Old 01-06-2017, 11:13 PM   #101
hotrodelrod
hotrodelrod's Avatar
Re: Hotrodelrods 54 build
The previous builder had fab'd a "saddle" that the stock core support rested on. The Absolute/*****in core support brackets supplied are made to fit on the top of the stock frame rails. Because my front clip is a metric Gbody clip these wont work.
http://67-72chevytrucks.com/vboard/a...1&d=1483758578
I cut some square tube and welded a plate with slotted holes to mount to core support for future wiggle room if needed.
I used weld nuts to mount as to match new core support
hotrodelrod is offline   Reply With Quote
Old 01-06-2017, 11:58 PM   #102
Advanced Design
Advanced Design's Avatar
Nice fab work Rick. Looks good!
Advanced Design is offline   Reply With Quote
Old 01-08-2017, 01:30 AM   #103
joedoh
joedoh's Avatar
looking good!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 01-08-2017, 01:55 PM   #104
ptc
ptc's Avatar
Coming together really nice!!!! Youre on the downhill side now at this point! keep it going.
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 01-01-2018, 09:32 AM   #105
Advanced Design
Rick, have you been back in the shop? Any updates?
Old 01-26-2019, 09:30 PM   #106
hotrodelrod
Here we are 2 years blown by. I have started back on my 54. I was at a standstill, afraid to tackle the firewall, floors etc. but recently decided its time to dive in. So here is where we left off.
http://67-72chevytrucks.com/vboard/a...1&d=1548551863
I welded a couple of braces in the door openings to keep the front of the cab from shifting upon firewall and floor removal.
http://67-72chevytrucks.com/vboard/a...1&d=1548552071
I then cut out the stock firewall. A jigsaw/ cut off wheel combo worked well.
Next i used a flange/punch tool to punch holes around the perimeter of the new firewall for plug welds. I temporarily mounted it with a couple of self tapping screws and marked a line on the old firewall so I can trim it up. Also marked the hood hinge bolts for drilling the new holes
The flooring is just laid in place. Sorry the pics are out of order. Its been awhile. I hope everyone is doing well and I look forward to whats to come.
Rick
Old 01-26-2019, 09:31 PM   #107
hotrodelrod
Hi Doug. finally back at it 2 years later. Hope you are well.
Rick
Old 01-26-2019, 11:34 PM   #108
Advanced Design
Rick
Good to see you back Rick. 2018 was pretty rough here and I hope 2019 is way better.
Nice work you have going there! Thanks for the updates.
Old 01-27-2019, 12:24 AM   #109
oldman3
oldman3's Avatar
I agree, nice to see your back and working on the truck...Jim
oldman3 is offline   Reply With Quote
Old 01-27-2019, 01:01 AM   #110
joedoh
joedoh's Avatar
looks good!
Old 01-27-2019, 07:19 PM   #111
hotrodelrod
So I removed the firewall and drilled the hood hinge holes, trimmed the remaining edge of the factory firewall, and did some grinding/cleaning up of the kick panels. They had been filled with mud. I then reinstalled the new firewall and tacked it in place. I then cut out what remained of the stock floor to find that the front inner cab corners had been rotted out and filled with mud. Glad I braced the cab well. So now I need to replace the inner front cab corners and probably the rocker panels as they are "iffy" as well before I can move foreward with the floors. Can anyone recommend a quality source for these panels?
Old 01-27-2019, 11:57 PM   #112
84blaze
Looking good! I bought an abandoned project and it came with all the *****in sheet metal. I plan to use the core support, floors and toe boards and do a custom firewall in mine. I like seeing photos of it being installed!
84blaze is offline   Reply With Quote
