Closed Thread
Old 03-23-2010, 02:58 PM   #126
70k52wd
Blaze-Air
70k52wd's Avatar
Re: Boss 338 Wheels **GROUP BUY**
Originally Posted by brossow View Post
This is pretty much off-topic, but is there a thread anywhere that lists the different rear-end widths for the different years? I've searched the forums and Google with no success. Sure would be nice to have readily available.
Going off the top of my head. I'm running a 71-72 rear. Back plate to plate is 57in if my poor memory serves correct.
Yea 6 lug. I can't win...
70k52wd is offline
Old 03-23-2010, 03:04 PM   #127
Leviticus
Shake and Bake!
Leviticus's Avatar
Well...got some bad news boys. The new revised fronts don't fit. Looks like it is the same issue as before, it won't seat all the way down onto the rotor, looks like it is tight at the front of the hub bore like before.
And just to sweeten the deal the rear 20x10 will require a spacer to fit. I didn't have the tires on but it looks like (judging by sight) about a 1/4 to 1/2" spacer to not rub on the inside of the fender well.
Well, we are dealing with Boss here, what did we expect
"All tyranny needs to gain a foothold is for people of good conscience to remain silent."
Thomas Jefferson
"You are remembered for the rules you break."
General Douglas MacArthur
"Support Our Troops And The NRA"
Leviticus is offline
Old 03-23-2010, 03:06 PM   #128
brossow
Amateur Rust Fighter
brossow's Avatar
Originally Posted by SCOTI View Post
Those will be short. I would recommend a 245-45-18 (26" tall) & 295-40-20 (29" tall).
What do you suggest on a 20x8.5 up front?
Brent
'72 Chevy SWB stepside - [ Build Thread ]
'79 ChevMC SWB fleetside - [ Build Thread ]
'64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...)
brossow is offline
Old 03-23-2010, 03:10 PM   #129
brossow
brossow's Avatar
You sure you got the -3 revision? Doesn't sound like it. Do you have a caliper (measuring device, not the brake component) to measure the bore? Please post some pics, including one of the label on the box.
Hey, now. You can't blame them for your failure to consider backspacing before ordering. As I've said before, the purpose of the revision was to correct the front hub fitment issue, not to change the backspacing (which is unchanged and which you should have recognized as an issue before making your purchase).
Brent
brossow is offline
Old 03-23-2010, 03:25 PM   #130
Tow Me
Glen
Tow Me's Avatar
I might be jumping in on this... I will talk to my dad too since he wants a set. I'll get back before the deadline!
Glen Simpson
Severed Ties - Oregon
Roseburg, Oregon
  • 1983 Chevrolet C10 - Ginger
    Photos
Past Trucks
Tow Me is offline
Old 03-23-2010, 03:27 PM   #131
Leviticus
Shake and Bake!
Leviticus's Avatar
Hey brossow,
don't get all pissy on me, I'm not blaming them for the BS, I had expected I might need a spacer on the rear, no biggie.
But I am blaming them for a revised wheel that does not fit. Box said right on it 3AA. There is a picture of the label in a thread I posted this morning. I'll take some pics of the figment issue when I get home, at the tire store right now.
I might get away with a little grinding on the tip of the hub.
Thomas Jefferson
Old 03-23-2010, 03:35 PM   #132
brossow
brossow's Avatar
Hey brossow,
Sure looked like you were blaming them. You said, "And just to sweeten the deal the rear 20x10 will require a spacer to fit. [...] Well, we are dealing with Boss here, what did we expect." I don't know how else to interpret that statement other than you blaming Boss. But I've been wrong before. *shrug*
Don't want to argue; just surprised by all the people willing to lay out a LOT of money without even knowing what it is they actually need vs. what they'd be getting. Not specifically including you among them -- just making a general observation.
Brent
Brent
brossow is offline
Old 03-23-2010, 03:37 PM   #133
Wildstreak
"something witty here"
Wildstreak's Avatar
so does this mean the re-tooled rims dont fit either?
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline
Old 03-23-2010, 03:38 PM   #134
72mistressc10
72mistressc10's Avatar
x2 ????
1972 C10 LWB Cheyenne Super
God Said,"Owning A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still Gay"
........................__
..........._______ |__\__
..........|__(O)______(O)]
72mistressc10 is offline
Old 03-23-2010, 03:44 PM   #135
brossow
brossow's Avatar
Here's a direct link to the thread mentioned above if anyone wants to follow along over there. Not a good sign....
Brent
brossow is offline
Old 03-23-2010, 03:45 PM   #136
Wildstreak
Wildstreak's Avatar
@Leviticus
I looked at your thread and the part number on your box is for 20x10 even tho it says its for 20x8.5 on your box. I kinda find that odd....
57 chevy 4x4
68 burb 2wd:
Old 03-23-2010, 03:48 PM   #137
Wildstreak
Wildstreak's Avatar
on the boss website I can even see A 20x8.5 with 5 on 5. what is the correct bolt pattern for a 72?
57 chevy 4x4
68 burb 2wd:
Old 03-23-2010, 03:51 PM   #138
brossow
brossow's Avatar
Originally Posted by Wildstreak View Post
@Leviticus
No, that's correct. The part number for a 20x10 in grey is 3387-2050. His box clearly says 3387-2850.
They don't list it there for some reason. The regional manager I've spoken to about these wheels doesn't know why they're not listed in the spec sheet, because they're definitely available and in their system.
Brent
Brent
brossow is offline
Old 03-23-2010, 03:52 PM   #139
72mistressc10
I believe the new hub bore was suppose to be 94.62mm=3.725, right?
Old 03-23-2010, 03:53 PM   #140
Wildstreak
Wildstreak's Avatar
Brent
I know that, but look at the rim size on his box it says 20x8.5.......
57 chevy 4x4
68 burb 2wd:
Old 03-23-2010, 03:54 PM   #141
72mistressc10
part number 3387-2850 is for the 20x8.5
part number 3387-2050 is for the 20x10
Original post shows this also.
Old 03-23-2010, 03:56 PM   #142
Wildstreak
Wildstreak's Avatar
Ah I see now dam 0 and 8 look very similar in small text lol
57 chevy 4x4
68 burb 2wd:
Old 03-23-2010, 03:58 PM   #143
TyKby2
TyKby2's Avatar
Both are about the same height and 295/35/18 is 26 iches tall and 245/40/18 is about 25.75 inches tall. I'm going to run 18's all the way around.
Kevin
1974 Chevy C-10 (The Mistress)
1971 VW Bus
1973 VW Super Beetle
1996 Jeep Cherokee
TyKby2 is offline
Old 03-23-2010, 04:08 PM   #144
TyKby2
TyKby2's Avatar
that is what I thought aswell.
Kevin
1971 VW Bus
1996 Jeep Cherokee
TyKby2 is offline
Old 03-23-2010, 04:14 PM   #145
brossow
brossow's Avatar
Did you see that somewhere official? That's 1/2" larger than what appears to have been delivered. WTF?
I've posted this info multiple times, but once more won't hurt. The national number for American Eagle Wheels (the company behind Boss and several other brands) is 909-590-8828. To find a local distributor, go here: http://americaneaglewheel.com/distributor.cfm. I encourage people to call, ask questions, demand answers, and report back with your findings. Might help to play dumb and just see what they tell you. Some items of interest include:
  1. What is the hub bore on the revised wheels?
  2. What is the ETA on the 20" chrome wheels?
  3. What specifically was changed with the -3 revision?
  4. Are there any plans for other backspacing options on the 20x10 wheel in order to better fit earlier trucks?
I'm sure there are many other questions as well, but those come immediately to mind.
EDIT: You might also consider asking questions in response to their blog post about the revised wheels. The blog is their PR piece, so if they start seeing a lot of public questions they might be more responsive. Please be courteous if you go this route.
Brent
Brent
brossow is offline
Old 03-23-2010, 04:41 PM   #146
Leviticus
Shake and Bake!
Leviticus's Avatar
Brent
Brent,
Not trying to fight with ya, I knew the 20x10 was a toss up on fitment, I was the one over in the other Boss thread saying I will see if it fits or not. I'm not just some idiot shelling out cash thinking they will fit, I was willing to take the risk to run the 10"s in the back.
The fronts on the other hand are somewhat frustrating, but I was expecting the old version when I ordered them so I am just truckin on
Anyways, I'll let you guys know what I can work out on them, I have some 1/4" spacers for the rear I am going to try to see if they get me clear.
And we will see how much material I am going to have to take off the front hub.
I'll keep you all posted, on a good note,the tires look sweeet on the wheels!
Thomas Jefferson
Old 03-23-2010, 04:52 PM   #147
72swb_327stroker_?
knuckle buster..
72swb_327stroker_?'s Avatar
*EHEM***
_______________________________________________________________________________
Eric
THIS SITE ROCKS!!!
Check out my suburban on 20's with fresh paint!
Click here to support the site
Check out the Member Photo Gallery here
StreetCruizin
FAQ thread
Site vendors list (scroll down to vendors in red)
join the the smilies fight club
72swb_327stroker_? is offline
Old 03-23-2010, 04:56 PM   #148
brossow
brossow's Avatar
Originally Posted by 72swb_327stroker_? View Post
*EHEM***
*EHEM*** See posts 131 and 135 in this thread for info and a link with pics.
Brent
brossow is offline
Old 03-23-2010, 05:10 PM   #149
Sublvr72
Sublvr72's Avatar
looks like they fit fine 20x8.5 and 20x10
Sublvr72 is offline
Old 03-23-2010, 05:14 PM   #150
Leviticus
Shake and Bake!
Leviticus's Avatar
Ok, guys,
Here are some pics of the front fitment issue. It looks like it is just hitting the front edge of the hub bore, from what I can tell, nothing behind where it is hitting towards the front of the wheel is an issue.
Its hard to judge how far off the rotor face it is sitting cause the wheels wants to oscillate on the hub but it looks like about a 1/4" or less. I think we are better off than the old version, but not direct fit.
I pulled my Caliper Gauge out to get you numbers on the hub bore but its and electric one and the battery was dead (left it on doh!) I'll get some batteries for it today.
You can see where its hitting in the hub in the pics.
Thomas Jefferson
Closed Thread
boss 338, group buy, wheels
