Old 07-13-2012, 07:10 PM   #1301
jlsanborn
jlsanborn's Avatar
Re: Make it handle
Rob,
I've sent you PM regarding my No Limit parts. Look forward to seeing your column! When do you suppose the first issue date would be? Have a specific topic picked out?
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 07-20-2012, 12:48 PM   #1302
robnolimit
robnolimit's Avatar
Re: Make it handle
SHOCKSI'm seeing a lot of talk here lately about shocks, so how about we talk about them here. First we all need to understand what a shock is. A shock is a dampner, or a device used to control the suspesion movement, by regulating how fast the suspension can compress or rebound givin a certian amount of load. The shock works in two directions. Compresion and rebound, or closing and opening. On most cars and trucks, the compresion rate is different than the rebound rate to make the car/truck feel balanced. Some of the forces that come in to play are, the total weight of the vehicle, the corner weight per shock, the motion ratio of the suspesion/shock travel, shock angle, unsprung weight, weight transfer due to braking, acceleration and/or cornering, speed, and size and shape of the road surface, and or bumps.
Here's where we're all screwed - we own trucks. The shock world is focused on cars. Performance, ride quality, testing..., it's all about cars. Except for off road shocks, built for a certain type of truck, still, not for a performance oriented street truck. So, your screwed. - until you learn about shocks AND trucks.
Why is a truck so different? Take a look and remember all tha factors that go into a shock. Your truck is REALLY nose heavy. also, the rear is REALLY light. The truck is too heavy, and the center of gravity us too high. This means it has a lOT more weight transfer under braking, acceleration, cornering, than a car. Truck susension parts are heavy, and we run bigger, heavier wheel and tire combos, so unsprung weight is way up too. all of this is bad. Now remember this, ALL performance shocks are designed for cars.
So, its up to you to think about it, and figure out how to pick shocks that might help. When we started with Romic shocks, They were, and still are, really good about working with us to get what we wanted. Most companies sell "coil-overs", front or rear, whatever, same part. So we kept going back to them - Rear shocks must be softer, again. and front compression must be firmer, again, and again. We would test, they would dyno, build more, we test, ..... Here is what we came up with.
First of all, most springs, on most trucks, are WAY TOO STIFF. They are trucks afterall, and, the aftermarket seams to copy the stock spring, but shorter, and most times, even stiffer. - not helping. This makes the shock problem even harder. Weight is a big issue, so front shocks are way different than rear shocks. For basics, we need a front shock that has a firm compression, and even firmer rebound. On the rear, we need a really soft compression, and a medium/firm rebound.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 07-20-2012, 06:11 PM   #1303
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Make it handle
If i call bilstein can they make a custom shock that will work for these trucks?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 07-20-2012, 07:26 PM   #1304
robnolimit
robnolimit's Avatar
Re: Make it handle
Many shock manufacturers can do custom builds, but you may have to tell them what you want. This is exactly why I wanted to start this discussion. Many people have commented how they are happy, or unhappy, with a certain shock. I have found that I need to mix and match to get what I want.
I used to use a lot of shocks from Carrera Shocks. They were bought out by Q-A1. They had some performance spec shocks that you could cutom order based on three things. Length, Mounting, andValving. The valving was based on a 1 to 9 scale, 1 = xx soft, 9 = xx firm. Split valve shocks were, and are available, and when discussing valving, the compression number goes first. I found that most of the trucks we built were very nice to drive with a 6/5 front, 7/6 for big block trucks, and a 3/6, or 3/7 rear shock. Also I learned that gas pressurized mono tube shocks are ok in the front, but are not soft enough for the back. Afco, Speedway, and others offer shocks like this. But WE have to know what to get, and this may require changing some mounts.
Old 07-20-2012, 08:50 PM   #1305
fatgump
fatgump's Avatar
Re: Make it handle
Is there a shock you would recommend to go with your Nolimit rear shock relocate mounts?
fatgump is offline   Reply With Quote
Old 07-20-2012, 09:55 PM   #1306
jlsanborn
jlsanborn's Avatar
Re: Make it handle
So what about us non-racers / daily drivers that wanna stay around a couple hunny for four shocks and buy them at Napa? What would you recommend? Also, how would you calculate stroke length?
Old 07-20-2012, 10:01 PM   #1307
jlsanborn
jlsanborn's Avatar
Re: Make it handle
Originally Posted by jlsanborn View Post
Rob,
Rob,
FedX just stopped by. Thanks! Another PM sent.
Old 07-20-2012, 11:42 PM   #1308
Mechanic77
Re: Make it handle
I don't want to complicate the shock discussion too much, but doesn't shock mounting location/angle also affect what valving is required? Like, how much difference for rear shock valving would there be for stock mounting location vs. your relocated mounts that put the shocks considerably closer to the wheels and more vertical (on a lowered truck)?
Pro Touring 1964 C10-Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=441627
Project '65 Short Step Daily Driver http://67-72chevytrucks.com/vboard/s...d.php?t=661948
Mechanic77 is offline   Reply With Quote
Old 07-20-2012, 11:53 PM   #1309
GMC Canuck
Re: Make it handle
ok, I'm in the planning stages of a tear down rebuild. I love my truck and it pains me to tear it apart cause I know this is more than a winter project but it's lasted 45 years and if it going to last another 45 some things need to be done.
I like the idea of a complete package. I know my strengths and happily defer to smarter people than me who have put together a system of parts that all works well together not the current mishmash of shinny bits I currently own.
I'm looking at no limits wideride front and fatbar rear or porterbuilts dropmember and tubular trailer arms setup or hotchkis' setup
Rob has mentioned several times about unsprung weight so it seems important (I know it is) and so I like his wideride setup. But for the rear, do I need a huge truck 12 bolt. Nope, the truck is never going to haul much more than a cooler. It's done it's time, paid it's dues and can now settle into a nice midlife crisis. I have a toyota to beat the crap out of. I've looked at irs but a custom setup is beyond my budget and retrofitting something like a mark VIII looks like a huge project with limitations on brake, wheel and ratio options. So is there a solid rear axle with a similar track width but maybe a little lighter? I'm not running any huge numbers for horsepower (375-400)
and thank you Rob and everyone else that has contributed or asked some really good questions.
GMC Canuck is offline   Reply With Quote
Old 07-21-2012, 12:47 AM   #1310
Grimee
Grimee's Avatar
Re: Make it handle
for my money I would go with Robs Parts first class stuff He talks the talk and most important he walks the walk
Grimee is offline   Reply With Quote
Old 07-22-2012, 02:14 PM   #1311
jlsanborn
jlsanborn's Avatar
Re: Make it handle
The greater the angle, the greater the disadvantage the shock is at. The shock will have to rotate more at the moutning points as well.
Think of it like this....
If the shock were perfectly vertical, then 1" of spring compression would result in 1" of shock travel and zero rotation at the mounts. Now put that sucker at 45 degrees. The same 1" of spring compression results in much less shock travel and it's had to rotate a few degrees on the mounts. So, your shock now has to "absorb" the same amount of "energy" with reduced displacement.
That's about everything I know about shocks! Actually, I don't know jack about shocks, but the geometry makes sense don't it?
Old 07-22-2012, 03:30 PM   #1312
robnolimit
robnolimit's Avatar
Re: Make it handle
Good one, right on the money. As you change the angle of the shock away from the true path of suspension travel, the dampening rate drops. Here are some calcs from old notes.
Shock angle - Dampening
0* 100%
10* 96%
15* 93%
20* 89%
25* 82%
30* 75%
35* 66%
40* 59%
45* 50%
You can see that the farther you lay a shock over, the more rapidly it looses effective dampening. These factors also hold true for spring rates, such as on a coil over shock. Understanding these relationship can help a chassis builder tune a vehicle suspension. Heres an example. Lets say you want the shock to have 200lb/in/sec (simplified term) dampening rate, but all you have available to use is a shock with a 300lb/in/sec shock. If you were to mount this shock at a 35* angle off of the true suspension travel line, you would reduce its effective dampening to 66%. So, 300lb/in/sec x 66% = 198lb/in/sec dampening rate. This relationship between mounting angle and dampening rate can be a good thing, for those who understand it, or a bad thing for those who don't.
Old 07-27-2012, 06:30 PM   #1313
robnolimit
robnolimit's Avatar
Re: Make it handle
Got my new copy of StreetTrucks today. looks good. WOW, I've been published! + a btchen C10 on the cover
Old 07-27-2012, 07:32 PM   #1314
GEARBOXGARAGE
Re: Make it handle
got my new copy of streettrucks today. Looks good. Wow, i've been published! + a btchen c10 on the cover
nice work!!
GEARBOXGARAGE is offline   Reply With Quote
Old 07-28-2012, 11:42 AM   #1315
Blitz
Mr. Thread Killer
Re: Make it handle
Looks like I have lots of reading, rereading, taking notes, comparing notes and editing notes to do. For now, I'm just trying to concentrate on what would make a 93 street truck perform and ride best based on a 4/6 or 5/7 drop in three different scenarios. Budget, Mild and Wild.
Blitz is offline   Reply With Quote
Old 07-28-2012, 12:15 PM   #1316
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Make it handle
What month? I'm no longer a subscriber, but I'd like to grab a copy
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 07-28-2012, 01:03 PM   #1317
robnolimit
robnolimit's Avatar
Re: Make it handle
The first steps of the plan should go like this. 1) Loose wieght, and move weight. Down and back. 2) move weight down - lower the truck, but don't get out of the sweet-spot of the suspension (drop spindles first) 3) Tires are everything. the wider the better. 40 series or shorter. 4) shocks, swaybars and alignment, this stuff is important.
Old 07-28-2012, 01:14 PM   #1318
robnolimit
robnolimit's Avatar
Re: Make it handle
it's the September 2012 issue
Old 07-30-2012, 08:33 PM   #1319
INSIDIOUS '86
Re: Make it handle
I see your f*rd is on fleabay! What for?
Old 07-30-2012, 09:28 PM   #1320
hotrod1
56 - autocross
hotrod1's Avatar
Re: Make it handle
Rob:
Congrats on the article. You deserve it!
hotrod1 is offline   Reply With Quote
Old 07-31-2012, 12:28 AM   #1321
robnolimit
robnolimit's Avatar
Re: Make it handle
Thanks HotRod1
Sid The garage is full, the shop is full, the trailer is full, and if you know about so-cal real estate, more space isn't an option. HellBoy took the last spot and Tina's mustang is coming along quickly. Someone else needs to know what it's like to drive a bad ass F-100. ?? Could be you
Old 08-01-2012, 12:14 PM   #1322
robnolimit
robnolimit's Avatar
Re: Make it handle
How to get the BEST DEAL EVER I made a comment on another thread here about buying an IFS. It may have sounded like I was steering the OP towards our product. Yes, thats how I make a living, but that wasn't my goal. Everyday I talk to people about their projects, and more than half of the stories are not so good. Poor quality parts, bad shop experience, over budget, too long....... Many of them are removing parts they bought and installed, only to be unhappy with the outcome. This is the heart of the problem. So how do you get the best deal without getiing screwed? Do your Homework. Ask the right questions, and if you don't know which ones to ask, ask about that too. Forming a relationship with a builder or retailer will help. Not a virtual relationship, but a personal one. Call them on the phone, or stop buy. But, don't waste their time, be ready, have a notepad and pen, and listen to what they say. Think about why they may say these things. Never buy on impulse. You can get Price, Quality, or Service. - But you can't have all three. Most of us are building what amounts to a 4000 lb. bomb. If you plan on driving your truck on a public road, with your wife, girlfriend, and/or kids, set out to make it safe enough for the HP you put in it. Our goal is to grow the classic truck hobby in general. More people building and driving more old trucks. To do that, we have to finish them, drive them, and live through the experience.
p.s. - never put your wife and girlfriend in the truck at the same time.
Old 08-01-2012, 12:42 PM   #1323
jmsaunders
jmsaunders's Avatar
Re: Make it handle
How to get the BEST DEAL EVER p.s. - never put your wife and girlfriend in the truck at the same time.
Not even if they are the same person????? I tend to think of my wife as my girlfriend lol.
J'aimi
54 Chevy 3100 5.3/4L60E (Plan to make summer daily driver)
54 Chevy 3600 "Destiny" future project (Plan to build for my daughter)
72 C10 current daily driver
74 Nova Son's DD (His 1st car, we had to start him off right)
00 F*rd Expedition wife's DD (She's the trader in the house and doesn't drive a GM )
jmsaunders is offline   Reply With Quote
Old 08-01-2012, 12:45 PM   #1324
CRGRS 66
CRGRS 66's Avatar
Re: Make it handle
How to get the BEST DEAL EVERp.s. - never put your wife and girlfriend in the truck at the same time.
no kidding, one in each ear... sage advice Rob
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 08-01-2012, 12:55 PM   #1325
PBFAB.COM
PBFAB.COM's Avatar
Re: Make it handle
Rob-
This is one of the main reasons I respect you and your company. It is always refreshing to see another vendor who shares similar principles and values. Sound advice all the way around!
If I were to emphasize anything you mentioned, it would be the planning process. Take your time in the "discovery" portion of the process. Ask LOTS of questions. Know what you are building BEFORE you build it. This will help ensure that all parts will work together to achieve the desired end result. A clear and solid plan will do nothing more than save time and money in the long run!
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
