Old 10-18-2012, 12:34 PM   #1426
jimmydean
jimmydean's Avatar
Re: Make it handle
Originally Posted by robnolimit View Post
Jimmy, years ago I ended up with a '84 C4, the original car had the cross-fire injection (bad) and the 4+3 slappy auto. It was a bad car (bad, as in not good) Most of it's technology didn't work. After much frustration, I gutted the car, Put in a tuned port 383, a 5 speed from a camaro, fabbed an aluminum dash with autometer guages (none of the digital worked ) Two Cerullo buckets, (again, the 28 way adjustable seats were crap) Along with gutting the dash, all of the climate control a/c came out, I put in a Vintage Air Mini unit. Weight dropped to 3100 lbs, and it was re-born as the killer of Z-06's It was a fun car street or track, but they do rattle alot
I bought the '94 to cut up for C4 Dropmebers and use the LT1 and 4L60E as well (my car was $4k). But after driving it, I fell in love. The updated interior and drivetrain saved the Vette (they talk about it in Chevy 100) and after chasing my buddy on the backroads in his C6, I know if I had an LS3 to match his LS2, he would be doing the chasing.
The truck will still get the engine at least. Thanks again, Rob. You are such a wealth of info and your track record shows you at least have some idea what you might be talking about.
<edit> And FYI, my car has zero rattles with the top on. Now if only the heater worked, I'd be golden.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 10-20-2012, 12:04 AM   #1427
Goats86
Re: Make it handle
OK you've got me curious. I have a 86 c10 with an 5.3 LS, 4L60E, 4 wheel disc brakes, posi, front and rear sway bars. It handles pretty well for an old truck with 200 lbs of ballast just behind the rear axle. I have already dropped the rear end about 4 inches and cut 1 coil off the stock front springs. From a "low budget" standpoint, I want to run 2 1/2 inch drop spindles. For springs 3/4 ton with 1 coil cut off? Will the ride height still be a 2 1/2 inch drop or will the stiffer spring make it drop less? Is this a decent budget fix? Will the ride suck?
Goats86 is offline   Reply With Quote
Old 10-21-2012, 12:47 AM   #1428
Matt R
Matt R's Avatar
Re: Make it handle
http://youtu.be/pVDd6aHYC5k
Enjoy. Watch the tire shot, you can see the push (driver induced, I went in too fast) at the far end on the 180* left. Otherwise, pretty good. If you watch close, you may see the door gap shift, I think this is the latch? Anyway, it was a fun day for sure.
That was an awesome video. I found myself tensing up my muscles in the turns while sitting in my recliner
My build thread http://www.67-72chevytrucks.com/vboa...d.php?t=494247
Matt R is offline   Reply With Quote
Old 10-22-2012, 03:41 PM   #1429
robnolimit
robnolimit's Avatar
Re: Make it handle
Sounds like a cool project, gotta love the LS platform motors. I suggest changing only one thing at a time. Will the drop spindles make it too low with the springs you have now? Also, the cut 3/4t spring is only slightly stiffer than the 1/2t spring so the ride in not affected very much. Would you sat that it has more of a 'push' now in a hard corner, or does the back end get 'loose'? Knowing the answer can help with spring choice. What tire/wheel combo are you running, - sizes/make -
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 10-22-2012, 03:42 PM   #1430
robnolimit
robnolimit's Avatar
Re: Make it handle
Thanks, it was a fun day. The seat belts crack me up.
Old 10-22-2012, 06:33 PM   #1431
Goats86
Re: Make it handle
Hi Rob, Thanks for the reply. I am running stock rally wheels all the way around. 7 inch front and 8 inch rear. As of now it runs pretty flat thru the corners. Seems to have a bit of a push in the corner but not too bad. Using urethane bushings all the way around. I removed all but 3 leafs in the rear. Those left I shortened 4 inches and prepped with teflon pads. Has a Helwig rear sway bar stock 1/2 ton up front. Cheapy Monroe shocks. The rear end is a narrowed Ford 8.8( I know but it got me posi and disc for cheap)
Old 10-23-2012, 11:42 AM   #1432
robnolimit
robnolimit's Avatar
Re: Make it handle
Goats86, sounds like a good set up. Tires will quickly become the limiting factor. I'm a fan of the Explorer 8.8, lots of value there. Try and dig up some stock 1/2t front springs, and start out by swapping the spindles and putting full height springs back in. Check the ride height. This will lower the CG, but, will probably raise the roll center. The truck will feel more stable, but the higher roll center may add to the push givin your front tire. For some extra drop out back, try a raised front spring hanger. This will also help by raising the anti-squat % a bit. Try to make one change at a time so you can note the changes. - let us know.
Old 10-25-2012, 05:24 PM   #1433
Hard Luck
I've got grease on my mind.
Hard Luck's Avatar
Re: Make it handle
Oh my gosh! I caught up to the rest of the class. Lots of great info.
Thanks for doing this Rob and everyone else who has been helping out with information we all need to know.
As we were talking about shocks I was wondering if these were your front reloction brackets I saw on a 68 CST. They look kind of like your rears except they are not painted "Battleship Grey". If they are yours what do they cost and if not, can we get info on the front bracket you offer?
What about moving the shock into the center of the spring like every other car has? Is this just too much work or is there no real benefit to spending our time and money there?
Hard Luck is offline   Reply With Quote
Old 10-26-2012, 07:37 PM   #1434
butchp
Re: Make it handle
Rob is there a picture of a good g frame for a 56 chevy truck that you could post. I have installed a 76 camaro sub on my extra frame and cnoched the rear, I just picked up the plates to plate benind the sub to the middle cross member, I just read on one of the first post on this thread about skipping the welds (2" weld skip 4") I was doing to window the plates to remove wt. Then in a post you suggested to use tubes 1 1/2 .120t to build 45 angles, is that w/ plates or without. Thanks for being on here.
butchp is offline   Reply With Quote
Old 10-26-2012, 08:22 PM   #1435
BMERDOC
BMERDOC's Avatar
Re: Make it handle
Rob! I'm back and almost ready to start on making more suspension improvements. I know I'll have to go back and read up on anti-squat, anti-dive, roll center and so on but I wanted to ask a question.
Your thread has covered bump steer. You mentioned heating the steering arms and bending them back down to correct bump steer. I have obtained a new set of lower cross shafts and intend to have them drilled at 90 degree intervals to obtain 1/4 inch increments for alignment machine testing (stock, 1/4", 1/2" and 3/4") I want to take my upper cross shafts to a local machine shop to have the holes milled so as to elongate the holes as much as THEY feel comfortable with doing (you mentioned 7/8").
I also have a set of spindles going to the scrap pile that I wanna steal the steering arms off of. I want to prep by attaching a string from the t/r end at the steering arm to the t/r end on the other side and measure from that string to the frame to eliminate tire size. Do you have any info regarding where the arm should be for "correct" bumpsteer?What is your advice on heating the arms? More along the lines of cooling...Do you like to quench or cool naturally?
***EDIT*** This coulda read a lot better than I typed it out but I think you get the idea. To simplify, Is the "stock" steering arm position a good base line to keep for experimental purposes or is there a better starting point? How do you prefer to treat heated suspension components?
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 11-02-2012, 03:21 PM   #1436
moregrip
moregrip's Avatar
Re: Make it handle
Wow....took me 4 days to read it all....holy cr@p alot of great info.......thank you!
Couldn't come at a better time.....I'm in the planning stages of a new build.....1973 C20.....going to do my best to apply as many of the lessons learned in this thread to my 8lug
moregrip is offline   Reply With Quote
Old 11-09-2012, 03:10 AM   #1437
cory d
cory d's Avatar
Re: Make it handle
i often haul a couple dirtbikes in my truck so i can only soften teh back so much. i have an short square with a flip kit, drop shackles and notch. i have about 4-4 1/2" between the axle and frame with 5 leafs and the overload. I was thinking about removing the overload and 2 smaller leafs and then putting junk yard helper leafs on it. would this be helpfull and how much travel would i want before the helpers begin to be used?
cory d is offline   Reply With Quote
Old 11-09-2012, 03:25 AM   #1438
cory d
cory d's Avatar
Re: Make it handle
i plan on getting 3/4 ton coils and putting my 1 1/4" bar on. i also need to find a rear bar
Old 11-09-2012, 05:05 AM   #1439
cory d
cory d's Avatar
Re: Make it handle
i guess i wouldnt be able to do that with the flip kit. maybe i can figure out a way to use helper coils. probably should have so many "late night ideas"
Old 11-10-2012, 09:55 PM   #1440
cory d
cory d's Avatar
Re: Make it handle
quagruple post
i had 5 leafs and an overload, i now habe the 2 long and the bottem with the overload. it rides better for sure and now its level. i think im bottoming out the longer shock i have on the back
Old 11-15-2012, 03:53 AM   #1441
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Make it handle
http://www.ridetech.com/store/1973-8...hq-series.html
Rob have you tested this line of shocks at all? You recommended fox shocks and they say these are them. Either way these are what I'm planning on running unless you have a better one in mind?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-15-2012, 04:19 PM   #1442
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: Make it handle
I have a set of ridetech coilovers for the rear. My build is still in progress, so haven't run them yet, but they get really good reviews on pro-touring.com
They look to be a very high quality unit.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 11-16-2012, 01:41 AM   #1443
BossHogg69
motor exploder
BossHogg69's Avatar
Re: Make it handle
Rob (or anyone else), do you have any thoughts on using ball joint spacers to make the spindle act 'taller' for camber gain?
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 11-16-2012, 12:01 PM   #1444
Mike Bradbury
Mike Bradbury's Avatar
Re: Make it handle
I don't have the Ride-Tech shocks but I have the Bilstein version. The important thing is that they are the mono tube type, they work very well and I am very happy with the performance and their ability to control the bumps and curves. Handles great for a big heavy truck.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 11-19-2012, 06:00 AM   #1445
jjzepplin
jjzepplin's Avatar
Re: Make it handle
The whole goal of A arm swapping, and I don't know if this really works, is to increase positive 'Caster'. Stock C-10's spec out 1 or 2 degrees, but your truck will respond well to 6 to 7 deg, and more for the wide tire guys, bigger than 8". To my knowledge, nobody makes a set of arms to gain caster, may someone should. The trick is to move the lower ball joint forward about a 1/2", and the upper ball joint back about 7/8", this will keep the wheel centered and net about 8 deg. + caster.
First vocabulary word : PUSH. or Understeer, or to be TIGHT. this is when you turn the wheel, and you can feel the truck 'push' forward, not wanting to turn. It is very common for these trucks to push, especially with wider tires do to the factory geometry, - remember, they were work trucks, tractors with windows.
#2: LOOSE, or Oversteer, is when the truck turns MORE than you want. Usually the back is comin around. Trucks are light in the rear, so they get 'loose' easily.
So, we have two problems right from the start, a push going into the turn, and getting loose through and out of the turn. An increase in caster helps to eliminate the push. I am in favor of more caster, much more than I would like to add negative camber to solve the push. Much more than -1deg camber wears tires, feels twitchy, and increases rolling resistance.
I have a 73 front end. Will this work for my truck too?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 11-19-2012, 11:12 AM   #1446
Wasted Income
Boosted Member
Re: Make it handle
LOL! I've never seen your setup before, but I like it!
I just finished mine up this weekend...
Turbo diesel
Old 11-19-2012, 11:54 AM   #1447
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Make it handle
Curious, too. What about taller upper BJs?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-19-2012, 12:24 PM   #1448
robnolimit
robnolimit's Avatar
Re: Make it handle
Ok, sorry I've been away for a bit. SEMA and the fal show set have me runnin.
Yes, the RideTech coil overs are made by Fox. We use them, currently on the HellBoy, and they are a very good shock
The Bilstien is a nice piece. The 'inertia' valve is pretty hi-tech, soft at low speed, and firms up quickly at higher motion rates. This makes it a great all-around shock.
Ball joint spacers?? don't know. But, "Tall ball joints" can help. This effectively adds to the "camber gain", and may raise the roll center a bit. Lots of NASCAR hobby racers use GM truck ball joints because they are stronger than the car units. Check out HOWE racing or Speedway Motors.
Old 11-19-2012, 12:26 PM   #1449
robnolimit
robnolimit's Avatar
Re: Make it handle
Last week we swapped out our 'home modified' LCA on the JT for a set of Nate Porter's "Forward Lower" arms. I'm getting the picts together and I'll post up the info here and on the JT thread.
Old 11-19-2012, 12:29 PM   #1450
robnolimit
robnolimit's Avatar
Re: Make it handle
During the Scottsdale GoodGuys show, we went over to Dino's friday night 'get together'. Pretty impressive. A lot more trucks than I expected, and some really cool ones. Dino is a great guy for hosting this event, including drinks and food. Thanks again Dino, we had a great time. - Expect to see some picts in Street Trucks soon.
