Old 04-11-2017, 11:52 PM   #1276
62stepside longbox
62stepside longbox's Avatar
Re: Nik's 62 build
Originally Posted by Grizz1963 View Post
Nick, I love the way you just quietly get on with stuff.
Changing the rounded door frames to square is really genius, and you guys did well there.
West coast mirrors, I love them. Not right for my trucks style, but they always look great.
Glad you found a good set, for presumably sensible money.
Thanks for the compliments rian
Originally Posted by TJ's Chevy View Post
Nice find on the mirrors man. I'm gonna be keeping mine for when my 66 is done.
Thanks Tj, they are not what I was thinking of when I bought my truck, but seeing how good they look on many of the trucks on the forum made me realize that they are what I really want, I'm pretty happy with these.
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 04-14-2017, 07:48 PM   #1277
62stepside longbox
Re: Nik's 62 build
I've been busy and the weather has been bad for the past week or so and I haven't got much done. But today was the first day of a four day long weekend so I got to work on the panhard bar. I decided to use the stock 60-62 panhard bar and bracket, so I cut the bracket off of the old rear end. I bolted one end of the panhard bar to the frame and made sure the rear end was centred under the frame. I then tack welded the bracket to the rear end and checked to make sure it was all good.
Old 04-14-2017, 07:51 PM   #1278
62stepside longbox
Re: Nik's 62 build
Once confirmed it was in the correct spot I welded it on solid. It still needs painting just as the rear end cover does as well.
Old 04-15-2017, 06:00 PM   #1279
realvc
realvc's Avatar
Re: Nik's 62 build
Way to go on all counts of your truck build.
The attention to detail and the over all way you have crafted your mods. is very inspiring to me.
I'm just plodding along trying to figure out how to do some of what you have done.
The power steering sector to frame mod. is too cool. I had wondered about doing something similar and notching the frame to allow the sector to mount like on the late model frame. I had also thought about cutting the frame where the sector mounts on my donor truck and wielding that section into the 62 frame.
The way you built your on power brake and clutch master cylinder mount is really impressive as is all your work on your truck and your dad's.
I had a very rough time getting the control arm bushings off of my donor control arms too.
Congrats. on your progress and on a very nice truck. Also this is one of the best build threads on the forum.
Thanks too for your kind words on my thread.
Vince
Galatians 6:14
62 SWB stepside, 94 Wrangler, 99 Z71, 99 vette
My Project http://67-72chevytrucks.com/vboard/s...d.php?t=719086
"If it's too loud, you're too old"
realvc is offline   Reply With Quote
Old 04-17-2017, 12:41 AM   #1280
62stepside longbox
Re: Nik's 62 build
Thank you so much for all of the compliments Vince! If you have any questions about any of the mods I have done feel free to ask! I've also been enjoying your build lots, not too many of us guys modifying 60-62 trucks as they are like the black sheep of 60-66 trucks.
Today I spent some time on brake lines, I cut one piece that goes from the proportioning block to the front drivers brake hose. I made double inverted flares on both sides.
Old 04-17-2017, 12:44 AM   #1281
62stepside longbox
Re: Nik's 62 build
And without a line bending tool I needed some other way to make nice bends in the line. So I just used a piece of exhaust tubing and wrapped the line around, then slid it off. I then installed the line, I still need to pick up some parts such as brake hoses, calipers and pads but it's getting close, should be on the road in no time
Old 04-17-2017, 12:48 AM   #1282
62stepside longbox
Re: Nik's 62 build
Also spent some time disassembling the mirrors, I got the arms all stripped down to bare metal with the wire wheel.
Old 04-18-2017, 08:58 PM   #1283
AJCK87
Re: Nik's 62 build
Originally Posted by 62stepside longbox View Post
Thanks buddy, when you come here in the summer we'll head there to go on a little hunt. Let me know specifically some of the things you might need and I'll let you know if it's there.
Beauty! Yeah I'll keep you posted on the travel plans. The wife and I will be going to the UK for three weeks in June and I have a family reunion on August, I will be making a plan to travel out to the Okanagan some time in between. I will for sure keep in touch. As for parts, I'll have to figure it out, I'm thinking some nice bed sides to finish up the rust repair on the rear quarters.
AJCK87 is offline   Reply With Quote
Old 04-25-2017, 04:29 PM   #1284
62stepside longbox
Re: Nik's 62 build
Sounds good! Let me know when it comes closer to the summer. Not sure if he'll have a bed he wants to cut up, but I can check.
Old 04-25-2017, 04:32 PM   #1285
62stepside longbox
Re: Nik's 62 build
The past week or so I've been under the weather with a nasty cold and haven't gotten much done, but I'm thinking I should be feeling better in the next couple days so I should have a progress update this weekend for you guys.
Old 04-30-2017, 10:29 PM   #1286
62stepside longbox
Re: Nik's 62 build
This weekend I finally was starting to feel a little better after my cold so I went out and worked on the truck. I removed the power steering pump and bracket and gave them a good clean and painted them up in gloss black. I allowed them to dry and them reinstalled them.
Old 04-30-2017, 10:37 PM   #1287
62stepside longbox
Re: Nik's 62 build
I also did some work on brake lines. I bent up this peice out of new line an slipped the old coil over it (don't know what it's really called but it looks like a spring and slides over the brake line).
Old 04-30-2017, 10:38 PM   #1288
62stepside longbox
Re: Nik's 62 build
A close up of the double flares I made.
Old 05-01-2017, 06:45 AM   #1289
realvc
realvc's Avatar
Re: Nik's 62 build
Glad to hear you are feeling better and able to get in some truck time.
Vince
Galatians 6:14
Old 05-01-2017, 11:06 AM   #1290
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: Nik's 62 build
Progress
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 05-01-2017, 02:01 PM   #1291
Re: Nik's 62 build
Glad you are up and about again. Work looks good as always.
Old 05-02-2017, 02:53 AM   #1292
62stepside longbox
Re: Nik's 62 build
Thanks Vince, truck time is always a good way to recover
Progress
Oh yeah
Thanks bill 🙂
Old 05-02-2017, 10:41 AM   #1293
65sub
65sub's Avatar
Re: Nik's 62 build
Hey Nik. Glad you're feeling better. Truck time is the best therapy.
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 05-02-2017, 07:21 PM   #1294
62stepside longbox
Re: Nik's 62 build
Thanks Dale, and yes I couldn't agree more.
The past few days it's been about 15 degrees and sunny here, I'm glad to finally see the weather get nice after the long winter, It's much more enjoyable working outside.
Today I got a lot of work done at school in the shop. I scavenged up some old exhaust systems and cut off enough tubing to finish my exhaust so when I fire the truck up I won't piss off the neighbors again! . I then spent some time building a radiatior shroud. I cut two pieces of 4.5"- 36" 20 ga sheet metal on the foot shear and then used the roller to make them into half circles. I then bead rolled both to add strength and just because it looks nice. Here they are, I'm extremely pleased with how they came out.
Old 05-02-2017, 07:23 PM   #1295
62stepside longbox
Re: Nik's 62 build
Another shot. I just can't get over how good they look!
Old 05-02-2017, 07:25 PM   #1296
62stepside longbox
Re: Nik's 62 build
I still need to bolt the two pieces together to make it a full circle and make up some mounting brackets but I wanted to test fit it first, here it is mocked up sitting flush against the radiator.
Old 05-02-2017, 09:09 PM   #1297
Classic v6 GMC's
Classic v6 GMC's's Avatar
Re: Nik's 62 build
WOW! That shroud is very nice!
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 05-03-2017, 12:14 AM   #1298
Captainfab
60-66 Nut
Re: Nik's 62 build
Very nice work on the shroud Nik
Old 05-03-2017, 06:32 AM   #1299
realvc
realvc's Avatar
Re: Nik's 62 build
Great job on the shroud.
Vince
Galatians 6:14
Old 05-03-2017, 12:52 PM   #1300
AJCK87
Re: Nik's 62 build
Awesome job! Glad to hear your feeling better, the colds have been going around
