Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 02-18-2010, 08:32 AM   #1376
Thealien
Thealien's Avatar
Re: PO has me PO'd
The wires come out of the 1/2 circle plug. If you look inside closely with a flashlight you can see the two retension pins/tangs that you have to push in to remove them. If you can't figure it out post or PM me and I'll find the connector I have and I'll post a pic. I used a small pocket knife to push the tangs in.
Old 02-18-2010, 10:11 PM   #1377
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Originally Posted by Chevyman63 View Post
Hey Jim...did all those parts on the work bench come out of the column? Wow, I had no idea!!!
Well, yes except the steering stabilizer, exhaust manifold and my Dad's 1950's drill that came from JC Penny's. Or are mocking me for the condition of my workbench/storage unit
Wow!, great info. thanks for taking the time, I'll investigate further
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 02-19-2010, 12:06 PM   #1378
Thealien
Thealien's Avatar
Re: PO has me PO'd
Here is a pic of that plug with 1 wire out, the size of the knife I use to push in the tabs that are visible in the picture. The second picture is just the wire showing the tabs a little clearer. I bent them out a little for clarity.
Hope this helps
Old 02-20-2010, 10:52 AM   #1379
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks for taking the time, so if I understand this right, the tang that has to be pushed down is on the top side of the connecter
SAFETY FIRST
AS usual, off topic
Jim
Old 02-20-2010, 11:23 AM   #1380
Thealien
Thealien's Avatar
Re: PO has me PO'd
No there is one tang/tab on each side of the metal connector. First push the tab on one side and then push the tab on the other side. It may take a couple of tries.
Old 02-20-2010, 12:20 PM   #1381
msgross
msgross's Avatar
Re: PO has me PO'd
he said "tang"...
I used JB weld to patch the shifter nub on my rebuild... I don't remember having to pull the harness apart like that but I used a van tilt so it might have been a flat adapter...
are you going to paint or PC the column once done? JB weld holds up to the PC oven if you are.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-20-2010, 12:33 PM   #1382
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Originally Posted by msgross View Post
he said "tang"...
I've got some stuff called 'Lab Metal', neat stuff, you can machine it once it sets up. I'm still not sure on the paint/PC. I have to fill in the shift indicator lamp hole, dunno how I'm going to fill that yet
The harness has a pinch in it down to the bare wire. Thing is, I have a red four way flasher knob, and I don't think it is right for my truck. My auto. coulumn has a black push/pull thingy and I like it better, so I may be using that if it fits into my tilt
Yeah well, I don't think you have to pull the harness apart either, but it was a steep learning curve
SAFETY FIRST
AS usual, off topic
Jim
Old 02-20-2010, 01:15 PM   #1383
msgross
msgross's Avatar
Re: PO has me PO'd
I used the JB weld putty on both parts...
The Garage:
Old 02-20-2010, 02:14 PM   #1384
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Really? Got pics, or should I visit your build thread
SAFETY FIRST
AS usual, off topic
Jim
Old 02-20-2010, 03:26 PM   #1385
msgross
msgross's Avatar
Re: PO has me PO'd
here is one part... Now that I think about it, I haven't done the sleeve yet..
The Garage:
Old 02-22-2010, 03:35 PM   #1386
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Off topic>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
GONE FISHING, be back in 7 days
Forecast....snowing, 4 ft base, 32degrees water temperature, wind chill -10, winds gusting to 50 MPH = perfect fishing weather in New York
SAFETY FIRST
AS usual, off topic
Jim
Old 02-22-2010, 04:06 PM   #1387
vtblazer
vtblazer's Avatar
Re: PO has me PO'd
So that means your post # 629 in this thread will be showing a fish?
Have a great time Jim, tell the boys hello for me.
vtblazer is offline   Reply With Quote
Old 02-22-2010, 04:16 PM   #1388
lks dcvn
lks dcvn's Avatar
Re: PO has me PO'd
Have fun - enjoy the trip...
lks dcvn is offline   Reply With Quote
Old 02-22-2010, 04:36 PM   #1389
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Confused #629?
Probably not! 20 years of fishing up there and I only kept one that is hanging on the wall Of course, if I land a state record, there are very loose interpretation of the rules
Plus the fact that Jonathon gave me a Sage flyrod for Christmas and I have NEVER thrown a fly rod before. But, as you know it's all about hanging out with my sons and nephews
I'll pass it on to the boys, Kurt.! We have a new member to the snowmobiling/fishing trip. He works at Quadratec, so we have to be nice to him
Thanks LKSDCVN
SAFETY FIRST
AS usual, off topic
Jim
Old 02-22-2010, 05:08 PM   #1390
vtblazer
vtblazer's Avatar
Re: PO has me PO'd
Originally Posted by jaros44sr View Post
Confused #629?
You alone have now contributed 629 times to this thread.
Old 02-22-2010, 07:03 PM   #1391
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Cool, don't know how you came up with that, but I will take your word on it. I now also carry a web cam, so I may be able to get some action shots, along with the stills
SAFETY FIRST
AS usual, off topic
Jim
Old 02-22-2010, 07:32 PM   #1392
vtblazer
vtblazer's Avatar
Re: PO has me PO'd
I'm @ #127 with this post...
Why are you still here? Get packin'!
Old 02-22-2010, 08:54 PM   #1393
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Re: PO has me PO'd
Have a good time Jim.
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 02-22-2010, 09:00 PM   #1394
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
How do you do that? Actually, I m leavin' Wed morning, just thought I'd hang out with use guys for a while
I'm really impressed with the builds that are going on rite now, lots of reading matr'l
SAFETY FIRST
AS usual, off topic
Jim
Old 03-01-2010, 02:17 PM   #1395
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Snowed from Wed. 5PM to Sun. 11AM...Caught and released 3 fish, my 1 larger, to Jon's 2 smaller 2 pair of waders failed, so one leg was filled with river water, and freaking cold for 8 hours, but that is fishing in Upstate NY. Dick's sporting goods WILL be dealt with!
The grille on the boat was a pleasant addition, breakfast and lunch on the river
Now back to regular rebuild, after a pause for some pictures
Blew up 2 of the 4 snowmobiles
SAFETY FIRST
AS usual, off topic
Jim
Old 03-01-2010, 02:23 PM   #1396
Tynee
I miss this truck.
Tynee's Avatar
Re: PO has me PO'd
Sounds like a great week. Looks pretty out there. Must not have been too cold, looks like the snow's WET!
As a former employee of Dick's Sporting goods, my best advice is to go to Cabella's, or Bass Pro Shops, or Sierra Trading Post, or, or, or...
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 03-01-2010, 02:37 PM   #1397
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Typical Father Son biannual fishing, just great to be able to fit time into all of my sons busy lives, but I think they get the purpose of these trips. It's all about quality time!
Cold? just a matter of opinion...if I could have felt my toes, it would've been my enjoyable. And yes the river water was wet
Maybe not Dick's fault, bought a bottom of the line wader made in China, lessen learned
Also my Northface shell failed, so I was wet 2 layers down
Thanks for checkin' in Tynee
SAFETY FIRST
AS usual, off topic
Jim
Old 03-10-2010, 04:42 PM   #1398
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Gotta put a round peg in a square hole...Thanks Rob for the deal on the Chevy Quadrajet
SAFETY FIRST
AS usual, off topic
Jim
Old 03-10-2010, 05:28 PM   #1399
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Re: PO has me PO'd
Hehe, thats the same little dinky air cleaner I have on mine to keep the dirt out! Great minds think alike!
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 03-11-2010, 12:11 AM   #1400
Firebirdjones
Re: PO has me PO'd
Cute air cleaner
Firebirdjones is offline   Reply With Quote
