Old 03-10-2019, 04:30 PM   #101
knomadd
knomadd's Avatar
Re: 72 Swb starting from the bottom
That's a pretty cool location. Nice and clean when closed, easily accessible to the driver, I like it!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 03-13-2019, 09:38 AM   #102
J3rm0ff
Thanks! now to figure out some sort of hinge to keep it closed and open. I had to cut off the spring steel thing off the back which kept it opened or closed.
J3rm0ff is offline   Reply With Quote
Old 03-13-2019, 08:38 PM   #103
J3rm0ff
Picked up a flaming river tilt column today for a real good deal. The only thing I’m not sure about is the neutral safety switch it’s right in the way of the brake bracket. Solved my issue of needing a tilt but now I have that issue lol. Never ending.
Old 03-15-2019, 09:04 AM   #104
knomadd
knomadd's Avatar
It's always something with custom work. You've gone this far, I'm sure you'll have a solution soon. Wish I had an idea to put out there for you.
-Duane
Old 03-19-2019, 09:48 PM   #105
J3rm0ff
Finished up the drivers side dash end. Started Shaving the factory heater control opening. Also got a set of CHE trunion bushings installed after having some bad luck with the BTR trunion bearings. Very happy with the CHE kit. Going to be dropping these off at the machine shop Friday and the. Hopefully my engine will finally be getting wrapped up.
Old 03-21-2019, 01:35 AM   #106
tinydb84
tinydb84's Avatar
I love that dash. Looks great.
David
Instagram: myfabguy
Old 03-21-2019, 10:28 PM   #107
J3rm0ff
Thanks!
Tonight I got the steering column mounted using the factory mounts.
Old 03-26-2019, 10:09 PM   #108
J3rm0ff
Working on the dash more. I bolted the gauges in and ser a seat in there and I’m not liking how far the steering wheel seems to be coming into the cab not sure if this is how it normally is or not.
Old 03-29-2019, 10:12 PM   #109
J3rm0ff
Pushed the truck aside to give some love to the c7. Dang it I need a bigger garage.
Old 04-08-2019, 09:10 PM   #110
J3rm0ff
Spent pretty much all last week getting the c7 cleaned up, polished and then ceramic coated. Hard to take a picture of a white car but it came out great!
Today I worked on something easy and got the coolant overflow mounted.
Old 04-16-2019, 09:26 PM   #111
J3rm0ff
Couldn’t figure out a way to keep the door closed after hacking up the factory stuff from the impala so i completely redid the hinge style and door and the way the controls were mounted. Came out a million times better than it was before. I have some air vents on the way to try out then Hopefully maybe possibly this dash will get welded in.
Old 07-05-2019, 10:06 AM   #112
J3rm0ff
Haven’t worked on the truck much the past couple months. I got a billet specialties steering wheel. Also change around the turbo side intercooler piping one last time so I could move the wastegate location so I wouldn’t run into any issues with the heater hoses.
Old 07-13-2019, 02:11 PM   #113
J3rm0ff
Finally got the engine back from the machine shop. It is basically brand new now. Everything has been gone over and replaced. Wiseco Pistons, k1 Rods, arp main studs and bolts, arp rod bolts, arp head studs, btr stage 2 turbo cam, Che rocker bushing kit, btr valve spring kit. Hoping this will all be worth it to not have to worry about anything. Sprayed it when I got it home so I didn’t have to worry about the surface rust. Also finished up the wastegate tube goin into the downpipe.
Old 07-21-2019, 08:44 PM   #114
J3rm0ff
Completely tore down the truck. Hopefully the frame will be painted by the end of the week. I made a makeshift rotisserie with my engine stand and borrowed my dads. A little sketchy but it gets the job done lol.
Old 07-26-2019, 07:19 PM   #115
J3rm0ff
2 coats of black epoxy primer and 1 coat of summit racing satin chassis black and the frame is painted.
Old 07-27-2019, 12:57 AM   #116
cornerstone
cornerstone's Avatar
Mission accomplished! Nice work man.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 07-31-2019, 09:38 AM   #117
J3rm0ff
thats one accomplishment. many more to go lol. Thanks
Old 08-08-2019, 09:47 PM   #118
J3rm0ff
I finally settled on this location for the airlift manifold. Had to weld it to the purty Trans crossmember but sometimes that’s the way she goes.
Old 08-22-2019, 09:49 PM   #119
J3rm0ff
Got the frame pushed over to the house garage and started running the air lines and airlift wiring.
Old 08-24-2019, 07:55 PM   #120
cornerstone
Thats one bad mambajamba brotha. I like the bracket that holds the airlines straight and steady into the manifold. I need to make one for my application.
Brian
Old 09-20-2019, 07:47 PM   #121
J3rm0ff
My phone camera stopped working so I haven’t been able to take pictures for a while. I picked up the manifolds and turbo housing from ceramic coating and for that on. Got the water pump, ac compressor, and alternator painted black and cleared with satin clear coat. I’m happy with how they came out. Now I’m working on the bottom of the cab to get it primed and finishing up the air lines on the frame. Also got the trans back from being rebuilt/ upgraded and shift kit installed. Now just need to get in painted and get a converter orders and I can set everything back into the frame!
Old 09-20-2019, 08:39 PM   #122
KMC3420
KMC3420's Avatar
Awesome progress! Keep it up.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 09-20-2019, 10:45 PM   #123
low69chevy
low69chevy's Avatar
Post Re: 72 Swb starting from the bottom
Nice project keep up the good work
low69chevy is offline   Reply With Quote
Old 09-27-2019, 11:58 AM   #124
J3rm0ff
Spent a few nights after work at my dads and got the brake caliper adapters made to fit the camaro ss Brembos on the front. Pretty excited about these.
Old 09-28-2019, 11:32 PM   #125
J3rm0ff
Got the bottom of the cab primed today. Good to finally see it in primer considering it’s been bare steel since I’ve owned it.
