03-31-2011, 12:25 AM | #126 | |
high-Tech Red Neck
Re: 1970 GMC Suburban... for the family
Flip me the bird from your Prius, go ahead!
"He used to be a pretty nice feller, now he's a welder!" Last edited by MrBeast; 03-31-2011 at 12:26 AM. |
03-31-2011, 11:59 PM | #127 |
Junk Yartist
No one caught the fact that I installed the new laptop screen upside down! look in the lower right corner of the screen pic. I thought it was funny.
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
04-01-2011, 12:22 PM | #128 |
That one of those original "Hybird" vehicles ain't it? Maybe the Prius is it's baby.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
04-01-2011, 09:24 PM | #129 |
Junk Yartist
It is! It is a diesel electric drive! I think we have one for sale too
04-01-2011, 09:59 PM | #130 |
I like the mid to late 90's seats in these trucks too. There is a black 72 crew cab truck on here that has the same seats you are talking about. I tried to find some interior pics but have had no luck... here are a few I did have. Nice build... I envy your ambition!
04-01-2011, 10:43 PM | #131 | |
Junk Yartist
04-01-2011, 11:01 PM | #132 |
Junk Yartist
Ok, I know this is April 1st, but this is not April Fools. The Suburban is going a new direction...
WE ARE MOVING TO CALIFORNIA!!!!! That's right! I'm not sure of the start date, but we are packing up and heading to California! My wife asked me if that means I would be converting to a lowered 2wd. STILL NOT HAPPENING!!
04-02-2011, 08:39 AM | #133 | ||
GEARHEAD
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
04-05-2011, 03:10 PM | #134 |
Junk Yartist
Just because we are moving doesn't mean work stops! This Axle needs to be done this week! So...
Set-up Complete. Cleaned. This is all I use for sealant. This is all I have ever needed. Covered. And a little less color. Yeah, i nicked the paint in one spot.
04-05-2011, 06:22 PM | #135 |
cool!
Chris 67 c10 swb build in progress 70 c10 lwb driver pending parts for drastic overhaul 70 c20 lwb parts truck for above mentioned drastic overhaul 71 k20 lwb building for off road use and towing |
04-05-2011, 08:42 PM | #136 |
I would be afraid to move, I've got too much junk & yard ornaments to deal with. How are you going to move the suburban with the large hole in the side?
Travis 2005 K2500 Duramax (hauls the junk home) 1967 Chev C10 (hauls a$$) 1970 Suburban (Yukon XL 4 door) 1968 GMC 3/4 ton (sheetmetal only, chassis gone) 2005 Malibu (wife's car, still a Chevy) Project Family Hauler New Home for Chevys (Moved in and working) |
04-05-2011, 08:56 PM | #137 |
Diff cover looks great man - nice touch taking the color off the fin edges!!!
1977 Chevrolet K30 LWB Crew Cab 497HP Mast Motorsports 6.0L LY6 HO engine GM NV4500 5-speed, Centerforce clutch + NP205 D60 + 14-bolt FF w/ Eaton posi + disc brakes Skyjacker 2.5" full spring lift w/ Nitro shocks Custom paint + interior http://67-72chevytrucks.com/vboard/s...d.php?t=435722 |
04-06-2011, 02:12 PM | #138 |
Junk Yartist
I plan to have the "C" pillar section at least tacked in for structure support before then, and then it will just go on a car trailer as a shell... All the parts will go in the moving truck. I think the Suburban is the EASY part of this move!
04-06-2011, 03:17 PM | #139 |
1. I never realized how thick the early sub frame were.
2. At least it has a Dana 60 up front. 3. You still gonna be in the heavy equipment repair business? 4. Where in California are you moving too? Not many active mines in this area I can think of (So Cal) unless you are moving to the desert. |
04-06-2011, 03:58 PM | #140 | |
Junk Yartist
Ridgecrest, CA... which is close to my family so I will be able to help my brother with his truck (pictured a few pages back)!
04-06-2011, 04:28 PM | #141 |
Cool, Lots of nice places to 4 wheel in the Sierras and Death Valley in Fall, Spring and Winter. Ridgecrest was/is the habitat of a lot of druggies so make sure you keep your stuff carefully protected and locked. They love to rip off garages for tools and anything they can sell for a quick buck. Hopefully you can find a place to work that is not highly visible. I suppose if most of your family is around there you'll get the lowdown pretty fast.
04-06-2011, 05:54 PM | #142 | |
Junk Yartist
04-08-2011, 11:28 AM | #143 |
Can you post some pics of your 4x4 burb driveline please!
Tcase crossmember, front drive shaft / rear carrier bearing setup? I'm trying to determine if I need to grab any missing parts before daa Burb comes come. Thanks! Chad
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
04-09-2011, 02:10 AM | #144 |
Junk Yartist
This is the only picture I can find right now... I sold the TH350 and got a SM 465 from another board member, and the t-case will be rebuilt with a new 10 spline input. As far as the carrier bearing, I am fairly certain that the 4WD suburbans did not have one. I may be wrong though. This probably doesn't help you much.
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 Last edited by jbclassix; 11-22-2012 at 11:40 PM. |
04-09-2011, 02:18 AM | #145 |
depends on trans length. The sm465 and 205 were shorter than the th350 or 400 and might require one. the 68 burb I had was set up for one but it was a th350 when I got it and it was torn all apart so not to much to go on.
04-09-2011, 11:23 PM | #146 |
Junk Yartist
Closer!
Also, I found a picture of my wifes truck. Right now it is sitting at my brothers house in Cali. Once we are settled in I am going to start in on this ASAP. For some reason I cant just limit myself to one project at a time! The only reason I may hold off on the truck is I have a car to finish and sell, which may just fund her truck! The car is sitting in Cali too.
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 Last edited by jbclassix; 04-09-2011 at 11:53 PM. Reason: tidy up a bit |
04-11-2011, 09:46 PM | #147 |
6>8 Plugless........
Nice progress on the truck! I did notice the screen pic, but I as well figured that you just had the image flipped. LOL Holly huge dump truck bat man! That looks like it would be a fun deal to work on for like a day. LOL Great job on the rear axle, it looks awesome! Congrats on your move, I wish you luck!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
04-17-2011, 04:31 PM | #148 |
Junk Yartist
Kinda an important part of the build, since this is gonna be the ultimate family rig! My boy is 3 months this morning! They'll be out helping me today since it's so nice out!
Chris, these next pictures are for you!
04-17-2011, 10:55 PM | #149 |
lookin great! I can't wait!
04-19-2011, 03:21 PM | #150 |
Junk Yartist
NEW TOY!!!!
This is all a matter of opinion, but THIS is what I wanted for the rear axle on my Suburban! I'm not going to tear into this axle yet, I have some body work I need to get back to now that other peoples projects are out of the way! I'm super excited about this trade though! This axle will get discs, and the drum parts will be available if anyone needs them, but that is a ways down the road.
