Closed Thread
Old 01-15-2011, 09:32 PM   #1351
OG2wdblaze
OG2wdblaze's Avatar
Re: What did you do to your truck today!
drove it...for the first time in about eight years I took it for a drive!!! also did a little body work and started smoothing my top!
OG2wdblaze is offline
Old 01-15-2011, 09:47 PM   #1352
treeboy97
treeboy97's Avatar
I removed my saginaw 4 speed and tried in install a T5. I ran into a small problem with the clutch disk, I had bought an 11 and actually need a 10 inch clutch disk. I will start over next Saturday!
1970 C10 LWB (Grandfather's Truck) 5.3 4L60E
2012 Victory Cross Country Touring
I'm not wasting money on my truck/bike, I'm helping to rescue the economy one mod at a time.
treeboy97 is offline
Old 01-15-2011, 10:47 PM   #1353
alwaysbroken
put the motor, trans, and tcase in my 4x4
chevys the way to go.
alwaysbroken is offline
Old 01-15-2011, 11:04 PM   #1354
Navy Mechanic
Navy Mechanic's Avatar
Finished installing front drop springs, spindles, shocks, ball joints, tie rods, etc.
"Once a Chief, always a Chief!" MCPO (ret)
03 2500HD- 'Daily driver'
67 Short Fleet- 'Drivable project!'
11 Malibu LTZ- 'The Wife's ride'
Navy Mechanic is offline
Old 01-15-2011, 11:13 PM   #1355
glider_6969
I pulled the seats out,, again, and put in the speaker and storage box I made and then put the seat back in,,, i probably should have wiped it down before I took the pics,
glider_6969 is offline
Old 01-16-2011, 12:05 AM   #1356
jhwkns
Registered Cruiser
jhwkns's Avatar
Originally Posted by og2wdblaze View Post
drove it...for the first time in about eight years i took it for a drive!!! Also did a little body work and started smoothing my top!
wtg!
I intend to live forever. So far, so good.
jhwkns is offline
Old 01-16-2011, 02:07 AM   #1357
Bull72
Bull72's Avatar
got a new alternator today =) I really wanted a chrome one, but that will have to wait.
Thank you god for all your blessings!
My mini build (I had a great starting point)
http://67-72chevytrucks.com/vboard/s...d.php?t=440743
Bull72 is offline
Old 01-16-2011, 02:44 AM   #1358
60ratrod
yes, i do
60ratrod's Avatar
i hear that the chrome ones have less of a life span since the chrome keeps the heat in more than the natural cast ones
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline
Old 01-16-2011, 02:47 AM   #1359
Mike Bradbury
Mike Bradbury's Avatar
Polished some chrome and did a compression test on the engine. All came out at 149 almost exactly. But I am still blowing a little smoke out the passenger side pipe when I romp on it.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline
Old 01-16-2011, 05:46 PM   #1360
Bull72
Bull72's Avatar
Well I am glad to hear that then =)
Bull72 is offline
Old 01-16-2011, 07:20 PM   #1361
Sonicman
Sonicman's Avatar
Put in headlight relays. I can't wait til it's dark to see the fruit of my labor!
Sonicman is offline
Old 01-16-2011, 07:25 PM   #1362
FlounderGDI
FlounderGDI's Avatar
I got the itch to work on the truck today so I braved the cold and bolted down my new bed mounted tool box... I also did some repair to my heater switch plug... Next up on the to-do list is to install my Skip White HEI...
1969 CST/10 "GreenAndWhite"
1974 Nova (SOLD... End of an Era)
2000 Impala (RIP)
2008 Malibu
Brand Loyal... I've never owned a Vehicle not made by Chevrolet.
FlounderGDI is offline
Old 01-17-2011, 02:48 AM   #1363
project 67 sub
project 67 sub's Avatar
did a little more work on the replacement dash, wire wheeled the paint off, and cut out the radio hole. i offset the hole to the right because i am going to add a push button starter on the left side of it. i also might add a few other things as well but not sure yet, and i would have to figure out what exactly that would be first lol.
project 67 sub is offline
Old 01-17-2011, 09:18 PM   #1364
project 67 sub
not much of an update as of yet, but, just some messing around. took a pic of the current engine setup as i dont have a pic of that in here. i also pulled the springs out of the front to see how low it is. still need to finish the lower arms, and install bags and spindles, but i only have 3/4" before the arms hit the grond
Old 01-17-2011, 09:46 PM   #1365
j_cst_10
j_cst_10's Avatar
I bumped into it with my 2002 Silverado while pulling into the driveway.
j_cst_10 is offline
Old 01-17-2011, 09:48 PM   #1366
cobrajet21
cobrajet21's Avatar
have not touched it in a year.
http://67-72chevytrucks.com/vboard/s...d.php?t=288820
68 Chevy CST project
02 Chevy Silverado Ex.cab
71 Ford Torino Cobra
cobrajet21 is offline
Old 01-17-2011, 09:48 PM   #1367
project 67 sub
ouch! did it do any damage???
Old 01-17-2011, 10:38 PM   #1368
67Slider
67Slider's Avatar
Replaced inner and outer tie rod ends, upper and lower ball joints, and cut one coil out of the front springs. Tried my wipers and found that I had installed the linkage backwards. Had to take the cowl off and swap the pivot arm. Buttoned her back up and parked her in the garage. I had replaced my rear springs with Jeep TJ springs awhile back. I finally got around to measuring the drop and come to find out one side is 1.75 inches higher than the other. I guess I will fork out the 100 bucks for real drop springs. I should have known better but it sounded like a great deal(the TJ springs).
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 01-17-2011, 10:41 PM   #1369
j_cst_10
j_cst_10's Avatar
No, not that I can tell. I really don't know how it didn't mess something up. It does have 4 inches of snow on it so who knows.
j_cst_10 is offline
Old 01-17-2011, 10:55 PM   #1370
kpeztruck
kpeztruck's Avatar
Originally Posted by magwakeenercew2jh View Post
Yup. Kimber .45 CDP Ultra II.
Sold it yesterday.
Lookin' for wheels:
http://tinyurl.com/4qxg2tj
Must be a nice set of wheels you are hunting for, I still have my Kimber Compact 12 years later. Carry it everyday. Hate to see you have to part with such a nice handgun. Paul Baxter
kpeztruck is offline
Old 01-18-2011, 12:04 AM   #1371
trkfrk
trkfrk's Avatar
Pulled engine/trans (mock-up) Prepped for powder coating. Cut 4" exhaust holes in frame. Sandblasted A-arms.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline
Old 01-18-2011, 12:05 AM   #1372
bc gman
71 bb longhorn
I put the first coat of teak oil/thinner on the red oak bedwood,just the start of many coats.
71 2500 Gmc longhorn with a 402 turbo 400.
09 F150 Supercrew 4x4
05 Mazda 6 sport
accept that somedays you are the statue
and somedays you are the pigeon.
bc gman is offline
Old 01-18-2011, 12:20 AM   #1373
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Thanks, Paul. I'm still covered. But that one was the most expensive I had. It took all of what I got for it for the Boss 338 20's. The "Little Woman" bought me tires for an early Valentine.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 01-18-2011, 02:43 AM   #1374
dixietruck71
dixietruck71's Avatar
picked up a 69 gmc grille last nite in killer shape, no rust. buffed and polished it tonight. gona put it on this weekend, along with all of the side trim finally.
71 gme Sierra Grande lwb.
68 Rambler American 2 door
75 jeep cj5
dixietruck71 is offline
Old 01-18-2011, 03:16 AM   #1375
mcmlxix
Collector of Projects
mcmlxix's Avatar
Put some red LEDs in the dash... I had already pulled it all apart and painted the inside a bright gloss white... they look good...
Rich
1972 K5 Blazer CST Click HERE
mcmlxix is offline
Closed Thread
