Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 07-02-2009, 01:39 PM   #126
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: project: FTD
nylon brush to knock off all the crap.. some chem b12 and steel wook to remove the tarnish..
that's abou tit.. oh and rags of course hehehe
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 07-02-2009, 05:16 PM   #127
dammitmitchell
the pollock
Re: project: FTD
SWEET ive been running numbers that i have been finding and here's what i have "total" into my engine as of now..
im waiting on a guesstimate for HP.. hehehehe
electric fan and factory alt and PS are and will be attached..
block
350 bored .060 over
gm 5.7l
the number next to it is 14010207
next to that is a stamp says M27
side of the block states 207
front id states V0901ZBA
105122952
Federal Mogul 350 cast pistons .060 over
crank is
3932442 3.48 69-85 2.45/2.10 cast large journal
heads are casting number 462624
76-87 1.94/1.50
& 2.02/1.60 76 CC Chambers
cam
RENEGADE PN 158881
dur@.050 Int 234 exh 244
vaulve lift int .488 exh .510
intake edlebrock perfromer RPM highsise
spacerplate (1in)
carb holley 670 carb with factory jetting..
(i might have to jet it up.. not sure yet..)
and "nothing special" for the distributor just a stock hei
(not sure because i diddnt buy it..)
Army vet 02-08
Old 07-02-2009, 07:31 PM   #128
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: project: FTD
about 320 hp and 375 tq
this is with 9 to 1 compression
and a 4000 pound truck using camquest
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 07-02-2009, 07:34 PM   #129
dammitmitchell
the pollock
Re: project: FTD
annd... well those sounnddd good to me!
hahahhaa...
others say different.. i prey yours is right.. because it sure as hell dont feel like 250 hp...
Army vet 02-08
Old 07-02-2009, 07:38 PM   #130
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: project: FTD
this is not the greatest desktop dyno but it seems pretty acurate
i hope mine is going to be at 430hp/430tq after the head swap
Gage
Old 07-04-2009, 02:41 AM   #131
highperf4x4
Re: project: FTD
You're showing 2 different valve sizes. Are your intake valves 1.94 or 2.02?
That 76cc head is your biggest setback right now. You gonna look for some with smaller combustion chambers? If you could find a set with 64-67cc chambers and 2.02 intake valves you'll be in good shape.
highperf4x4 is offline   Reply With Quote
Old 07-04-2009, 10:04 AM   #132
dammitmitchell
the pollock
Re: project: FTD
the heads unfortunately right now are obviously a major setback, bu tthey are past my allowance to get.. damn....
nut in the near future... it will come.. right now... i want them really really dang bad..
but oh well..
Army vet 02-08
Old 07-04-2009, 12:41 PM   #133
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: project: FTD
i wonder how accurate the comp cams camquest is
Gage
Old 07-10-2009, 08:50 PM   #134
dammitmitchell
the pollock
Re: project: FTD
hey all well! i got the heads town down.. they are actually in reallllly dang good shape! (to bad im gonna replace them soon)
i finished all my welding and "fender extensions" up..
it could have definatley come out alot better but im inot gonna complain seeing how it's my first attempt at this...
so inner and the main fenders done, all i need now is to get off me arse and sandblast the hood and the rad support, headers and battery tray...
paint them up.. and then it'll be time to spray gloss coat on everything....
motor is ready valve r assembly once the RIGHT freaking valve seals come in..
and im set.. time to take pictures i guess
Army vet 02-08
Old 07-10-2009, 09:00 PM   #135
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: project: FTD
cool did you get that program working i think it works great
Gage
Old 07-12-2009, 12:58 AM   #136
dammitmitchell
the pollock
Re: project: FTD
ok so her's the pictures....
im waiting on gloss cote in the next few days to seal in the paint etc.. etc.. to make it alllll pretty...
in addition to what is seen i also have new timing tape/ clutch(on order) all gaskets needed.. and well.. oil etc...
whenever the gloss gets sprayed i'll be ready and waiting to put the body back together.... so i can finish sliding in the motor and be reeeady to go....
also got a new shock bolt mount for my front axle.. the old one was MIA for quite some time now...
hopefully.. three weeks.. we'll be good to go... and i'll be ready fo break in!
Army vet 02-08
Old 07-12-2009, 01:02 AM   #137
dammitmitchell
the pollock
Re: project: FTD
and a new LINK to see my photos's ive rpeviously posted.. (due to photobucket being dorks!)
http://s295.photobucket.com/albums/m...itchell/truck/
Army vet 02-08
Old 07-12-2009, 09:35 AM   #138
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: project: FTD
cool i cant wait to see it on the road
is this a longbed
Gage
Old 07-12-2009, 01:25 PM   #139
dammitmitchell
the pollock
Re: project: FTD
yeap!
hey gage you want a cam? im seding it tothe swhot this week to find out which one it is.. it's not crazy, but it's nto stock....
waiting to find out what it is..
Army vet 02-08
Old 07-12-2009, 01:33 PM   #140
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: project: FTD
what are the numbers on it
Gage
Old 07-12-2009, 04:17 PM   #141
dammitmitchell
the pollock
Re: project: FTD
wooot wooot! ordered my poly body bushings wheee!
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=53
now.. with the cab sittign at the correct angle (instead of metal on metal rad support, while rear of cab is on new bushings) and my motor is seated correctly! on the CORRECT engine mounts
my distro will FINALLY be able to be adjusted without a whole lot of complaiing!
Army vet 02-08
Old 07-12-2009, 09:37 PM   #142
TheSebring
Re: project: FTD
Man we need to get a filter for you bro. Sometimes you type things out so fast that it takes me a minute to figure out what you're trying to say
Nice work on the truck so far. Keeping my eye on the build process.
TheSebring is offline   Reply With Quote
Old 07-12-2009, 11:23 PM   #143
dammitmitchell
the pollock
Re: project: FTD
i talk like i think.. and i type like i talk..
yes i should Slllooooowwww down.. but it's a terrible habit left over from the army.. it's kinda lie army induced ADD...
it sucks! hahahha
Army vet 02-08
Old 07-16-2009, 04:32 PM   #144
dammitmitchell
the pollock
Re: project: FTD
i had o do this....
was doing body mounts..
one bolt snapped off.. (and yes i used PB blaster.. my usual soaking regiem etc...)
then i welded a socket onto the remaining shaft of the bolt..
bolt broke so far in that i couldnt save it..
so.. after heating etc.. it's just impossible..
so...
i did this... now that ive calmed down im going to wait til tomorrow morning before i start welding it all back together
Army vet 02-08
Old 07-16-2009, 06:01 PM   #145
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: project: FTD
man that sucks ive been getting pretty pissed when doing my suspension
my dad always says jokingly sit down drink a beer and smoke a cigarette (in your case cigar)
Gage
Old 07-17-2009, 02:04 AM   #146
dammitmitchell
the pollock
Re: project: FTD
well weather her tonight sucked.. (hot and we had alot of power outages..)
and so i moved my heads into the living room to make em pretty and complete...
and then my awesome wife wanted to leart what in the world i was doing =-)
Army vet 02-08
Old 07-19-2009, 05:42 PM   #147
TheSebring
Re: project: FTD
Weather here has been burning my skin plum off. We had like 5 consecutive days of 100+ and they just keep coming.
Old 07-19-2009, 07:06 PM   #148
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: project: FTD
now that is a good wife. I wish mine was into cars or at least interested.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 07-19-2009, 08:49 PM   #149
dammitmitchell
the pollock
Re: project: FTD
it took begging =-) she dosent like to be ignored sooooo.. that was her onlly way of getting attention that night was to help =-)
but HEY it's worth it!
hehehhe
Army vet 02-08
Old 07-19-2009, 09:01 PM   #150
dammitmitchell
the pollock
Re: project: FTD
nothing done this weekend.. to much family stuff going on.. it'll be tuesday until i can even begin decam install... bummer
Army vet 02-08
