Old 04-26-2016, 12:01 AM   #101
MTCK
MTCK's Avatar
Re: Daddyjeep Hauler - 85 K30 crew cab short bed
Hahahaha that's great. How many tacks did you make before you noticed?
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 04-26-2016, 12:42 PM   #102
daddyjeep
daddyjeep's Avatar
Too many. luckily my light fits through the sending unit hole.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 04-26-2016, 01:17 PM   #103
68Timber
I know the pieces fit
68Timber's Avatar
Glad to see I'm not the only one does stuff like that. That's great.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 04-26-2016, 01:32 PM   #104
Chevy_mud_truck
Chevy_mud_truck's Avatar
At Least it was able to get it out
Chevy_mud_truck is offline   Reply With Quote
Old 04-26-2016, 09:50 PM   #105
daddyjeep
daddyjeep's Avatar
I finished up the notch in the tank tonight. There are a couple questionable spots that have a chance of leaking as well as some rust pitting in a couple spots. These areas will get a coat JB weld just to be sure.
[IMG][/IMG]
04 1500 crew cab
Old 04-26-2016, 10:00 PM   #106
68Timber
68Timber's Avatar
Looks great. You are right, that's a much bigger clearance than it appeared to need. Clean work!
John
74 Honda Z50 build
Old 05-01-2016, 05:36 PM   #107
daddyjeep
daddyjeep's Avatar
I had some scar tissue removed from my eye lid on Friday so I wasn't allowed to spend any time in the shop this weekend. Since the wife had to go to work for an hour or so, I might have snuck down to the shop.
I finished up coating all the weld seams with JB Weld and shot a few coats of rubberized undercoating. I also found out that my stock sending unit fits the Blazer tank nicely.
[IMG][/IMG]
[IMG][/IMG]
04 1500 crew cab
Old 05-03-2016, 12:53 PM   #108
daddyjeep
daddyjeep's Avatar
I at least got the tank ratchet strapped in place last night in between all the other crap I have to do every night. Who's idea was it to have kids anyway? I'm going to have to have a talk with the wife. I did get one tank strap built out of some 1/8" x 1 1/2" strap and some all thread, but in the pic the ratchet strap is still holding the tank. I am real happy with the tanks mod. I just hope it holds gas.
[IMG][/IMG]
[IMG][/IMG]
04 1500 crew cab
Old 05-03-2016, 01:05 PM   #109
68Timber
68Timber's Avatar
Looks good! What kind of magic did you use to get rid of gas vapors etc so you could cut and weld on it?
John
74 Honda Z50 build
Old 05-03-2016, 01:22 PM   #110
daddyjeep
daddyjeep's Avatar
No magic. This tank had been sitting in the front seat of a Blazer for years. I just vacuumed out the spider webs and dead mouse and started welding.
04 1500 crew cab
Old 05-10-2016, 01:04 PM   #111
daddyjeep
daddyjeep's Avatar
I finally got the hitch modified, painted, and installed. I had to relocate the middle bolt tab and drill new holes in the frame for the front bolt. Then I could finally install the tank. I still need to level it and then start plumbing.
[IMG][/IMG]
[IMG][/IMG]
04 1500 crew cab
Old 05-12-2016, 10:29 PM   #112
daddyjeep
daddyjeep's Avatar
I really wish I had time to strip this truck down to a bare frame. I started plumbing tonight and the General sure liked to hide the bolts that hold the factory hard lines to the frame. The engine bay and frame have a nice heavy coat of oil and sludge that makes a real nice skin conditioner. I drove greasy leaky junk for years and I really don't care to go back there, but since I need this functional soon I'm going to have to suck it up I guess.
04 1500 crew cab
Old 05-12-2016, 10:57 PM   #113
MTCK
MTCK's Avatar
I hear ya. Had to make similar compromises on mine. I tried to really clean up everything I touched, but didn't go looking for side projects. It'll feel good when you're on the road. Maybe blow it apart next winter...
-Marcus
Project Plow Truck
Old 05-12-2016, 11:46 PM   #114
daddyjeep
daddyjeep's Avatar
That is definitely the plan. Get through the summer dragging the Jeep around and tear it down properly over the winter.
04 1500 crew cab
Old 05-13-2016, 12:15 AM   #115
tinydb84
tinydb84's Avatar
Love the light in the gas tank. Made my day. I'll just pretend I havent done stuff like that a hundred times...
David
Instagram: myfabguy
Old 05-18-2016, 09:54 PM   #116
daddyjeep
daddyjeep's Avatar
I got the floor sprayed with some self etching primer and covered all the welds with seam sealer. I also got the first coat of filler on all the external seams. Oh how I love sanding.
[IMG][/IMG]
[IMG][/IMG]
04 1500 crew cab
Old 05-19-2016, 01:00 PM   #117
daddyjeep
daddyjeep's Avatar
I forgot to mention, for those that are referencing the modification of the rocker panel for the rear door i had to make a change. The radius at the front of the rear door had to be modified. You can see in the last pic that I had to make a bunch of relief cuts in the lip for the weatherstripping so I could tighten up the radius. After cutting that area out, reforming it, and welding it back in I was left with about a 1 inch gap to fill. I should have gotten some pics, but did not. In order to ensure that the radius was correct I made a cardboard template of the passenger side.
04 1500 crew cab
Old 05-19-2016, 11:03 PM   #118
daddyjeep
daddyjeep's Avatar
More sanding tonight and a second coat of filler. did I mention I hate sanding. I have respect for body guys.
[IMG][/IMG]
[IMG][/IMG]
04 1500 crew cab
Old 05-20-2016, 03:12 PM   #119
Woodyboat
Woodyboat's Avatar
Daddyjeep, I just found your thread thanx to a heads-up from Front Range. I will need to be repairing the rust on my Crew Cab dually as well. Honestly, it looks our two trucks have virtually the same amount of rust in the same exact places. So I REALLY appreciate your contributions to this forum and your sharing this thread with us.
So, I noticed that you decided to use two replacement rocker panels from single cabs instead of just one panel for a crew cab. (Maybe I need to re-read the thread) If you had to do it over again, would you go the same route or get the panel made just for the Crew cab?
Woodyboat is offline   Reply With Quote
Old 05-20-2016, 04:21 PM   #120
daddyjeep
daddyjeep's Avatar
Thanks for checking in Woodyboat. If I could have found a complete rocker panel for a crew cab I would have absolutely used that. The problem is that they are not available. The only crew cab specific rocker I could find is a slip on, which does not include the door sills or the part that ties into the fender mount. Someone posted that rear door rockers were once available, but they are hard to find and expensive. I hope this helps in your planning.
04 1500 crew cab
Old 05-20-2016, 05:15 PM   #121
Woodyboat
Woodyboat's Avatar
Originally Posted by daddyjeep View Post
...If I could have found a complete rocker panel for a crew cab I would have absolutely used that...
Yes, I can see that now. The key word is "complete." If you could have found a COMPLETE rocker panel, you would have used it. The rust on my dually extends well beyond what I can see would be covered if I ordered the one shown in the LMC catalog. I really wish those folks could offer some better photos of their replacements parts. This is 2016 now. Do we still have to rely on illustrations like those in a JC Whitney catalog?
Haha, on this forum I need to remind myself that "CC" stands for Crew Cab and NOT Chris Craft. LOL
Old 05-20-2016, 05:53 PM   #122
Woodyboat
Woodyboat's Avatar
Ok I'm back. daddyjeep, I went to your Photobucket page and viewed all your photos, even expanding each one and studying it at length. It is amazing how similar our two trucks are and how they both have rusted in exactly the same places in the same ways. I only paid $800 for this truck but even then, I've had that overwhelming feeling that I may have paid too much. But, I feel a lot better now that I can see the progress you're making.
I really think you went the right way with two sets of rockers from a single cab. The curvatures at the ends of each panel are correct using your method. If I were to get the CC panel from LMC, those curves would still have to be fabricated and I just don't want to go there. But doing it your way saves all that work and then transfers the fabbing to middle of each door opening - place a beginner like myself can be successful.
Old 05-20-2016, 07:17 PM   #123
daddyjeep
daddyjeep's Avatar
Check post 117. I did have to modify the curve at the front of the rear door openings.
04 1500 crew cab
Old 05-20-2016, 08:29 PM   #124
Woodyboat
Woodyboat's Avatar
Ok, I see it now. I missed that the first time through. But, we're not building show trucks here and that looks darn good to me. In fact, I'd be very happy if mine turns out that good - which I think it will cause I am willing to keep at it until I get it just right. That's a good solution.
Old 05-20-2016, 11:25 PM   #125
daddyjeep
daddyjeep's Avatar
More sanding, more filler, more sanding...good enough. I don't have time for perfection. This truck needs to tow the Jeep in 3 weeks. I also got a couple coats of rubberized undercoating on the drivers side floor and installed a new fuel pump tonight.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
04 1500 crew cab
