#101 |
Re: 47 Step van
Just noticed this build, wonder what's inside your head for ideas, must just be swirling inside there...but I sure do enjoy it, you have some wicked skill man. Thanks for sharing and the ideas for us to change up and use again.Rick/Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
#102 |
Re: 47 Step van
Bubba54, thank you. It did work out really well. The nice thing was that if i need a different box they would exchange it. I figured the right one so I did not need another one. They offer them every 2" in length.
99 to life, thank you. No I made the perforated part. I layed it out, center pinched it and drilled it with a 1/4" bit. Then opened it up to 3/8". It was over 100 3/8 holes. I used a unibit so I got a round hole. Mud.man.rj , thank you. My full time job I program and run Cnc mills. So when I am running it and the rest of the time I am always thinking of how to do things. I love to build things as you can probably tell. Feel free to use any of my ideas, always glad to show anyone. Shannon
48 Panel Truck 1948 Chevy / S10 1954 Chevy / S10 1951 Chevy / C4 47 Step van Lowered 1996 Dually |
#103 |
Re: 47 Step van
Today's progress was to make front marker light and buckets. Ken got a really good deal on the rear red ones and I made a matching set for the front. I have the material for when I make custom turn signals and tail light. I made the bucket with 1156 sockets and I bought 1156 LED bulbs. Then I figured out what I needed for the gas tank. Then started to blank out the pieces and paneled them for strength. I have the ends tacked on. It will have 2 baffles inside of it. It is a 20 gallon tank.
Shannon
#104 |
Re: 47 Step van
Pictures
Shannon
#105 |
Re: 47 Step van
More
Shannon
#106 |
Re: 47 Step van
Shannon
#107 |
Re: 47 Step van
Man...the talent in those hands..nice work.
#108 |
![]() Join Date: Oct 2007
Re: 47 Step van
Shannon is this how you make your tail lights normally for the trucks. Was curious how you went about them.
#109 |
Re: 47 Step van
Mud.man.rj, thank you very much.
Wickid demon, yes that is how I make them. The transparent acrylic and special cement comes from delvie's plastics inc online. The prismatic sheet on the back is defuser sheet from lowes for drop ceilings. I cut them out on my wood band saw or you can with a jig saw and buff them to shape on the belt sander. You can make any shape or size rather than what they make. I always use the 1157 or 1156 sockets from the parts houses and the LED bulbs. Not heat and not a lot of current. Nothing to it. Shannon
#110 |
Shannon Looks good as usual !!
Those teardrops will fit nicely
48 GMC Burb 51 Chevy AD 3100/C 4 byShannon 74 Chevy P 10 48 Double Duty 04 SS Burb 01 Springer HD |
#111 |
![]() Join Date: Mar 2011
Re: 47 Step van
Shannon, running out of words, great job...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#112 |
Re: 47 Step van
I the robot once again say, great work.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#113 |
Re: 47 Step van
48 GMC BURB, thank you. Yes they will fit nicely.
Oldman3, thank you 99 to Life, thank you Well I have the tank welded together and the baffles in. I still need to make the bongs for the fittings, put in the fuel sending unit and put the tube in for the fill. I also made the tank mount also. I have not gotten much done the week because we got snow on Monday and a ice storm on Wednesday which took out power at home and at work. We were fine because I have a generator and back feed the house through the garage welding outlet. So we had heat, power to the refrigerators, DVD player and TV. Our house is mostly gas so we had hot water and we have city water. There are still a lot of people without. I feel for them. Shannon
#114 |
Re: 47 Step van
The tank mount.
Shannon
#115 |
Re: 47 Step van
The tank.
Shannon
#116 |
Re: 47 Step van
The pair together. It will mount on the outside of the frame on the passenger side and the fill will be at the factory hole.
Shannon
#117 |
Re: 47 Step van
Looks very nice...Jim
#118 |
Re: 47 Step van
Looks good Shannon..Have you looked at "Balls" window kits ?
#119 |
Re: 47 Step van
Oldman3, thank you.
48 GMC BURB, thank you Here is my Sunday progress, I started to work on the heater/AC unit. I knew I was going to mount it on the drivers side because the glove box was on the passengers side and we want to keep it. The bad thing is that there is really no under the dash. There is a bulkhead in front of the dash but it is outside the interior area. So I ended up make a boxed in area for it to go in. If I would not have done that the floor heat would have went outside. So it worked out great. Now I will make the mounts for it. I will probably end up doing it tomorrow because we are getting hammered with more bad weather and snow. If you noticed from the pictures it was snowing on Sunday. I am so ready for spring to come. On a side note I got my front wheels put on my lowered dually. I have to widen the rear fenders 3 inches to fit the back wheels on. Shannon
#120 |
Re: 47 Step van
The box.
Shannon
#121 |
Re: 47 Step van
Heater box and my black truck.
Shannon
#122 |
Re: 47 Step van
Looks great Shannon. Is the heating and cooling only in the front? Big box for one unit.
#123 |
Re: 47 Step van
Shannon, nice looking setup...Jim
#124 |
Re: 47 Step van
Wickid demon, thank you. He had bought that and I think is going to also use a boat unit too. He does not want to put anything on the roof because of ruining the lines of the truck.
Oldman3 , thank you. Home today because it is snowing like hell. We are supposed to get 8-14 inches. Plans today, stay after the driveway and work in the garage for a little. Shannon
#125 |
Re: 47 Step van
Looks good as usual Shannon. Yes that unit is for the cab area ,I plan on a pocket door to separate the cab from the work area & use a marine unit in the back. ...Nice progress on the duley ! When you get dug out I need a pic of the trans where the speed sens is so I can have the wire harness mod done .TKS & stay warm!! Maby I shouldent mention it but it's 88 here in Brazil
