Old 04-18-2012, 09:01 PM   #101
JRANGER
JRANGER's Avatar
Re: Project 78 High Sierra
Got a lil bondo on the fender dents, holes and used the excess on the lip of the hood.... need to do much more and sand it but this is all before it got dark
JRANGER is offline   Reply With Quote
Old 04-18-2012, 09:40 PM   #102
trout
no i got a welder just haven't got the nerves to try it by my self might try it on these after market 73-80 fenders i got that i cant get rid of
Edited by staff
trout is offline   Reply With Quote
Old 04-18-2012, 10:00 PM   #103
JRANGER
JRANGER's Avatar
i hear ya...Thats why i started on the inner fenders...Had to do it one way or another so
Old 04-20-2012, 01:10 PM   #104
grayharville
^^who I am^^ what I say>
grayharville's Avatar
yep you just got to jump into it. practice your skills as you go along.
70 chevy LWB 350/TH350 Barn find (AKA the 70)
http://www.67-72chevytrucks.com/vboa...d.php?t=406364
East Tx Squares
grayharville is offline   Reply With Quote
Old 04-20-2012, 01:35 PM   #105
trout
most deff.. i have done every thing else to my sept the welding that my dads but i think im going to get a roll of wire and try it out the next couple days on my 76
Edited by staff
Old 04-20-2012, 01:39 PM   #106
grayharville
just go at it, with sheetmetal all you really need to do is spot weld and skip around alot. it is time consuming, but thats the only way to do it to avoid warping. which sucks.
East Tx Squares
Old 04-20-2012, 01:44 PM   #107
UPNADM
UPNADM's Avatar
I like your idea for paint combo.
UPNADM is offline   Reply With Quote
Old 04-24-2012, 04:55 PM   #108
UPNADM
UPNADM's Avatar
How's it going? No updates!
Old 04-24-2012, 04:59 PM   #109
JRANGER
JRANGER's Avatar
no progress this weekend... I had a bachelor party to attend in ATL so I was out of town spending all my money!!! I did get a lil sanding on the first bit of bondo and put some more on it.
Should be back to it this weekend and maybe a few nights this week...
Old 04-25-2012, 09:22 AM   #110
JRANGER
JRANGER's Avatar
Allthough I really want to work on the fender and hood this weekend I have decided before I do any of that I am going to do the following:
Remove the driveshaft and replace the rear seal so it stops leaking.
Remove the speedo cable and grease it so it stops jumping and squeaking
Then I shall return to the body work and hopefully have the hood and fender prepped to go ahead and install
Old 04-25-2012, 10:45 AM   #111
grayharville
Sounds like a plan.
East Tx Squares
Old 04-25-2012, 10:46 AM   #112
grayharville
Whenever you said ATL all I could think of was a lil jon song
East Tx Squares
Old 04-28-2012, 09:22 PM   #113
JRANGER
JRANGER's Avatar
Well started the day greasing the speedometer cable only to remove the the gauge cluster and with just a slight move the corner that holds the shifter wire broke off...I tried to rig it up but no luck...But I did put the new lens cover on it to see the difference and it looks great....Ordered a new cluster for the backing plate.
Sanded down the fender bondo and hit the hole thing with high build primer only to find a bunch of lil dings on the front of it..So i will have to sand those spots down and bondo them
Also hit some more bondo on the hood under side edge and sanded the front bondo hole...
Old 04-28-2012, 09:26 PM   #114
UPNADM
UPNADM's Avatar
Looking good, keep on keepin on.
Old 04-28-2012, 09:26 PM   #115
JRANGER
JRANGER's Avatar
new gauge lens comparison
Old 04-28-2012, 09:27 PM   #116
UPNADM
UPNADM's Avatar
That lens looks great. Where did you order that from?
Old 04-28-2012, 09:29 PM   #117
JRANGER
JRANGER's Avatar
I ordered it from LMC! Its perfect.....
Old 04-28-2012, 09:30 PM   #118
JRANGER
JRANGER's Avatar
My ghetto hot glue and l bracked that didnt work
Old 04-28-2012, 10:01 PM   #119
grayharville
Gauges look nice bro. I see you work in your living room too..
East Tx Squares
Old 04-28-2012, 10:02 PM   #120
JRANGER
JRANGER's Avatar
haha, yes sir.....Best lighting and i was watching the draft at the same time lol
Old 04-28-2012, 10:07 PM   #121
grayharville
Yep I was polishing center caps on my pool table the other day lmao
East Tx Squares
Old 05-05-2012, 05:27 PM   #122
JRANGER
JRANGER's Avatar
Got to work while hung over today and got some progress on the hood...
I hit it with 3 cans of high build primer....then had to sand the whole right side back down due to the scarring from removing the paint with a flap disc...Got most of the scarring off of it but still need to do more sanding...HIt it back with another 2 coats of primer and thats where it sits..
Also sanded down the bondo on the under edge where it was ful of holes and hit the bondo with some rust tough
Old 05-05-2012, 08:35 PM   #123
JRANGER
JRANGER's Avatar
Also got my new gauge cluster in.....Swapped all my gauges into it and cut the speedo and gas gauge to give it a little cleaner look...I suck at making stuff straight though
On the bright side i have a couple spare gauges and the circuit board was a lot better on the new one
Swapped the needles as well as they are brighter but the speedo one you cant do...erg broke the other speedos off...glad i started with the other one lol
Old 05-05-2012, 09:44 PM   #124
grayharville
Like the gauges
East Tx Squares
Old 05-05-2012, 10:07 PM   #125
UPNADM
UPNADM's Avatar
Looking good.
