Old 10-22-2011, 04:14 PM   #126
Vernski
Re: Tricked-out Chevy six cylinder engines
Originally Posted by DLOE65 View Post
Here's Mine,
292 .30 over,Balanced, Clifford Cam, Offy manifold with water heat plate, Holley 390, Landon Cast split exhaust manifolds, Landon Mini HEI, Landon Billet Push Rod Covers, Taylor Wires, aluminum water neck, Think i am going to be running Porter Mufflers.
Nice motor that bright green jumps at you and you have it out-fitted well it will be a good runner...Vernski
Vernski is offline   Reply With Quote
Old 10-24-2011, 07:39 PM   #127
DLOE65
DLOE65's Avatar
Thanks!
DLOE65 is offline   Reply With Quote
Old 02-03-2012, 05:42 PM   #128
DLOE65
DLOE65's Avatar
For you guys running the offy 4barrel intake, have any of you fabbed or purchased a carb spacer so your kick down and throttle linkage can be facing the driveside?
Old 02-03-2012, 05:57 PM   #129
1963c-10
1963c-10's Avatar
Stock original 230, but its cleaned up pretty nice
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 02-03-2012, 06:25 PM   #130
shawno72
C/10 junkie
shawno72's Avatar
Originally Posted by 1Bad62Pro/Street View Post
You know what's funny is he said that the motor was a 292 but its not. May be a 250 but definately not a 292.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 02-03-2012, 06:28 PM   #131
awbrown
I picked up on that too......
awbrown is offline   Reply With Quote
Old 02-06-2012, 02:39 PM   #132
Heater63
Heater63's Avatar
DLOE, here is a spacer ( I don't know what brand) I got with my used manifolds I found on craigslst. It has a simple angle iron bracket attached from linkage mounting.
I don't know if it's home fab or sold somewhere.
I have no idea if I will use this,... I just set it there so you can see it and have another idea.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 02-06-2012, 02:50 PM   #133
DLOE65
DLOE65's Avatar
Hey Heater, thanks for the picture. I ended up purchasing a 1" cast aluminum carb spacer from trans dapt. I rotated it so the linkage was on the driver side, then drilled and countersunk the bolts to mount to the offy. Worked great, check my build thread, I posted pics last night.
Old 02-06-2012, 03:56 PM   #134
Heater63
Heater63's Avatar
DLOE, good deal. I will check out your pic's.
I don't have my cab back on yet, so haven't address the throttle linkage yet.
Is there consensus on any performance effects of how the carb faces?? (ie, primaries/secondaries facing ) To my (sometimes wrong) mind, the carb should face away from the head, so that the primary venturi are on the furthest most point of the plenum and balanced front to back. I will check on Inliners also... T Lowe has done a ton of dyno testing, I will see what he has found scientifically.
292 + TKO500
Old 02-06-2012, 04:01 PM   #135
DLOE65
DLOE65's Avatar
Yeah, I'm not sure either, I may have to change it back if it's a issue, I hope not though.
Old 02-06-2012, 07:49 PM   #136
Vernski
If the manifold is an open plentium the carb can sit in any direction if it's closed or separated then it has to sit one way only to work right...Vernski
Old 02-07-2012, 02:29 AM   #137
Heater63
Heater63's Avatar
DLOE, as Vernski said, it is accepted that facing forwards is fine, especially with a carb spacer, and since you're already rigged up, I would not change it. Tom Lowe on inliners recommends putting the primaries away from the engine to keep the runner length to mid cylinders as long as possible- but the difference made is not much.
292 + TKO500
Old 02-07-2012, 02:41 AM   #138
DLOE65
DLOE65's Avatar
Sweet good to know! Thanks!
Old 03-09-2012, 06:29 AM   #139
Dragun12
Dragun12's Avatar
ya does any one know how much better they do with the three one barrels and the long tube headers? because my 72 c20 has the 292 and but after seeing every one elses 292 i really want to try and put some money in to it and see if i can make it perform. because at times i hate that darn engine but then i dont want to be like every one else and throw in it v8 right off the bat i want to give this engine a good fare chance. since i replace the old block cuz it had a nice huge crack between cylinders 1 and 2 on the block and head and rebuilt the one thats in it now it ive put 6000 miles on it so its still new lol. and heres some pics of the heart of my old tanker
Dragun12 is offline   Reply With Quote
Old 03-09-2012, 03:50 PM   #140
Heater63
Heater63's Avatar
Dragun, here's the short and sweet:
Use a small 4bll (Holley or Edelbrock) on the Offenhauser intake, use Langdon Cast Iron or long tube headers, use HEI(you are), a mild cam (Comp and Schnieder make 292 cams) and you've done the majority of improvements for the least money.
The next step is lump port the head, I suggest having Tom Lowe on Inliners.org do it.
You wanna throw more money at it?? >>> You can put in propane pistons, roller rockers (you'll need custom length pushrods) you can turbo, you can EFI, you can dump a ton of money. If you want to go that route read Santucci's book and Inliners.org
292 + TKO500
Old 03-09-2012, 03:53 PM   #141
DLOE65
DLOE65's Avatar
Heater any updates on your build? Send me some pics!
Old 03-09-2012, 09:24 PM   #142
Dragun12
Dragun12's Avatar
ya i was thinking about going to Tom Lowe for his lump port kit and Head rebuild Parts kit 1.94/1.6 Valves. so why the four barrel just less tunning hassel than the three ones and are Langdon Cast Iron headers better then the tube type?
Old 03-22-2012, 08:22 PM   #143
monolith
Zero Albedo
monolith's Avatar
http://inlandempire.craigslist.org/pts/2883555914.html
Saw this beast on CL. Can someone archive the listing to preserve what was done to the motor? I would, but I only have a phone for internet these days, and I dont know how.
Baz
"Deserve's got nothin' to do with it."
66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467
65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432
65 Chevy Panel (former U.S.Navy truck)
64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348
64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now)
68 Dodge Charger
monolith is offline   Reply With Quote
Old 03-28-2012, 07:41 AM   #144
K98AL
K98AL's Avatar
I'm wanting to go to a dual carb setup on my 235. I'm running Fenton headers now, any advice on manifolds/carb setups? I really like to dual 1bbl with oil bath air cleaners, but how tough is this to run/keep tuned?
K98AL is offline   Reply With Quote
Old 03-28-2012, 09:53 AM   #145
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: Tricked-out Chevy six cylinder engines
Check these out fellas.
https://www.cliffordperformance.net/
http://www.speedwaymotors.com/Offy-1963-75-Chevy-6-Cylinder-Dual-Carb-Intake-Manifold,813.html
http://www.jegs.com/v/Offenhauser/750
http://www.summitracing.com/search/Brand/Offenhauser/?autoview=ProductName
I6 Banger Info:
https://en.wikipedia.org/wiki/Chevrolet_Straight-6_engine#Second_generation
Tire Scorching 292
https://www.mighty6.com/motorvation
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 03-28-2012, 12:35 PM   #146
K98AL
K98AL's Avatar
Thanks!
Old 03-28-2012, 07:26 PM   #147
gimmy 64
tom langdon has this set up but uses later model 2 barrel carbs. he sells the whole thing with linkedge etc. suppose to be a really nice set up for the early six
gimmy 64 is offline   Reply With Quote
Old 03-28-2012, 10:14 PM   #148
monolith
Zero Albedo
monolith's Avatar
250 6-CYL OUT OF A 1968 CAMARO 81/2 TRW PISTONS, STD STEEL CRANK 250 REWORKED HEAD,CRANE HYD CAM,,1.5 ROCKERS,CRANE VALVE SPRINGS, CROWER ONE PIECE PUSHRODS,TRW WATER PUMP, TRW HIGH VALOUME AND HIGH PRESSURE OIL PUMP,MALLORY ING,(2) 35 MM WEBBERS SITTING ON A BDS 110 BLOWER, FLEX PLATE,ALT,P/S PUMP DUAL EXTERNAL OIL FILTERS,HEADERS CLIFFORD VALVE COVER THIS MOTOR WAS IN A 1968 CAMARO STREET CAR $2,500.00
Baz
68 Dodge Charger
Old 05-09-2012, 09:58 AM   #149
1963c-10
1963c-10's Avatar
230 that was built for a 66 nova. Engine now for sale as is car. guess the owner went for a differnt project
Old 05-09-2012, 02:09 PM   #150
RAYDAY
RAYDAY's Avatar
im thinking of running 3 1 barrels with progressive linkage on a 250 any one tryed that? normal driving ur on the 1 carb should get good response and mileage. but 2 more kickin when u need it!
96 s10 static drop smooth and blue
99 silverado nothing stock layed out on 24s
65 c10 bagged patina driver
http://www.myrideisme.com/Garage/az480
half-assed build thread
http://67-72chevytrucks.com/vboard/s...=1#post5206828
RAYDAY is offline   Reply With Quote
