Old 01-10-2017, 12:54 PM   #101
MarleyMarvelous
Re: A real BadSeed
*Or welder. Haha
MarleyMarvelous is offline   Reply With Quote
Old 01-10-2017, 03:21 PM   #102
Steven R
Re: A real BadSeed
Thanks for the welding setting notes. I happen to have the same welder. It nice to be able to compare notes and settings from time to time. Please take note you got skills you can be proud of.
tks I look forward you the rest of you build
Steven R is offline   Reply With Quote
Old 01-11-2017, 12:18 AM   #103
MarleyMarvelous
Re: A real BadSeed
Thank you Steven R
Old 01-11-2017, 02:02 PM   #104
Couch
Daily Driver
Couch's Avatar
Re: A real BadSeed
awesome thread man, and great work! i too am building a c-10 that belonged to my dad that i have very similar childhood memories to your own in it. im subscribed and will be following along with this build. keep up the killer work!
nitrous...the equal opportunity destroyer.
Couch is offline   Reply With Quote
Old 01-23-2017, 12:01 AM   #105
MarleyMarvelous
Re: A real BadSeed
I've been stackin up some parts. I got a new core support because the stock one had herpe. And the gears and posi came in.
Old 01-23-2017, 12:07 AM   #106
MarleyMarvelous
Re: A real BadSeed
I also got the axle stripped of all it's seals and bearings.
Old 01-23-2017, 10:33 AM   #107
Oregon 1967 GMC
Oregon 1967 GMC's Avatar
Re: A real BadSeed
wow you are getting it together brother!
Hey man
67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603
Oregon 1967 GMC is offline   Reply With Quote
Old 01-29-2017, 11:16 PM   #108
MarleyMarvelous
Re: A real BadSeed
I made a little progress today. Got the axle brackets and bag mounts on.
Old 01-30-2017, 02:06 AM   #109
MarleyMarvelous
Re: A real BadSeed
Boom
Old 02-04-2017, 04:54 PM   #110
MarleyMarvelous
Re: A real BadSeed
I got the posi locker and new diff cover, rear bags, new axle seals, discs and calipers all installed.
Old 02-04-2017, 05:12 PM   #111
Oregon 1967 GMC
Re: A real BadSeed
uh-oh it's getting real serious now!
Hey man
Old 02-13-2017, 01:01 AM   #112
rustytruck50
rustytruck50's Avatar
Re: A real BadSeed
Looking good! Any updates?
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 02-13-2017, 04:47 AM   #113
MarleyMarvelous
Re: A real BadSeed
UPDATE:
I had to do something about this step in the frame horns. My core support wouldn't sit flush with the frame and my sway bar mounts weren't able to sit flat.
Old 02-13-2017, 04:47 AM   #114
MarleyMarvelous
Re: A real BadSeed
Better.
Old 02-13-2017, 05:03 AM   #115
MarleyMarvelous
Re: A real BadSeed
Had to trim the headlight buckets to fit the Halo headlights.
Old 02-13-2017, 11:10 PM   #116
Pinky6872
Re: A real BadSeed
That frame horn modification looks awfully familiar. Nice work!
My Dropmember Equipped Build
Instagram @chrispinkosky
Pinky6872 is offline   Reply With Quote
Old 02-13-2017, 11:29 PM   #117
MarleyMarvelous
Re: A real BadSeed
I learned it from watching you Pinky. Haha
Old 02-13-2017, 11:31 PM   #118
MarleyMarvelous
Re: A real BadSeed
Installed a few more pieces tonight.
Old 02-15-2017, 02:35 PM   #119
MarleyMarvelous
Re: A real BadSeed
Recieved my Radiator and fans. Waiting on the shroud
Old 02-15-2017, 02:45 PM   #120
mooseknuckles
mooseknuckles's Avatar
Re: A real BadSeed
nice work!
mooseknuckles is offline   Reply With Quote
Old 02-15-2017, 03:30 PM   #121
Phill0406
Phill0406's Avatar
Re: A real BadSeed
Unbelievably jealous of you fab work, I hope to have half these skills one day.
When welding on the bottom brackets to the bags, did you just set your pinion angle at the 1 up that porterbuilt recommends and put the plates in level?
Phill0406 is offline   Reply With Quote
Old 02-15-2017, 08:03 PM   #122
MarleyMarvelous
Re: A real BadSeed
Yes.
Old 02-15-2017, 08:04 PM   #123
MarleyMarvelous
Re: A real BadSeed
Thanks for the compliments guys!
Old 02-16-2017, 11:15 PM   #124
MarleyMarvelous
Re: A real BadSeed
I designed these little perches to hang off the side of my rear frame rails and support the fuel cell a little closer to the cell wall it's self. The bolt needed to be right at the edge of my alrerady boxed frame. So, I cut some relieif holes and came up with the tube to cover my bolt and welded nut.
Old 02-20-2017, 03:48 PM   #125
MarleyMarvelous
Re: A real BadSeed
Yesterday, I built my rear crossmember. I wanted rounded corners but mandrel bent frame rails aren't in the budget. So, here's how I tackled that task.
67 c10, badseed, marley marvelous
