Closed Thread
Old 01-11-2011, 12:28 AM   #1301
bc gman
71 bb longhorn
Re: What did you do to your truck today!
I put the door handles back on put the new tailgate trim on,window felt.
71 2500 Gmc longhorn with a 402 turbo 400.
09 F150 Supercrew 4x4
05 Mazda 6 sport
accept that somedays you are the statue
and somedays you are the pigeon.
bc gman is offline
Old 01-11-2011, 12:39 AM   #1302
k7elh
k7elh's Avatar
I drove it to work, then drove it home again...
Eric Hutchins
1970 Chevy C10 CST
k7elh is offline
Old 01-11-2011, 12:58 AM   #1303
60ratrod
yes, i do
60ratrod's Avatar
looked at parts for it. mostly on ebay
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline
Old 01-11-2011, 09:43 AM   #1304
dixietruck71
dixietruck71's Avatar
i drove it to work, drove home. then polished 2 of my slot mags. its way to much work but worth it in the end.
71 gme Sierra Grande lwb.
68 Rambler American 2 door
75 jeep cj5
dixietruck71 is offline
Old 01-11-2011, 01:48 PM   #1305
Dano69c10
Dano69c10's Avatar
Originally Posted by glider_6969 View Post
Updated pic of the new steering wheel, and completed the install on the new floorshifter and linkage and removed shifter off the column.
Hey Glider,
Do have a high hump or low hump cab? Is that a hurst shifter? I like the way that setup looks.
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline
Old 01-11-2011, 08:51 PM   #1306
glider_6969
Originally Posted by Dano69c10 View Post
Hey Glider,
Dano
Hey Dano, thanks,
I have a low hump. I originally did buy a Hurst but sent it back , the shifter seemed like it was going to be a bit short and I didn't want to have to lean forward to have to shift, plus it was about $100 bucks more than the one I put in which is from MR. Gasket, I did the install by myself, it wasn't to bad. almost forgot, the Hurst kit didn't even come with shifter boot cover. I would have had to buy that extra.
glider_6969 is offline
Old 01-11-2011, 08:59 PM   #1307
Navy Mechanic
Navy Mechanic's Avatar
Removed driver's side A-arm, spindle, rotor, spring, shock...
Install new components tomorrow.
"Once a Chief, always a Chief!" MCPO (ret)
03 2500HD- 'Daily driver'
67 Short Fleet- 'Drivable project!'
11 Malibu LTZ- 'The Wife's ride'
Navy Mechanic is offline
Old 01-11-2011, 11:15 PM   #1308
70 net440
Junior Member
70 net440's Avatar
Drove my kid's '71 K-10 to work, then to hoop practice, then home.
63 C10
70 Coronet R/T
67 C10
70 Dart Swinger
71 K10
70 net440 is offline
Old 01-12-2011, 12:09 AM   #1309
project 67 sub
project 67 sub's Avatar
bought anther set of bags, some 2600 doms and some fittings and line to run it on shraders. will be putting those in the back, and removing the dual 3/4 port 4 ply 2600 contis from the rear and putting them in the front when im ready. also bought a few more tools to use when i work on my truck.
project 67 sub is offline
Old 01-12-2011, 01:05 AM   #1310
Dano69c10
Dano69c10's Avatar
Got the crossmember off today;
'69 Fleet
Old 01-12-2011, 01:11 AM   #1311
mcmlxix
Collector of Projects
mcmlxix's Avatar
Ordered a DIY4X rear flip kit to get rid of the blocks and get read for the 14bff...
Rich
1972 K5 Blazer CST Click HERE
mcmlxix is offline
Old 01-12-2011, 02:13 AM   #1312
k7elh
k7elh's Avatar
These old slot mags just scream classic IMO... I love em. When I was a kid (many moons ago), I bought a set of mags for my first car, and they didn't fit. I kept them, thinking one day I might be able to use them. My dad told me to get rid of them, so I hid them under my bed! I got to use them after all when they fit my next car perfectly. Now if I could find a cheap set for my truck...
Eric Hutchins
1970 Chevy C10 CST
k7elh is offline
Old 01-12-2011, 02:34 AM   #1313
alwaysbroken
i watched it snow.
chevys the way to go.
alwaysbroken is offline
Old 01-12-2011, 02:50 AM   #1314
jakeblues652
jakeblues652's Avatar
Originally Posted by alwaysbroken View Post
i watched it snow.
i was waiting by the window for the snow! oh, and i tested the posi
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains
Originally Posted by Dan in Pasadena View Post
Did you figure out how to fix it?...I mean with other than a BFH?!
want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there
jakeblues652 is offline
Old 01-12-2011, 02:36 PM   #1315
dixietruck71
what lug pattern do you need? i have lots of mags and if i dont have any i can usually get them for 25 bucks each
75 jeep cj5
Old 01-12-2011, 03:28 PM   #1316
AZChevyland
AZChevyland's Avatar
Well it was the weekend but GOT THE WHEELS ON!
J&S Sideyard Projects......we will be at...... Dino's 3rd annual Pre-ShowGit Down
AZChevyland is offline
Old 01-12-2011, 03:47 PM   #1317
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
gonna look good!! ^ boss?
John
1999 Toyota Tacoma 4x4
oldblue1968chevy is offline
Old 01-12-2011, 03:54 PM   #1318
robertadkinsjr
robertadkinsjr's Avatar
Finally got the engine in. Now just gotta rerun wiring, hoses, vacuum lines, fuel lines, and button up.
robertadkinsjr is offline
Old 01-12-2011, 04:09 PM   #1319
BossHogg69
motor exploder
BossHogg69's Avatar
Got the motor & trans set down in the frame (mock up), had to dimple the #1 primary tube to clear the motor mount bracket. Now I gotta hack up my brand new trans crossmember to work on my Tremec TKO trans
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline
Old 01-12-2011, 04:42 PM   #1320
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Don't forget the monkey wrench.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 01-12-2011, 05:01 PM   #1321
helldiablo
nothing, looked at her, and said "soon enough sweetie" soon enough".... i dont think Society is ready for my truck to come out of hibernation.. but i think i gave Society a long enough break.... hahahaha.. they'll never take me alive!!!
helldiablo is offline
Old 01-12-2011, 05:06 PM   #1322
bigdogboxers
bigdogboxers's Avatar
I have watched the tire slowly loose air over the past few weeks....
bigdogboxers is offline
Old 01-12-2011, 05:11 PM   #1323
Dano69c10
Dano69c10's Avatar
Dropped the rear suspension from the frame;
Finsihed gutting the cab, getting ready to separate the cab from the frame.
Dano
'69 Fleet
Old 01-12-2011, 05:12 PM   #1324
Gene
Gene's Avatar
Re-installed dash wiring and started hooking up new under hood and front light harnesses.
Gene is offline
Old 01-12-2011, 07:39 PM   #1325
project 67 sub
ordered a double adjustable panhard bar from porterbuilt . i already cant wait for it
Closed Thread
