Old 01-11-2014, 12:06 PM   #101
ryanroo
ryanroo's Avatar
Re: Ultra Family and Hauler Mobile
Originally Posted by Dieselwrencher View Post
That was pretty low.
For those that don't know yesterday I drove this to work and the engine oil pan drain plug fell out. I stopped it before it was totally out of oil. My brother brought a different drain plug and my dad brought some oil. We put the drain plug in and oil in, fired it up and it was fine. Drove it with no issues. Later I started it up and it had a slight knock. Now it will be getting a rebuilt engine. It really stinks because I checked everything but the oil pan drain plug. I was just under it yesterday morning checking stuff and the drain plug was dry and had no signs of being loose. So yes, check them all before driving a big project........
All in good fun my friend. just trying to make light of a crappy situation.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 01-11-2014, 12:12 PM   #102
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Hey, at least the cruise works. And at least the a/c isn't charged yet........
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-11-2014, 12:17 PM   #103
ryanroo
ryanroo's Avatar
Since you will have the engine apart, seems like a good time for twins and maybe a p-pump...
72 K20 12v build
Old 01-14-2014, 06:36 PM   #104
Ackattack
Ackattack's Avatar
At least with the engine no-one gets hurt. I always fear that I forgot to tighten a bolt that holds the steering or suspension together and it will fall out going down the road at 70.....that wouldn't be good.
Ackattack is offline   Reply With Quote
Old 01-15-2014, 02:47 AM   #105
Dieselwrencher
Yeah, true. I rechecked my axle u bolts and spring hanger bolts, hub bolts, ball joints, tie rods and all that for the same reason. Dang the luck.
Ryan
Old 03-06-2014, 12:06 AM   #106
6BT 56
6BT 56's Avatar
Any progress on this one ? You got all the hard work done so I guess just $$$ at this point ?
Still one of my fav builds on here . I guess it's knowing if I tried to build one I could actually use the excuse it's for the wife . lol.
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 03-06-2014, 12:51 AM   #107
Dieselwrencher
LOL Yeah for sure. We just got the engine and trans pulled back out and I have the new engine short block is done. I'm hoping to get everything transfered over and get the engine put back soon.
Ryan
Old 03-31-2014, 03:59 PM   #108
Dieselwrencher
The big ol Ex is running once again. I checked the drain plug and a lot of everything else because I'm paranoid now. Last Thursday I broke the cam in and everything was good, no leaks etc. The only thing odd is it had a slight belt squeal noise but I think it was a tone ring tach interference issue. It wasn't the tone ring or sensor, I think it's just the dang belt. I've put 160 miles on it and it's doing good. I have a coolant leak to address at some point. It's leaking a slight bit from a weld on my lower coolant tube. I'm going to have to put a new ring and pinion in the rear axle as my used one has a whining noise that is annoying.
Ryan
Old 03-31-2014, 08:24 PM   #109
6BT 56
6BT 56's Avatar
Looking good . How does that 24v work with the 1st gen style pump. Thats called a rotary pump rite ? The next one like your 70 and Ryan the super welder's is called a p pump ?
Old 03-31-2014, 08:38 PM   #110
Dieselwrencher
I'm still trying to get used to the sound of it and figure out where it likes the timing the best. It works pretty good so far. Yep, it's a rotary or VE bosch pump. The 94-98's are P-pump in line bosch pumps.
Ryan
Old 03-31-2014, 09:13 PM   #111
COS399
COS399's Avatar
Good catch there 56 6BT. I missed that until you mentioned it. So Ryan is it a IC or NIC VE pump? I have a spare NIC pump that I was going to try and get rid of it but I might hang on to it if you tell me it's worth hanging on to in case my VP takes a dump. Oh yeah, Nice Build.
COS399 is offline   Reply With Quote
Old 03-31-2014, 10:23 PM   #112
1972RedNeck
1972RedNeck's Avatar
They're only good for a max of about 450 HP with the stock head.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 04-01-2014, 02:34 AM   #113
6lcummins
If you do want to unload the NIC VE pump you have I know someone that would be interested in it.
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK"
ASSEMBLY THREAD
6lcummins is offline   Reply With Quote
Old 04-01-2014, 03:57 PM   #114
Dieselwrencher
This pump is from a non intercooled engine and has a Denny T Stage 2 fuel pin and a 3200gsk. Honestly, since you have the truck all wired up and running, I'd leave it a VP. I used to hate VP trucks, but have taken a fond liking to them lately. I'm still trying to get used to the different tone from the VE on the 24v. It moves out pretty well considering this tank weighs 8690 with a full tank of fuel.
Ryan
Old 04-01-2014, 06:48 PM   #115
6BT 56
6BT 56's Avatar
Good to hear it runs well. Man its heavy ! I have the same fuel pin and gsk for mine . Still find them very ineffective in the glovebox . I bet they will help by putting them in the pump when the , if the weather ever changes . Watching it rain now . Better than snow i guess. Now for a month of the dogs living in the mud room .
Old 04-01-2014, 08:43 PM   #116
Dieselwrencher
Yeah, I bet they are pretty non helpful in the glove box. If the mileage is decent I may turn the fuel up some more to help the 62/71 along. Haha
Ryan
Old 04-01-2014, 08:48 PM   #117
6BT 56
6BT 56's Avatar
Ok i will bite and be the one who is going to look stupid. What is a 62/71?
Old 04-01-2014, 08:58 PM   #118
Dieselwrencher
No need to look or feel stupid. That is just the size of the compressor wheel and turbine wheel in the turbo. The compressor is 62mm at biggest point, the turbine wheel is 71mm at the largest point, and the turbine or exhaust housing is a 14. Which means it will flow 14cm2 through it. Typically you will see after market chargers listed in 3 number groupings typically. The turbo on this thing is 62/71/14.
Ryan
Old 04-01-2014, 09:01 PM   #119
Dieselwrencher
Today the rear end started making a thumping noise, so it is time to replace my apparently not so great ring and pinion for a new one. Hopefully the parts should be here Friday. Last night I put mud flaps on it and a steering stabilizer. While we're doing the rear end, I'm going to go ahead and put on a rear sway bar to help with body roll. She definitely sways a bit during fast lane changes at 70mph or so.
Ryan
Old 04-01-2014, 10:59 PM   #120
Ackattack
Ackattack's Avatar
Heck, I don't even have a front one, and she's fine at 70
That reminds me, I need to order some parts to make end links for mine.
Old 04-01-2014, 11:33 PM   #121
6lcummins
62mm Inducer on the compressor wheel and 71mm Exducer on the turbine wheel.
"STOCK"
ASSEMBLY THREAD
Old 04-01-2014, 11:38 PM   #122
mosesburb
I had a V-8
mosesburb's Avatar
Holy kick in the stones, Batman!! Man, that sucks. Glad you got it fixed up quick. I've been absent from this thread for a bit, but for some reason I thought you had this running a while back or at least were a whole lot closer than you actually were. I don't miss gelled diesel......ugh.
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 04-01-2014, 11:42 PM   #123
mosesburb
I had a V-8
mosesburb's Avatar
That is more than mine weighs with a full load of travel goods. Wow!!
Old 04-02-2014, 07:30 AM   #124
ryanroo
ryanroo's Avatar
ill go ahead and break it down since Ryan said it all wrong and you are speaking in turbo code.
the inducer is the inlet side of of the wheel, regardless of its orientation. the exducer is the outlet side of the wheel. so, in a turbocharger, the inducer side of the compressor is the side that you see when you look down its throat. the exducer side of the compressor is the big side that is at the back of the compressor housing.
the exducer of the turbine wheel is the small side, or the one you see when you look up the turbos butt. the inducer is the big side of that wheel in the front of the exhaust housing.
since the space available for the compressor to draw in air is the inducer and the space available for exhaust to exit the turbine is the exducer, you can get an idea for the air flow ability and depending on all kinds of other factors the power it will be able to make from knowing the size of the inducer on the compressor and the exducer on the turbine. the area of the exhaust housing, or the third number given in the size helps you determine how much fliud can pass through the housing at a given pressure. that will help determine the lag or how fast the turbo spools and has an effect on EGTs and drive pressure.
this thing seems to have a target on the gonad area, or maybe the wallet. but at least it should be a nice well done rig when finished! Ryan had it running/driving briefly, but it took a digger when the engine decided to knock.
72 K20 12v build
Old 04-02-2014, 02:11 PM   #125
Dieselwrencher
Good catch, IDK what I was thinking when I typed that out.
Yeah, I drove it about 42 miles in January and then the oil pan drain plug fell out. I thought I stopped it in time but I didn't. Definitely sucked, but it's a lesson learned.
Yeah, I knew they were heavy, but holly crap not this much.
Well said Ryan. And yeah, this thing has way of draining the pocket book or any account hooked to it. But, this is a part in building old trucks. This one had 179k on it and I'm sure they weren't all great miles. Haha
Ryan
