Old 03-08-2016, 09:57 PM   #126
dean jendro
Old and crusty
dean jendro's Avatar
Re: Wing or vent window rebuild
A lot of the kit stuff out there is very generic and often doesn't work for every application. You can get any length tubular rivet from these guys.
http://www.rivetsinstock.com/rivets/...ar-rivets.html
65 Chevy long wide daily driver - SOLD!
64 Chevy Short Step LS
dean jendro is offline   Reply With Quote
Old 03-08-2016, 10:06 PM   #127
Larry64
Dean Thank you very much. Just what I need.
Never drive faster than your Guardian Angel can fly
Larry
Larry64 is offline   Reply With Quote
Old 03-09-2016, 05:50 PM   #128
Larry64
The frame is 0.110, the seal is 0.180 & the rivets I got from T & C shop are 0.200. So to even make it through the rubber they are 0.090 short. Thanks again Dean I bought a box of 100 (smallest order) for less than $8.00.
Larry
Old 03-09-2016, 10:59 PM   #129
dean jendro
Old and crusty
You are welcome. Some of what should be simple projects can turn out to be not so simple, especially if a lot of time has lapsed between tear down and rebuild. I picked up a spare vent window early in the process just to have a good sample of how it was supposed to look. That helped me a lot too. The rivet kits that are for sale for these trucks usually come up short on proper lengths, number of rivets and even the swaging tools. I ended up buying all that on line from one of the rivet manufacturers. The dies that they sell are a lot better and make the driven head roll over properly instead of just flattening and cracking. Take your time, experiment on some scraps of the same thickness and it will all come together.
Old 03-09-2016, 11:07 PM   #130
Larry64
Will do.
Larry
Old 03-26-2016, 04:45 AM   #131
skip64
As far as I can tell, I only need the actual vent glass frame. The post that the vent handle attaches to is gone. Is there a place to just buy the frame only?
Thanks,
SKIP64
skip64 is offline   Reply With Quote
Old 03-26-2016, 09:11 AM   #132
dean jendro
Old and crusty
Thanks,
SKIP64
Junk yard.
Old 09-05-2017, 09:11 PM   #133
88k5jimmy
Is there anyway to re-host the pics for this write up? Also, has anybody investigated having the vent window not open, making it a solid non-operable piece of glass that utilizes a better seal and alleviates the issues with the seals not filling the gap between the vent window and door edge?
88k5jimmy is offline   Reply With Quote
Old 01-04-2018, 12:40 PM   #134
nibulus
nibulus's Avatar
Trying to mount the vent glass only, without disassembling the frame. The glass is simply missing.
I guess there‘s no need to take it apart, or am I wrong?
I‘m struggling mounting the glass though...
Is the bottom of the glass normally sort of wavy like the one I have (see below)? Or is it just poor quality?
nibulus is offline   Reply With Quote
Old 01-04-2018, 01:35 PM   #135
forestb
forestb's Avatar
I think it depends on what kind of shape your gasket is in. If it is in bad shape then I think you could. If it is in good shape than probably not. If your paint is in good shape I would not try it without taking out the frame. If you take out the frame it would be a good time to change the rubber seal also
forestb is offline   Reply With Quote
Old 01-04-2018, 03:57 PM   #136
Afirehawk1
Sounds like alot of work.
Why not swap out with reproductions?
Afirehawk1 is offline   Reply With Quote
Old 01-04-2018, 04:07 PM   #137
The Rocknrod
Moderator
The Rocknrod's Avatar
Old 01-04-2018, 08:30 PM   #138
dean jendro
Old and crusty
All this glass is just flat panel glass. Sounds like you don't have a pattern, but your glass person can pop out the other side and use that for a pattern. He would then re-install both glass with new glass tape and off you go. The idea of this post was to show how to properly rebuild the whole wing window but if everything is in good shape just put in a new piece of glass, otherwise take it apart and replace or repair all shoddy components.
Old 01-14-2018, 10:50 PM   #139
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Sorry folks, Photobucket is holding my pics ransome. I do have all the pics that i have linked here.
I don't have edit capabilities to change previous post but i will see if a mod can edit my first post to include the link to pics until I can get this resolved.
Alan's Classic is offline   Reply With Quote
Old 01-15-2018, 09:20 PM   #140
Alan's Classic
Captainfab gave me this suggestion and it worked to view blocked pics. Here is is suggestion.
Originally Posted by Captainfab View Post
Regarding the photobucket pics, all you need is to download the photobucket fir for the particular browser you are using. I use Firefox and downloaded the fix. I can see all pics in this thread as well as all others on this forum.
Old 04-11-2018, 03:14 PM   #141
Dodge68charger
This Thread Is Exactly What I Need To Start My Rebuild... Any Way To Get The Pictures To Download. Not Working on Any ofmy Devices
Dodge68charger is offline   Reply With Quote
Old 04-11-2018, 04:25 PM   #142
Alan's Classic
This is a link to my google album that has all the pics. Maybe it will help for now.
https://photos.app.goo.gl/ubCvVmf1xKJWahMW2
Old 04-11-2018, 04:38 PM   #143
Dodge68charger
Awesome. Thank You
Old 04-13-2018, 10:15 PM   #144
CousinTone
Is there anything Captianfab doesn't know? I've been suffering for a long time, a quick click and all pics are showing up perfectly.
Thanks for taking the time to pass on the tip. Tony "V"
CousinTone is offline   Reply With Quote
