02-09-2023, 02:16 PM | #101 | |
Re: Installing The NV4500 5 Speed Overdrive Transmission In The C-30
Thomas |
02-09-2023, 03:08 PM | #102 | |
The Older Generation
Hi Thomas, Not Richard but check out my post #84. It explains what I did with mine. The secret is, if the hole is going to come out too close to the trans main case and force the bit off to the side, stop just as it starts to break through. All of the holes that weren't close to the case I drilled all the way through. LockDoc .
03-21-2023, 03:41 PM | #103 |
I have a question about the high hump transmission cover
Do any vendors sell a high hump transmission cover with no transmission shifter hole in it? |
03-21-2023, 04:55 PM | #104 | |
I'm pretty sure they are reproduced but I can't tell you off the top of my head who sells them.... EDIT: https://www.classicindustries.com/product/153761.html They are pretty proud of them. I'm sure there are other vendors that sell them too. I would put out some feelers in your area, you might get lucky.... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-21-2023 at 05:54 PM. |
03-21-2023, 06:35 PM | #105 |
Wow. They do think very highly of them.
05-21-2023, 10:31 PM | #106 |
Sorry to bring up a old thread, but would this technique work for a 4wd nv4500 obviously id have to move the crossmember on the back. Just wondering if the 4wd has the same stick out and pilot size as the sm465
1959 GMC 100 3 on the tree 270. 1968 GMC k2500 Stepside 1972 Chevy Monte Carlo Custom. |
05-21-2023, 11:48 PM | #107 | |
I can't answer your question. I have a 4x4 w/NV4500 setup in a '91 Chevy but the engine and trans are still in the truck. I need to get it dismantled but I don't have time right now. Maybe someone else will know the answer to your question. LockDoc
07-23-2023, 04:32 PM | #108 |
In May I bought a used NV4500(1993/94 GM version), and was told is was good and useable. I finally got it "installed" in the truck about a month ago and finally finally got a driveshaft made and installed a few days ago last thursday.
I installed it by drilling holes using Leons method. I did a very poor job, but it worked. The trans is bolted only using 3 of the 4 bolts, tightened with a combo wrench. Filled with Amsoil MTGQT-EA. It ran fine, I just wanted to drive it through the gears and specifically into 5th, no grinding, ran good, and I can proceed with other work on the truck knowing it *should* drive fine for the time being. Thank you Leon. Last edited by jumpsoffrock; 07-23-2023 at 04:40 PM. |
07-23-2023, 07:52 PM | #109 | |
No problem. Glad you got it dialed in. I don't know which bolt you had trouble with but I would definitely try to get it installed. That trans weighs close to 200 pounds and needs all of the bolts in it if possible..... LockDoc
