordan
In progress....
Old 08-21-2011, 09:15 PM   #114
shenk10
shenk10's Avatar
Jordan
In progress....
Old 08-25-2011, 12:43 AM   #115
shenk10
shenk10's Avatar
Got the belt on today. Transmission swap parts are coming tomorrow and I ordered a shift kit today so I should have the trans done in two weeks or so.
Jordan
In progress....
Old 08-25-2011, 11:21 PM   #116
Nobaddaze
Nobaddaze's Avatar
lookin good
Hard work has a future payoff. Laziness pays off now.
My Build
Nobaddaze is offline   Reply With Quote
Old 08-25-2011, 11:53 PM   #117
gearheads78
gearheads78's Avatar
great project....
gearheads78 is offline   Reply With Quote
Old 08-30-2011, 08:14 PM   #118
shenk10
shenk10's Avatar
thanks...got a few more pics
Jordan
In progress....
Old 08-30-2011, 09:06 PM   #119
73gmc454
73gmc454's Avatar
lotso progress, lookin good too!
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237
73gmc454 is offline   Reply With Quote
Old 09-09-2011, 09:19 AM   #120
shenk10
shenk10's Avatar
thanks, should be taking the transmission tomorrow to get the shift kit and it converted from awd to 2wd
Jordan
In progress....
Old 09-14-2011, 12:28 PM   #121
shenk10
shenk10's Avatar
well dropped the trans off yesterday...hopefully it will get done before the weekend, but we'll see
Jordan
In progress....
Old 10-06-2011, 08:39 PM   #122
shenk10
shenk10's Avatar
Should have some info to update after this weekend. Finally getting a chance to go home and work on the truck. Got the transmission back with the shift kit, servo's, and conversion done. Would put it back in the truck, but have decided to go with a 3200 rpm torque converter before it goes back in. So I'll be waiting on that before the trans goes back on.
Jordan
In progress....
Old 10-09-2011, 10:02 AM   #123
shenk10
shenk10's Avatar
Jordan
In progress....
Old 10-09-2011, 10:04 AM   #124
shenk10
shenk10's Avatar
Bolted the trans on without a converter just so it could roll, looks so much better just with a trans sitting there. Should have more work done next weekend.
Jordan
In progress....
Old 10-25-2011, 12:06 PM   #125
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Coming along nicely buddy.
--Josh
